i just switched from ubuntu to manjaro, and i’m very happy of all of the new things i’m discovering !
However, i really like to have different colored folders, it helps me organizing my stuff.
So I got the package “folder-color-nautilus” but it doesn’t work… It was properly installed, but when i right-click on a folder and i choose the color, nothing happens. I also tried to install “folder-color-bzr” but the installation failed with the error “./common.sh not found”.
Do you have any tip on that ? Maybe another way to change the color of folders ?
I noticed something about the “Desktop Icons NG” as well, and it is in the community repository:
$ pamac search desktop icons
gnome-shell-extension-desktop-icons-ng 47-1 community
A fork from the official desktop icons project, with several enhancements like Drag'n'Drop.
So you could always try replacing gnome-shell-extension-desktop-icons with it:
To check if it’s installed globally, it should be listed when you execute:
ls /usr/share/gnome-shell/extensions/
To check if the extension is installed for the current user it should be listed when you do:
ls ~/.local/share/gnome-shell/extensions/
To check if it’s enabled, it should be listed when you execute:
gsettings get org.gnome.shell enabled-extensions
It also might be that it doesn’t work even if it is installed due to a version incompatibility, and if that’s the case, I think you’re kind of out of luck. But I’m no expert and I might be wrong.
Thank you a lot for the details ! The extension is indeed listed everywhere you pointed (under the name “ding” ). It’s installed globally, for the current user and it’s enabled.
So i’m beginning to think i’m out of luck… That’s a shame because it worked on ubuntu right out of the box, and it also work on my gaming PC which is on garuda (gnome). So i really don’t understand what is wrong.
Yep, I entered this command, still the same.
However, i got this message when i launch nautilus in the terminal
nautilus
libgvfscommon.so: cannot open shared object file: No such file or directory
Failed to load module: /usr/lib/gio/modules/libgioremote-volume-monitor.so
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
