Hi,I’m testing 6.14-rc3 kernel , nvidia driver 570.86.16 witch close module. It looks like again problem with nvidia fbdev.
sudo cat /sys/module/nvidia_drm/parameters/fbdev
return No such file or directory
i use linux614-nvidia package witch nvidia_drm.modeset=1 nvidia_drm.fbdev=1 in grub (I know that these values should be used by default in the modern driver, but I still left them here)
some boot log and lsmod. Actually there are no errors, but I have additionally left it if that would be useful.
Sorry, can’t reproduce. I’ve been using the fbdev feature since it was first introduced and never had an issue.
EDIT: To clarify since you clarified, I meant I can’t reproduce on recent stable and LTS kernels–I have not tested 6.14-rcX. There may be bugs, it’s still an early release candidate.
Then neither Manjaro nor Arch can help you as you are in a completely unsupported configuration.
This topic will be temporarily hidden from the public. Anyone with the link can view it and users who subscribed to the topic will still receive notifications for replies.
Once you remove the Arch Testing repos, please provide more information for us to help you and the topic will be restored.
@Yochanan
I have already disabled all external repositories, rolled back versions of packages and rebooted the system, this did not change the situation.
I provided all the information about the kernel, video card and driver.
Is there anything else that will be useful?
do not report errors, except for xdg-portal error
Please don’t make me publish logs on pastebin, it will break my heart.
Perhaps the original text was misleading. The problem is only reproduced on current 6.14 rc kernel, I can use version 6.13 without problems but I need some changes from 6.14 kernel.
@Yochanan
You previously wrote that you cannot reproduce the problem. Did you use linux614-nvidia or nvidia-dkms? Could have added additional grub parameters besides nvidia_drm.modeset=1 nvidia_drm.fbdev=1 ? close or open module ?
I have tested the closed and open module, both lead to the same result
