Hi everybody,
I got a strange problem when I try to suspend my T14. When powering it back on after suspend, the cursor of the password field blinks for about a second and then stops. The whole system is frozen, but the mouse cursor can still be moved. It’s also impossilble to change to tty2 or others. The only thing that helps is a hard reboot.
Some infos:
I’m running Manjaro with KDE. It’s a dualboot system with Windows 10, where everything is working fine. The two OS are installed on two different NVME drives. WIndows on the one that came with the laptop, Manjaro on a second one that I installed myself in the WWAN slot. Everything else is working fine, except for suspend.
What I observed so far:
I tried suspending on tty2 via systemctl suspend. After waking the machine up, everything was working fine for a few seconds, then I got a lot of input/output errors when trying to read the contents of the drive via ls (for some reason I can’t attach a picture). Trying shutting it down with systemctl or just changing directory with cd results in an “command not found” error. It seems like the drive isn’t powered up or something like that after suspend. There are also no error logs written at all, which would support my theory.
What I tried so far:
Adding different kernel parameters in GRUB like “ahcpi.disable=1” etc, pretty much everyone that seemed to be related to the problem according to Google. Of course I also changed the suspend options in the BIOS to Linux. I tried to install Manjaro GNOME, which resulted in the same behaviour.
And, last but not least, the output of inxi -Fazy
Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=d83ec6c6-e230-4bdd-8296-a2353423554b ro quiet apparmor=1
security=apparmor udev.log_priority=3 acpiphp.disable=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 20UES00L00 v: ThinkPad T14 Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20UES00L00 serial: <filter> UEFI: LENOVO
v: R1BET60W(1.29 ) date: 11/30/2020
ID-1: BAT0 charge: 44.9 Wh (87.2%) condition: 51.5/50.5 Wh (101.9%)
volts: 12.5 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: Discharging cycles: 9
Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 4 MiB
bogomips: 54318
Speed: 1397 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 08:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 2-2:2
chip-ID: 04f2:b6d0 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.10-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 08:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 08:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
vendor: Lenovo driver: r8169 v: kernel port: 3400 bus-ID: 02:00.0
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:3
Local Storage: total: 1.4 TiB used: 645.83 GiB (45.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: MZVLB1T0HBLR-000L7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 5M2QEXF7 temp: 31.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: PC SN520 SDAPMUW-512G size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter>
rev: 20250000 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 70.32 GiB (15.0%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 32.5 C mobo: 0.0 C gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): cpu: 0
Processes: 348 Uptime: 46m wakeups: 3 Memory: 14.93 GiB
used: 2.09 GiB (14.0%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1443 pacman: 1438 lib: 440 flatpak: 5
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
Does anybody have any idea how to fix this annyoing problem? Any help would be really appreciated! My current “workaround” is to only shut off the monitor when closing the laptop lid.
And thanks to everyone reading this thread!
