hola, hace unos dias instale manjaro en mi laptop huawei matebook D14 con cpu i3-10110U arquitectura Comet/Whiskey Lake y no tengo sonido en mi latop. He intentado darle solucion reinstalando pulseaudio, configurando alsa, y otras cosas mas, pero no encuentro una solucion a mi problema.
les dejo el resultado de inxi -Fazy
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=0f8422aa-0771-4a63-9033-d349a2794697 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: HUAWEI product: NBLB-WAX9N v: M1010
serial: <superuser required>
Mobo: HUAWEI model: NBLB-WAX9N-PCB-B2 v: M1010
serial: <superuser required> UEFI: HUAWEI v: 1.35 date: 06/23/2021
ID-1: BAT1 charge: 19.2 Wh (37.5%) condition: 51.2/54.9 Wh (93.1%)
volts: 8.2 min: 7.6 model: Desay HB4692Z9ECW-22T type: Li-ion
serial: <filter> status: charging cycles: 133
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 20810
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: QUANTA driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 13d3:5476 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0877 built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: QUANTA
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 238.47 GiB used: 30.71 GiB (12.9%)
model: MZVLB256HBHQ-00000 size: 238.47 GiB block-size: physical: 512 B
rev: EXH7201Q temp: 36.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
used: 30.7 GiB (12.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
System Temperatures: cpu: 42.0 C pch: 33.0 C mobo: N/A
Processes: 261 Uptime: 4h 6m wakeups: 6 Memory: 7.51 GiB
used: 2.76 GiB (36.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1218 pacman: 1191 lib: 304 flatpak: 15
snap: 12 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
