Hi everyone, I am having problems to be able to see my second screen, everything seems to be in order but it does not show the image, if anyone can help me i would appreciate it
these are my logs
inxi -v7azy ✔
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c228fe4e-a4d9-4775-b26d-e7394f09c3e7 rw quiet splash
resume=UUID=6e5a2a70-6426-466f-b3d4-4f81f049b7c7 udev.log_priority=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Alienware product: Alienware m15 Ryzen Ed. R5 v: 1.9.0
serial: <superuser required> Chassis: type: 10 v: 1.9.0
Mobo: Alienware model: 06W7NY v: A02 serial: <superuser required>
UEFI: Alienware v: 1.9.0 date: 11/10/2022
ID-1: BAT1 charge: 63.1 Wh (100.0%) condition: 63.1/86.0 Wh (73.4%)
volts: 12.5 min: 11.4 model: BYD 0x48,0x32,0x32,0x42,0x69,0x03,0x000D
type: Li-ion serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 14.98 GiB used: 2.59 GiB (17.3%)
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1862 high: 3300 min/max: 1200/4679 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2394 2: 2391
3: 1916 4: 1926 5: 1915 6: 1913 7: 3300 8: 1200 9: 2395 10: 1200 11: 2155
12: 1200 13: 1200 14: 1200 15: 2287 16: 1200 bogomips: 105444
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:24dd class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Dell driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 58.0 C
Device-3: USB C Video Adaptor type: USB driver: N/A bus-ID: 1-1.2:6
chip-ID: 25a4:9311 class-ID: 1100 serial: <filter>
Device-4: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:7 chip-ID: 0c45:672c class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 4480x1440 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-1-0 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 2560x1440 hz: 240 dpi: 189
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.12-1-MANJARO) direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel bus-ID: 1-1.1:4 v: kernel pcie: chip-ID: 223d:8971
class-ID: 0102 gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: VSG Gravity type: USB driver: snd-usb-audio
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Realtek RTL8125 2.5GbE vendor: Dell driver: r8169 v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8125
class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-3:5
Local Storage: total: 953.87 GiB used: 16.69 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41001131 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 30 GiB size: 29.36 GiB (97.87%) used: 13.87 GiB (47.3%)
fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
uuid: c228fe4e-a4d9-4775-b26d-e7394f09c3e7
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 16E8-D712
ID-3: /home raw-size: 65.71 GiB size: 64.12 GiB (97.59%)
used: 2.82 GiB (4.4%) fs: ext4 dev: /dev/nvme0n1p10 maj-min: 259:10
label: N/A uuid: 6824fb35-570a-48a1-876e-c1a668960411
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 6e5a2a70-6426-466f-b3d4-4f81f049b7c7
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: ESP
uuid: ACB0-CD1D
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 834.64 GiB fs: bitlocker
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.17 GiB fs: ntfs label: N/A
uuid: 64443972443947D6
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 16.25 GiB fs: ntfs label: Image
uuid: 047C38C57C38B372
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 1.4 GiB fs: ntfs
label: DELLSUPPORT uuid: 6C7E01857E0148F2
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-1:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 1-1.1:4 info: VSG Gravity type: Audio driver: snd-usb-audio
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 200mA chip-ID: 223d:8971
class-ID: 0102
Device-2: 1-1.2:6 info: USB C Video Adaptor type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 25a4:9311 class-ID: 1100
serial: <filter>
Device-3: 1-1.3:8 info: Apple USB DEVICE type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 05ac:0256 class-ID: 0301
Device-4: 1-2:3 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c53f class-ID: 0300
Device-5: 1-3:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-6: 1-4:7 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Alienware LED controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
chip-ID: 187c:0550 class-ID: 0300 serial: <filter>
Device-2: 3-4:3 info: Darfon type: Keyboard driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA chip-ID: 0d62:3740
class-ID: 0301
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 70.1 C mobo: N/A gpu: amdgpu temp: 63.0 C
Processes: 360 Uptime: 5m wakeups: 4 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 969 libs: 298 tools: gnome-software,pamac Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.25
mhwd -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.11.04 false PCI
