Te mando salida del os-prober y del jourtalctl:
[manjaro andreu]# os-prober
/dev/sdb2@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda1
ago 20 14:10:44 manjaro andreu[3743]: 50mounted-tests: debug: /dev/sda1 type not recognised; skipping
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sda1
ago 20 14:10:44 manjaro andreu[3743]: 50mounted-tests.orig: debug: /dev/sda1 type not recognised; skipping
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests.orig
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: 05efi: debug: /dev/sda2 is ext4 partition: exiting
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: 10freedos: debug: /dev/sda2 is not a FAT partition: exiting
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: 10qnx: debug: /dev/sda2 is not a QNX4 partition: exiting
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/sda2
ago 20 14:10:44 manjaro macosx-prober[3840]: debug: /dev/sda2 is not an HFS+ partition: exiting
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: 30utility: debug: /dev/sda2 is not a FAT partition: exiting
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/sda2
ago 20 14:10:44 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/sda2
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/sda2
ago 20 14:10:45 manjaro andreu[3743]: 83haiku: debug: /dev/sda2 is not a BeFS partition: exiting
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/sda2
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/sda2
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/sda2
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdb1
ago 20 14:10:45 manjaro andreu[3743]: 50mounted-tests: debug: /dev/sdb1 type not recognised; skipping
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdb1
ago 20 14:10:45 manjaro andreu[3743]: 50mounted-tests.orig: debug: /dev/sdb1 type not recognised; skipping
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests.orig
ago 20 14:10:45 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdb2
ago 20 14:10:45 manjaro kernel: device-mapper: uevent: version 1.0.3
ago 20 14:10:45 manjaro kernel: device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: mounted using GRUB fat filesystem driver
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: /dev/sdb2 is a FAT partition (mounted by GRUB)
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: /dev/sdb2 partition scheme is gpt
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: /dev/sdb2 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: running subtest /usr/lib/os-probes/mounted/efi/10elilo
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: running subtest /usr/lib/os-probes/mounted/efi/20microsoft
ago 20 14:10:46 manjaro andreu[3743]: 20microsoft: result: Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: bootloader Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows found by subtest /usr/lib/os-probes/mounted/efi/20microsoft
ago 20 14:10:46 manjaro andreu[3743]: 05efi: result: /dev/sdb2@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: os found by subtest /usr/lib/os-probes/mounted/05efi
ago 20 14:10:46 manjaro systemd[1]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:46 manjaro systemd[1457]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:46 manjaro andreu[3743]: os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests
ago 20 14:10:46 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdb3
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
ago 20 14:10:46 manjaro andreu[3743]: 05efi: debug: /dev/sdb3 is ntfs partition: exiting
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
ago 20 14:10:46 manjaro andreu[3743]: 10freedos: debug: /dev/sdb3 is not a FAT partition: exiting
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
ago 20 14:10:46 manjaro andreu[3743]: 10qnx: debug: /dev/sdb3 is not a QNX4 partition: exiting
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
ago 20 14:10:46 manjaro macosx-prober[4032]: debug: /dev/sdb3 is not an HFS+ partition: exiting
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
ago 20 14:10:46 manjaro andreu[3743]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
ago 20 14:10:46 manjaro andreu[3743]: 30utility: debug: /dev/sdb3 is not a FAT partition: exiting
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
ago 20 14:10:46 manjaro andreu[3743]: 83haiku: debug: /dev/sdb3 is not a BeFS partition: exiting
ago 20 14:10:46 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
ago 20 14:10:47 manjaro systemd[1457]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:47 manjaro systemd[1]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:47 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdb3
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: mounted using GRUB ntfs filesystem driver
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/05efi
ago 20 14:10:47 manjaro andreu[3743]: 05efi: debug: /dev/sdb3 is ntfs partition: exiting
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10freedos
ago 20 14:10:47 manjaro andreu[3743]: 10freedos: debug: /dev/sdb3 is not a FAT partition: exiting
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10qnx
ago 20 14:10:47 manjaro andreu[3743]: 10qnx: debug: /dev/sdb3 is not a QNX4 partition: exiting
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20macosx
ago 20 14:10:47 manjaro macosx-prober[4110]: debug: /dev/sdb3 is not an HFS+ partition: exiting
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
ago 20 14:10:47 manjaro andreu[3743]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/30utility
ago 20 14:10:47 manjaro andreu[3743]: 30utility: debug: /dev/sdb3 is not a FAT partition: exiting
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/40lsb
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/70hurd
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/80minix
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/83haiku
ago 20 14:10:47 manjaro andreu[3743]: 83haiku: debug: /dev/sdb3 is not a BeFS partition: exiting
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90solaris
ago 20 14:10:47 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/efi
ago 20 14:10:48 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdb4
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
ago 20 14:10:50 manjaro systemd[1457]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:50 manjaro andreu[3743]: 05efi: debug: /dev/sdb4 is ntfs partition: exiting
ago 20 14:10:50 manjaro systemd[1]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
ago 20 14:10:50 manjaro andreu[3743]: 10freedos: debug: /dev/sdb4 is not a FAT partition: exiting
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
ago 20 14:10:50 manjaro andreu[3743]: 10qnx: debug: /dev/sdb4 is not a QNX4 partition: exiting
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
ago 20 14:10:50 manjaro macosx-prober[4194]: debug: /dev/sdb4 is not an HFS+ partition: exiting
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
ago 20 14:10:50 manjaro andreu[3743]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
ago 20 14:10:50 manjaro andreu[3743]: 30utility: debug: /dev/sdb4 is not a FAT partition: exiting
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
ago 20 14:10:50 manjaro andreu[3743]: 83haiku: debug: /dev/sdb4 is not a BeFS partition: exiting
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
ago 20 14:10:50 manjaro andreu[3743]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
ago 20 14:10:50 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdb4
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: mounted using GRUB ntfs filesystem driver
ago 20 14:10:51 manjaro systemd[1]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/05efi
ago 20 14:10:51 manjaro systemd[1457]: var-lib-os\x2dprober-mount.mount: Succeeded.
ago 20 14:10:51 manjaro andreu[3743]: 05efi: debug: /dev/sdb4 is ntfs partition: exiting
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10freedos
ago 20 14:10:51 manjaro andreu[3743]: 10freedos: debug: /dev/sdb4 is not a FAT partition: exiting
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10qnx
ago 20 14:10:51 manjaro andreu[3743]: 10qnx: debug: /dev/sdb4 is not a QNX4 partition: exiting
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20macosx
ago 20 14:10:51 manjaro macosx-prober[4271]: debug: /dev/sdb4 is not an HFS+ partition: exiting
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
ago 20 14:10:51 manjaro andreu[3743]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/30utility
ago 20 14:10:51 manjaro andreu[3743]: 30utility: debug: /dev/sdb4 is not a FAT partition: exiting
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/40lsb
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/70hurd
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/80minix
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/83haiku
ago 20 14:10:51 manjaro andreu[3743]: 83haiku: debug: /dev/sdb4 is not a BeFS partition: exiting
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90solaris
ago 20 14:10:51 manjaro andreu[3743]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/efi
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: /dev/sdb6: is active swap
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: 05efi: debug: /dev/sdb7 is a FAT32 partition
ago 20 14:10:52 manjaro andreu[3743]: 05efi: debug: /dev/sdb7 partition scheme is gpt
ago 20 14:10:52 manjaro andreu[3743]: 05efi: debug: /dev/sdb7 partition type is 0fc63daf-8483-4772-8e79-3d69d8477de4
ago 20 14:10:52 manjaro andreu[3743]: 05efi: debug: /dev/sdb7 is not a ESP partition: exiting
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: 10freedos: debug: /dev/sdb7 is a FAT32 partition
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: 10qnx: debug: /dev/sdb7 is not a QNX4 partition: exiting
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/sdb7
ago 20 14:10:52 manjaro macosx-prober[4351]: debug: /dev/sdb7 is not an HFS+ partition: exiting
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: 30utility: debug: /dev/sdb7 is a FAT32 partition
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: 83haiku: debug: /dev/sdb7 is not a BeFS partition: exiting
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/sdb7
ago 20 14:10:52 manjaro andreu[3743]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/sdb7
Salida:
ID_PART_ENTRY_SCHEME=gpt
ID_PART_ENTRY_TYPE=0fc63daf-8483-4772-8e79-3d69d8477de4
