Problem with touchscreen monitor in multi-head setup after upgrade to Gnome 44
Hi everyone!
After having done the upgrade to Gnome 44 (I think it was 2 stable updates ago) my touchscreen Dell p2418ht touch monitor stopped working. After some experimentation with xinput-calibration I realized the problem was that the touchscreen was being mapped to an all-encompassing virtual screen encompassing my 3 displays.
I managed to fix the problem by installing xrandr-watch-git and adding an xinput --map-to-output statement, as directed here.
Although I don’t have a problem right now, I wanted to report a potential bug in Gnome 44, as this mapping had been done automatically in previous Gnome versions.
Here’s my inxi in case it helps:
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=20705b87-eec6-4fb3-8353-031c51df1cac ro quiet splash apparmor=1
    security=apparmor udev.log_priority=3 nvidia_drm.modeset=1
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4602
    date: 02/23/2023
  Device-1: hid-CC20412029RJ2XQAQ-battery model: Apple Inc. Magic Trackpad 2
    serial: N/A charge: N/A status: discharging
  Device-2: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
    status: discharging
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2436 high: 3700 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 3530 9: 2200 10: 2878 11: 2200
    12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 3700 18: 2874 19: 2200
    20: 3700 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177341
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Nanjing Magewell Eco Capture Dual HDMI M.2 vendor: SafeNet
    driver: Eco Capture v: N/A alternate: MWEcoCapture pcie: gen: 2 speed: 5 GT/s
    lanes: 4 bus-ID: 04:00.0 chip-ID: 1cd7:0051 class-ID: 0400
  Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-1,DP-2,DP-3
    empty: HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 10de:2182 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 5440x1080 s-dpi: 96 s-size: 1439x286mm (56.65x11.26")
    s-diag: 1467mm (57.76")
  Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right model: Dell P2418HT
    serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  Monitor-2: DP-2 note: disabled pos: center model: HS133PC built: 2020
    res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2 size: 294x166mm (11.57x6.54")
    diag: 338mm (13.3") ratio: 3:2, 4:3 modes: max: 1920x1080 min: 640x480
  Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left
    model: HP E202 serial: <filter> built: 2020 res: 1600x900 hz: 60 dpi: 92
    gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9
    modes: max: 1600x900 min: 640x480
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
    driver: Eco Capture alternate: MWEcoCapture pcie: gen: 2 speed: 5 GT/s
  Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.1 chip-ID: 10de:1aeb
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Kingston HyperX Cloud Alpha S
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 7-3:3 chip-ID: 0951:16ed class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-ac907f97584b state: down mac: <filter>
  IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-3: veth10b8c6c state: up speed: 10000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 494.88 GiB used: 349.67 GiB (70.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM13.0 temp: 36.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Cruzer Switch
    size: 29.11 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.27
    scheme: MBR
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 343.12 GiB (75.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 33.0 C mobo: 33.0 C
  Processes: 471 Uptime: 8m wakeups: 4 Memory: available: 15.53 GiB
  used: 3.4 GiB (21.9%) Init: systemd v: 253 default: graphical tool: systemctl
  Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1687 pm: dpkg pkgs: 0
  pm: pacman pkgs: 1675 libs: 432 tools: gnome-software,pacaur,pamac
  pm: flatpak pkgs: 5 pm: snap pkgs: 7 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.27
