After last update i cant use sleep mode
PS:I checked on the snapshot that was made before the update everything works.
PS2:I saw that there is a special topic here for upgrade problems but I don’t know how to transfer the post there
You don’t.
You can check the logs.
journalctl --list-boots --no-pager
will list the boots, find a boot it happened and use that number, I will assume it was the last boot, ie -b -1
in the example. (boot 0 is the one you are running right now)
sudo journalctl -b -1 -p 3 --no-pager
Click the </> button here in the text box on the forum and paste the output from the commands.
Because I used snapshot, I can’t see the logs that were taken before the restore
Then it’s very hard to analyze.
I suggest this.
Make sure you can REISUB (follow this tutorial)
Then force the error by sleeping/waking up, do a REISUB and then check the logs.
Do this at your own risk though. But that would be the “softest” way I think.
Others on the forum, feel free to chip in with opinions.
After last update, all works good! Thanks developers!
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
