2021/07/29 11:55:21.782111 system_key.go:129: cannot determine nfs usage in
generateSystemKey: cannot parse /etc/fstab: expected between 3 and 6 fields, found 1
/var/lib/snapd/snap/code/70/command-code.wrapper: line 2: /snap/code/70/electron-launch: No
such file or directory
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=B6F4-3B3C /boot/efi vfat umask=0077 0 2
UUID=16817bea-e6bc-4c71-8ad3-f681a4deeb09 / ext4 defaults,noatime 0 1
�a:q
LABEL=E /mnt/E auto nosuid,nodev,nofail,x-gvfs-show 0 0
this is cat /etc/fstab
I removed that part that you said now the error shrank to
btw, this file (/snap/code/70/electron-launch) does exist!
