Hello,
I have bought new monitor with upgrade to Monitor 4K Philips 288E2UAE/00 28’’ IPS 60Hz. (my previous monitor Full HD 144HZ no crashes, works good)
Everything works quite fine with new one, but now when I use my Android Studio and want to make let’s say massive operation like launch my phone and start the program or change entire Color Scheme to another on x11 screen freezes and I need to force to power off computer by button (it looks like it’s not fully compatible?) and on wayland program crashes
That was my topic one day, maybe it is related? Something was restarted because of monitor, crashes?
computer, linux info
Kernel: 6.4.16-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=758df14c-2163-4fe3-a0db-2a38fe4278d3 rw amd_pstate.enable=1
amd_pstate=guided iommu=pt amd_pstate=active amd_pstate.shared_mem=1 quiet
splash initcall_blacklist=acpi_cpufreq_init amd_pstate.enable=1
amd_pstate=guided iommu=pt amd_pstate.shared_mem=1 apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: HP product: HP Pavilion 15 Laptop PC v: N/A
Mobo: HP model: 88D0 v: 78.31 serial: <superuser required>
part-nu: 4H3T9EA#AKD uuid: <superuser required> UEFI: AMI v: F.23
date: 10/05/2022
ID-1: BAT0 charge: 37.7 Wh (96.9%) condition: 38.9/38.9 Wh (100.0%)
volts: 12.7 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 94
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1474 high: 4372 min/max: 400/4372 boost: enabled scaling:
driver: amd-pstate governor: schedutil cores: 1: 1114 2: 1529 3: 1269 4: 4372
5: 1114 6: 1114 7: 1114 8: 1114 9: 1114 10: 2618 11: 1114 12: 1114 13: 1543
14: 1114 15: 1114 16: 1114 bogomips: 57518
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 41.0 C
Device-2: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 30c9:000e class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 5760x2160 s-size: <missing: xdpyinfo>
Monitor-1: not-matched mapped: HDMI-A-0 pos: top-left res: 3840x2160
dpi: 157 size: 621x341mm (24.45x13.43") diag: 708mm (27.89") modes: N/A
Monitor-2: not-matched mapped: eDP pos: primary,bottom-r res: 1920x1080
hz: 60 dpi: 142 size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.52 6.4.16-5-MANJARO) device-ID: 1002:164c memory: 500 MiB
unified: no
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: C-Media Thronmax MDrill One Pro
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-2.2:4 chip-ID: 0d8c:0080 class-ID: 0300
API: ALSA v: k6.4.16-5-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8852
class-ID: 0280
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 0bda:2852
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 476.94 GiB used: 238.7 GiB (50.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 HFM512GD3JX013N size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS1 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 238.7 GiB (51.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 5 (default 60) cache-pressure: 50 (default 100)
zswap: yes compressor: zstd max-pool: 20%
ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 32 GiB note: est. available: 30.68 GiB used: 6.76 GiB (22.0%)
Processes: 466 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
image: 12.26 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1754 pm: pacman pkgs: 1749 libs: 506 tools: gnome-software,pamac
pm: flatpak pkgs: 5 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.33
cpupower frequency-info 1 ✘
analyzing CPU 4:
driver: amd-pstate
CPUs which run at the same hardware frequency: 4
CPUs which need to have their frequency coordinated by software: 4
maximum transition latency: 20.0 us
hardware limits: 400 MHz - 4.37 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 400 MHz and 4.37 GHz.
The governor "schedutil" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.27 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
AMD PSTATE Highest Performance: 255. Maximum Frequency: 4.37 GHz.
AMD PSTATE Nominal Performance: 105. Nominal Frequency: 1.80 GHz.
AMD PSTATE Lowest Non-linear Performance: 65. Lowest Non-linear Frequency: 1.11 GHz.
AMD PSTATE Lowest Performance: 24. Lowest Frequency: 400 MHz.
x11
kwi 09 23:28:30 chris-15 systemd-fstab-generator[300]: Failed to create unit file '/run/systemd/generator/swapfile.swap', as it already exists. Duplicate entr>
kwi 09 23:28:30 chris-15 (sd-exec-[293]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
kwi 09 23:28:29 chris-15 systemd-modules-load[323]: Failed to find module 'amd_pstate'
kwi 09 23:28:33 chris-15 bluetoothd[658]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
kwi 09 23:28:33 chris-15 kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
kwi 09 23:28:33 chris-15 kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
kwi 09 23:28:51 chris-15 gdm-password][1368]: gkr-pam: unable to locate daemon control file
kwi 09 23:28:53 chris-15 systemd[1409]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 203 and the job result is failed.
when switch to wayland
