After solving the problem with the laptop-lid occured a new problem with the resolution of fullscreen. On my sytem are 2 monitors, the laptop-screen with 1366 x 768 and the tv-screen with 1920 x 1080 resolution. The laptop is closed and the tv is the main-screen. When I switch the windows in xfce to fullscreen the resolution switches only to 1366 x 768. I can manualy enlarge the windows to the full size, but by enabling fullscreen it switches back to 1366 x 768. Watching video in fullscreen is not possible (vlc, telegram, firefox).
This is the actuell output of xini:
inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.2-2-rt19-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-rt-x86_64
root=UUID=d0bc7191-a1c7-4201-a5f3-e37e56238f7e rw quiet apparmor=1
security=apparmor resume=UUID=a2cb04dd-618c-4f19-a445-4ea08c13fd41
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Packard Bell product: Easynote ENTG71BM v: V1.10
serial: <superuser required>
Mobo: Packard Bell model: Easynote ENTG71BM v: V1.10
serial: <superuser required> UEFI-[Legacy]: Insyde v: 1.10 date: 12/15/2014
ID-1: BAT0 charge: 29.0 Wh (100.0%) condition: 29.0/36.7 Wh (79.1%)
volts: 11.9 min: 11.4 model: LGC AC14B18J type: Li-ion serial: <filter>
status: full
Device-1: hid-20:73:34:07:30:5d-battery model: ECBK02 serial: N/A
charge: N/A status: discharging
RAM: total: 1.82 GiB used: 1.07 GiB (58.9%)
RAM Report:
Info: model: Intel Celeron N2840 bits: 64 type: MCP arch: Silvermont
family: 6 model-id: 0x37 (55) stepping: 8 microcode: 0x838
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 923 high: 1090 min/max: 500/2582 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 756 2: 1090
bogomips: 8666
Flags: 3dnowprefetch acpi aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Acer Incorporated ALI driver: i915 v: kernel ports:
active: HDMI-A-1,eDP-1 empty: DP-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0f31 class-ID: 0300
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus-ID: 2-4:4
chip-ID: 04f2:b47f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: 43FHD_LCD_TV
built: 2015 res: 1920x1080 hz: 60 dpi: 38 gamma: 1.2
size: 1280x720mm (50.39x28.35") diag: 1093mm (43") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: primary model: LG Display 0x0456 built: 2014
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:0f04 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-2-rt19-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Foxconn driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wls2 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: ens3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 2-3.1:9
chip-ID: 0489:e078 class-ID: e001
Local Storage: total: 495.06 GiB used: 12.56 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Intenso model: Rainbow Line
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.07 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUC0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 461.76 GiB size: 453.44 GiB (98.20%)
used: 12.55 GiB (2.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: d0bc7191-a1c7-4201-a5f3-e37e56238f7e
ID-1: swap-1 type: partition size: 4 GiB used: 11.8 MiB (0.3%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: a2cb04dd-618c-4f19-a445-4ea08c13fd41
ID-1: /dev/sdb1 maj-min: 8:17 size: 3.32 GiB fs: iso9660
ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: E23F-1E9F
Hub-1: 1-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 2-1:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Hub-3: 2-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 2-3.1:9 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0489:e078
class-ID: e001
Device-2: 2-3.2:6 info: Trust Keyboard & Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 145f:022a class-ID: 0301
Device-3: 2-3.3:7 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
Device-4: 2-3.4:8 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-5: 2-4:4 info: Chicony VGA Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b47f
Hub-4: 3-0:1 info: Super-speed hub ports: 1 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 200 Uptime: 1h 46m wakeups: 7 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1131
lib: 344 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.14
I donĀ“t know where to change it, in Display-manager or XFCE-settings?
Thank you
