I am on unstable using Plasma.
This could be due to the latest update but I don’t see anyone talking about it.
After logging in and about after a minute or so the panel becomes unresponsive.
Cannot right click on the desktop either.
I have run the following command from the command line and then the panel starts working correctly.
systemctl restart sddm
Host: manjaro Kernel: 5.19.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.28 date: 07/14/2022
ID-1: BAT0 charge: 67.5 Wh (100.0%) condition: 67.5/67.5 Wh (100.0%)
volts: 13.1 min: 11.6 model: HP Primary type: Li-ion serial: SerialNumber
status: full cycles: 178
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB
L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 3275 high: 3602 min/max: 400/4900 cores: 1: 3602
2: 2300 3: 3600 4: 3600 5: 3602 6: 3600 7: 3600 8: 2300 bogomips: 36812
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 515.76 arch: Pascal pcie: speed: 2.5 GT/s lanes: 4
bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: 200901010001
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: AU Optronics 0x30eb res: 1920x1080 hz: 60
dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0401
Sound API: ALSA v: k5.19.14-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: 0c:dd:24:ab:82:13
Local Storage: total: 931.51 GiB used: 184.84 GiB (19.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: S59ANS0N809758J rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-1: / size: 234.94 GiB used: 47.12 GiB (20.1%) fs: ext4
dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 96 MiB used: 68.8 MiB (71.6%) fs: vfat
dev: /dev/nvme0n1p2
ID-3: /home size: 319.4 GiB used: 137.66 GiB (43.1%) fs: ext4
dev: /dev/nvme0n1p7
System Temperatures: cpu: 64.0 C pch: 60.0 C mobo: N/A
Processes: 237 Uptime: 17m wakeups: 1115 Memory: 15.26 GiB used: 2.58 GiB
(16.9%) Init: systemd v: 251 default: graphical Compilers: gcc: 12.2.0
clang: 14.0.6 Packages: 1603 pm: pacman pkgs: 1597 pm: flatpak pkgs: 6
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
KDE Plasma Version: 5.25.5
KDE Frameworks Version: 5.98.0
Qt Version: 5.15.6
Kernel Version: 5.19.14-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-10510U CPU @ 1.80GHz
Memory: 15.3 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics
Manufacturer: HP
Product Name: HP Spectre x360 Convertible 15-df1xxx
