zital
18 October 2023 20:16
1
Hi, I’m new in Manjaro, I’m using the XFCE version, but when I power on the PC it freezes when is loading the 3 points screen. I power off the pc, then power on and it works well.
Where I can find the logs to check what is happening when I power on at the first attempt?
my cpu/gpu: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
kernel 6.5.5-1-MANJARO
xfce: 4.18
cscs
18 October 2023 20:21
2
Hullo,
Is the first boot cold as well? (as opposed to, for example, rebooting from another system)
Also. Maybe include system info. Such as inxi -Fazy
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
zital
18 October 2023 20:39
4
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=6f82471f-83df-4ff8-9720-a97aec8a3bec rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Maxtang model: FP30 v: V1.0 serial: <superuser required>
UEFI: American Megatrends v: FP30T111 date: 04/03/2020
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1600 min/max: 1600/2000 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1600
4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31949
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1 bus-ID: 04:00.0 chip-ID: 1002:15dd class-ID: 0300 temp: 61.0 C
Display: x11 server: X-org v: 1.21.1.8 compositor: xfwm v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Philips PHL 243V7
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:15dd memory: 1000 MiB
unified: no
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3.4.3:7 chip-ID: 0d8c:0014 class-ID: 0300
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 238.47 GiB used: 15.85 GiB (6.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBUSNS4180S3256GJ
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 61D1 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 15.85 GiB (6.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 60.9 C mobo: N/A gpu: amdgpu temp: 60.0 C
Fan Speeds (rpm): N/A
Processes: 258 Uptime: 4m wakeups: 0 Memory: total: 8 GiB note: est.
available: 6.73 GiB used: 1.94 GiB (28.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1093 libs: 311 tools: pamac,paru pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: guake inxi: 3.3.30
I know what the problem is, I created a 2 desktop entries in: /home/zital/.config/autostart
guake.desktop
[Desktop Entry]
Type=Application
Name=guake
Exec=/usr/bin/guake
Terminal=false
rfkill.desktop
[Desktop Entry]
Type=Application
Name=rfkill
Exec=/usr/bin/rfkill block 0
Terminal=false
when I put these entries in the startup it crashes and manjaro removes its.
What is the problem with these entries?
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Physician, heal thyself: Desktop Entries
