Hi all, I am having a problem trying to start up UFW on my installation.
I recently installed a newer Kernel version, the output of uname -r
is: 5.4.62-1-MANJARO
When I run sudo ufw enbale
I am met with the following output:
ERROR: problem running ufw-init
modprobe: FATAL: Module nf_conntrack_ftp not found in directory /lib/modules/5.4.62-1-MANJARO
modprobe: FATAL: Module nf_nat_ftp not found in directory /lib/modules/5.4.62-1-MANJARO
modprobe: FATAL: Module nf_conntrack_netbios_ns not found in directory /lib/modules/5.4.62-1-MANJARO
iptables-restore v1.8.5 (legacy): Couldn't load match `limit':No such file or directory
Error occurred at line: 63
Try `iptables-restore -h' or 'iptables-restore --help' for more information.
Error occurred at line: 8
ip6tables-restore v1.8.5 (legacy): Couldn't load match `rt':No such file or directory
Error occurred at line: 24
Try `ip6tables-restore -h' or 'ip6tables-restore --help' for more information.
Problem running '/etc/ufw/before.rules'
Problem running '/etc/ufw/user.rules'
Problem running '/etc/ufw/before6.rules
This causes all internet traffic to fail completely without disabling ufw.
Curiously when I run ls -l /lib/modules
I am met with:
total 16
drwxr-xr-x 4 root root 4096 Sep 15 17:04 4.19.144-1-MANJARO
drwxr-xr-x 4 root root 4096 Sep 15 17:04 5.4.64-1-MANJARO
drwxr-xr-x 2 root root 4096 Sep 15 17:03 extramodules-4.19-MANJARO
drwxr-xr-x 2 root root 4096 Sep 15 17:03 extramodules-5.4-MANJARO
And running sudo mhwd-kernel -li
I am met with:
Currently running: 5.4.62-1-MANJARO (linux54)
* linux419
* linux54
So when I run a command to print out my kernel version I get 5.4.62-1-MANJARO
but the modules in /lib/modules
seem to be for 5.4.64-1-MANJARO
. I am unsure if this is the major issue or a red herring, any ideas?
