Hi,
I got a really weird problem with my Logitech M705:
A few weeks ago the sensitivity of the scroll wheel just went insane. I’ll try to describe it as good as possible:
The scroll wheel has those little “bumps”, when you use it. Like to scroll one line, you turn the mouse wheel one bump. But now if I only touch the wheel lightly or if I move the mouse itself the scrolling starts. In VLC, when I try to cange the volume with the scrolling wheel, it changes about 40% at once, not only 5% like before. I hope you know what I mean
And now here’s the really weird thing: This only happens on my main Manjaro KDE install. I tried it with Windows 10, a live Manjaro KDE environment and even in a virtual machine with Manjaro Gnome, everything is working like it’s supposed to. And it only happens with that Logitech. I tried my wifes bluetooth mouse, and it was also working correctly.
Here’s the inxi output:
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=1b0606ac-4e2c-4117-91a4-6791c0563892 rw resume=/dev/nvme0n1p3
quiet apparmor=1 security=apparmor
resume=UUID=718df8d6-24f6-4d50-b89f-8deda9dc0ffe udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 20UES00L00 v: ThinkPad T14 Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20UES00L00 serial: <filter> UEFI: LENOVO
v: R1BET66W(1.35 ) date: 07/30/2021
ID-1: BAT0 charge: 49.3 Wh (95.7%) condition: 51.5/50.5 Wh (101.9%)
volts: 13.0 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: Charging cycles: 21
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech MK700 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 14.86 GiB used: 2.87 GiB (19.3%)
Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 4 MiB bogomips: 54304
Speed: 1396 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz):
1: 1396 2: 1397 3: 1483 4: 1399 5: 1407 6: 1397 7: 1629 8: 1396 9: 1425
10: 1417 11: 1436 12: 1692 13: 1619 14: 1863 15: 1767 16: 1538
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 08:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 2-2:2
chip-ID: 04f2:b6d0 class-ID: fe01 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: DisplayPort-3 res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 08:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 08:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: BEHRINGER UMC404HD 192k type: USB driver: snd-usb-audio
bus-ID: 6-1.3:6 chip-ID: 1397:0509 class-ID: fe01
Device-5: Lenovo ThinkPad Dock USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 6-1.4.4:10
chip-ID: 17ef:306f class-ID: 0300
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3400 bus-ID: 02:00.0
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 5.95 TiB used: 2.78 TiB (46.7%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: MZVLB1T0HBLR-000L7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 5M2QEXF7 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: PC SN520 SDAPMUW-512G size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 20250000 temp: 45.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST5000DM000-1FK178 size: 4.55 TiB block-size: physical: 4096 B
logical: 4096 B type: HDD rpm: 5980 serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: SDRW-08U7M-U rev: A101
dev-links: cdrom
ID-1: / raw-size: 789.07 GiB size: 775.69 GiB (98.30%)
used: 306.79 GiB (39.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:8
label: N/A uuid: 1b0606ac-4e2c-4117-91a4-6791c0563892
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7
label: NO_LABEL uuid: 2BDD-CC73
ID-3: /run/media/florian/INTENSO raw-size: 4.55 TiB size: 4.55 TiB (100.00%)
used: 2.37 TiB (52.1%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: INTENSO
uuid: 943CCBC23CCB9E1C
ID-4: /run/media/florian/Win10 raw-size: 475.74 GiB
size: 475.74 GiB (100.00%) used: 110.3 GiB (23.2%) fs: ntfs
dev: /dev/nvme1n1p4 maj-min: 259:4 label: N/A uuid: 76E8810EE880CE35
ID-1: swap-1 type: partition size: 16.43 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:9 label: N/A
uuid: 718df8d6-24f6-4d50-b89f-8deda9dc0ffe
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: Wiederherstellung uuid: A40A720A0A71D9AE
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 1673-4285
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p5 maj-min: 259:5 size: 580 MiB fs: ntfs label: N/A
uuid: 0612415712414D3D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 2-2:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6d0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 4-1:2 info: Lenovo USB Billboard type: Billboard,HID
power: 100mA chip-ID: 17ef:3076 class-ID: 0300 serial: <filter>
Device-2: 4-3:3 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-7: 6-1:2 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 17ef:3073 class-ID: 0900
Device-1: 6-1.2:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 6-1.3:6 info: BEHRINGER UMC404HD 192k type: Audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-8: 6-1.4:7 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-9: 6-1.4.2:8 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 6-1.4.2.4:11 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E
SATA 6Gb/s bridge ASM1153 SATA 3Gb/s bridge ASM1153E SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Device-2: 6-1.4.3:9 info: MediaTek Slim Portable DVD Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0e8d:1887 class-ID: 0802
serial: <filter>
Device-3: 6-1.4.4:10 info: Lenovo ThinkPad Dock USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 17ef:306f class-ID: 0300
Device-4: 6-3:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Hub-10: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 52.6 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): fan-1: 2900
Processes: 359 Uptime: 39m wakeups: 14 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1434 pacman: 1430 lib: 397
flatpak: 4 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
Your help is really appreciated, since this is a really annoying problem
Thank you!
