Problem with switching keyboard layouts
Hi, I’m currently on Testing Branch, KDE Plasma everything should be up to date. I want to set up 2 keyboard layouts (EN and CZ) I can switch between under System Settings → Keyboard. When I do that, it works as expected (the 2nd layout is added, I can switch to it and use it) but the change doesn’t stay after restart, where it reverts to only having the EN layout available.
I found that when I click “configure” on the system tray keyboard icon, it brings up a KDialog saying that a fcitx module is missing, which I think might be connected. When I try to install fcitx-configtool (as the dialog instructs me), it wants to install fcitx4, which is in conflict with the currently installed fcitx5, so this probably isn’t the right solution.
Any idea how to fix this? Thanks
Update: So I managed to install the fcitx5-configtool (that was the correct name of the package) and I managed to set CZ as the primary layout. However, now CZ stays in System Settings → Keyboard and EN gets removed on restart. This is confusing…
Temporary solution found:
It’s apparently a bug and it was discussed for example here:
https://bbs.archlinux.org/viewtopic.php?id=284058
Making the config file immutable by “sudo chattr +i kxkbrc” helped, the layouts now stay as they should even after restart. But it obviously isn’t a permanent solution.
You can also set a key combination for this. I use SHIFT + CAPS-LOCK to switch between UK and Greek layouts; I sometimes need to use e.g. Ω (for electronics) which I can’t find using the Compose key.
System Settings → Keyboard → Key Bindings tab → Switching to another layout. There are a lot of options there; my particular choice is near the bottom.
