Problem with trying to recover from an interrupted update/upgrade
So as the title says, I’m trying to recover from an interrupted updat by following this guide:
https://forum.manjaro.org/t/howto-recovering-from-an-interrupted-update-upgrade/132762
However, in the middle of upgrading my PC freezes, and after a while I figured out it was because of my SSD. I am using an Acer Aspire A315-23 laptop, and whenever I liveboot a distro it freezes after a while even when using boot parameters from this guide https://askubuntu.com/questions/1277405/problems-installing-ubuntu-on-acer-laptop
This usually isn’t a problem, however the recovery process takes some time and it always freezes in the middle of upgrading. After some time I thought about editing and updating Grub, however it’s impossible to do that on a liveusb.
In short, I have two questions:
  1. Is it possible to permanently alter the boot parameters on a liveboot medium? OR
  2. Is it possible to cut down time required for the recovery process
    Sorry if this question(s) has/have been asked before
Thanks in advance!
Yes - altering them does not even require chroot
because what need you alter / edit is the /etc/default/grub file on your system partition
not the one on the live system.
Just mount the partition and do whatever …
But after altering them you need to run update-grub
or the equivalent
grub-mkconfig -o /boot/grub/grub.cfg
and that only works from within a chroot
What recovery process?
The file system check that runs after you shut down by cutting the power/turning it off?
No - it takes the time it takes - and it is needed.
ps:
I may have misunderstood you:
the only way to edit the grub parameters for the live system is to press ESC to halt at the Grub screen, then press E to edit - there is no way to make this permanent.
In this case, I’d suggest (attempting) a clone of this onto a new device, and see if the problem persists. CloneZilla can be used for this.
  1. Why you think it is your SSD? Do you have enough free space?
  2. What are your pamac.logs showing?
    /var/log/pacman.log
  3. How did you update? Maybe try to update from TTY?
  4. I recommend to use in future Timeshift, you can always fix better your system if you can rollback your system… at least you have a safety net and you have always a working system.
Sorry for wasting everyone’s time but due to an emergency I have wiped my system in the meantime.
Hold up on the solution.
Are you sure you are reinstalling the right OS for you this time around?
Yes, I am absolutely certain. Thank you for your patience.
A new nuke-and-pave installation is not a “recovery” from anything, nor does it address or in any way “solve” what caused the issue in the first place, so is not helpful at all, and not a useful “solution” for anybody reading this.
Sorry if this sounds a bit harsh, but it’s a statement of truth.
AFAIK The problem is that the Western Digital SSD has a problem with power states which prevents linux from recognizing it (WD apparently doesn’t test their SSDs with linux distros), see: https://community.wd.com/t/linux-support-for-wd-black-nvme-2018/225446/17. A way of fixing this is modifying the grub file. However it is impossible to do such a thing on a liveboot medium. I’m pretty sure that the problem can only be permanently solved by replacing the SSD. Once again thank you for being so understanding.
Interesting re. the SSD issue; I wonder what shows up with sudo smartctl -x /dev/sdXX (change sdXX to whatever your machine reports it as)?
You might need to install smartmontools first. It’s in “extra” repo. :wink:
I wonder if it’s overheating? I’ve heard that can be an issue, although the SSD I have in mine runs practically cold even with big transfers.
Thanks for the suggestion. Here’s what I got:
=== START OF INFORMATION SECTION ===
Model Number:                       WDC PC SN520 SDAPNUW-256G-1014
Serial Number:                      2039D2803732
Firmware Version:                   20110000
PCI Vendor/Subsystem ID:            0x15b7
IEEE OUI Identifier:                0x001b44
Total NVM Capacity:                 256,060,514,304 [256 GB]
Unallocated NVM Capacity:           0
Controller ID:                      1
NVMe Version:                       1.3
Number of Namespaces:               1
Namespace 1 Size/Capacity:          256,060,514,304 [256 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            001b44 8b49c12e9d
Local Time is:                      Sun Oct  6 14:07:56 2024 CEST
Firmware Updates (0x14):            2 Slots, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Log Page Attributes (0x02):         Cmd_Eff_Lg
Maximum Data Transfer Size:         128 Pages
Warning  Comp. Temp. Threshold:     82 Celsius
Critical Comp. Temp. Threshold:     86 Celsius
Namespace 1 Features (0x02):        NA_Fields
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     2.60W       -        -    0  0  0  0        0       0
 1 +     2.60W       -        -    1  1  1  1        0       0
 2 +     1.70W       -        -    2  2  2  2        0       0
 3 -   0.0250W       -        -    3  3  3  3     5000    9000
 4 -   0.0025W       -        -    4  4  4  4     5000   44000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         2
 1 -    4096       0         1
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        47 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    8%
Data Units Read:                    90,082,154 [46,1 TB]
Data Units Written:                 31,887,533 [16,3 TB]
Host Read Commands:                 1,038,561,985
Host Write Commands:                478,749,191
Controller Busy Time:               2,427
Power Cycles:                       7,987
Power On Hours:                     11,004
Unsafe Shutdowns:                   149
Media and Data Integrity Errors:    0
Error Information Log Entries:      124
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Error Information (NVMe Log 0x01, 16 of 256 entries)
No Errors Logged
Read Self-test Log failed: Invalid Field in Command (0x4002)
This looks OK to me but I could be missing something. Also I’m unsure about this:
It doesn’t look like there’s been any heat issue, though, at least with the drive itself. Maybe a controller issue?
Edited to add: what memory and swap do you have available?
free -h
               total        used        free      shared  buff/cache   available
Mem:           5,7Gi       2,5Gi       2,8Gi       146Mi       784Mi       3,2Gi
Swap:          2,0Gi       664Mi       1,4Gi
That looks decent enough; I’d have more swap but at least you have some. Unlike what I’m seeing a lot here lately: “No swap defined”.
I had an issue some time back where in my case Haskell modules were taking an age to install, due to a bad sector on the disk. It would get stuck for ages, until I fixed the issue. Not sure how this would relate with an SSD, though.
Watch the logs whilst upgrading; save them and post here. We might be able to spot something.
sudo pacman -Syu --logfile ~/.upgrade-log.txt
I use a slightly different method: I manually copy the Pacman output and save it in a date-stamped text file for future reference. But you may need to alter your Terminal scrollback limit:
echo export HISTSIZE=10000 >> ~/.bashrc
Will do!
