Which version of U-Boot did you flashed?
BSP-uboot
Now back on standard and all runs as desired. But only after zeroeing out first part of the EMMC
I’m experiencing this issue too. I got my Pinebook Pro ANSI unit in yesterday and flashed the latest Manjaro KDE using manjaro-arm-installer
. Starting from a cold boot works just as it should, but rebooting causes this graphics artifacting without fail. It does so regardless of if it was booted from microSD or eMMC. I haven’t made any hardware modifications, or even opened the device up.
I actually took a video of the behavior:
Yes, I know. But which version exactly? 1.5 or 2.0?
Now I see that I’ve forgot to remove " at the end of every dd
command.
It looks exactly like what I’ve described.
I have an ANSI pinebook pro and I also see this issue.
Also:
If you boot from an SD card and then reboot
, you end up in the eMMC
I think that uboot is still running and it believes that the OS you are rebooting from failed to boot, so it launches the next priority boot.
So the only drawback of reverting to bsd uboot is that the suspend won’t work anymore right?
My system is running on an NVMe, starts from EMMC. I think there is no suspend possible ATM. Regardless off the U-Boot. PBP goes to sleep and wakes up after 6 seconds. Or is this solved by any U-Boot version?
I didn’t have any issues with suspend on any U-Boot. There is only a risk of possible bricking PBP during flashing U-Boot files to the eMMC module. If the U-Boot on the eMMC got corrupted it might not boot even from SD card, if you have a bad luck. Moreover the only person who knows what’s in this U-Boot is mrfixit2001 or the aliens/illuminati/reptilians (I’m not saying that mrfixit2001 is one of them, but I don’t know if he is the one who built it). But you will be able to boot any other OS (from the list https://wiki.pine64.org/index.php/Pinebook_Software_Release) and some of them will be able to power down PBP (with mainline U-Boot the previous default OS had problems with it, but I didn’t check it again, yet).
Err, with working s3, suspend 3(what dmesg calls it), s2ram, ~7%/d
s2idle is, oh say, 10-12 times worse, FWIW
And, the point, for s3 you MUST have bsp uboot and no nvme
(and the “right” kernel)
Perilous… Thanks for the info mate, you got me scared… I might just wait until there is an update which might fix the issue if enough people has the same problem. Until then, not use reboot…
PBP has much worse problems with charging than with suspend. It can drain more power than the power supply can provide, it stops or interrupt charging (which causes waking up from suspend after a few seconds) when the board temperature is over forty something Celsius, in the summer when there was over 30 degrees Celsius outside and simply turning on the PBP would cause it to stop charging or using the power supply.
Are these problems specific to a certain uboot?
IMO no,
the loading problem exists, the charger is absolutely HOT and no more power can be delivered.
These are the hardware problems but the blinking red LED next to DC-In is waking up PBP from suspend.
There are more hardware problems like, e.g. I can hear right channel on left channel and vice versa (it doesn’t matter on built-in speakers or on wired headphones), but it can be annoying maybe, the crosstalk between audio output and serial console could interpret loud noises as magic SysRq combinations, effect: random crashes on certain U-Boot and kernel configurations caused by cranked up to distortion sound output (source: Review of Pinebook Pro).
Hello,
Is your display issues resolved?
Latest updates from Manjaro done, display problem on startup are not fixed
Unfortunately not. I did’t install the bsp uboot tho…
Hey guys,
After using my PBP happily for months now it doesn’t boot anymore =(
Yesterday I installed latest updates (Manjaro KDE) via package manager - afterwards it felt a little sluggish so I decided to shut it down in the evening (to reboot the next day).
When I press the power button, the power LED is orange for a few seconds an then turns green - but the screen stays off. I noticed that I can press caps lock and num lock (fn+f10) and it toggles the appropriate LEDs.
I also tried booting from SD card (also Manjaro KDE) and at first it prompted me for system set up info (user name, pw, root pw, locale, tz etc) but then was just showing the Manjaro logo and a spinner for at least half an hour.
Any help much appreciated!
