Hi All,
I’ve been using Manjaro cinnamon for a couple of weeks now and everything is running fine. I installed DropBox (ver 214.4.5217) from the AUR and for the most part it is working as expected.
However, when the PC wakes from sleep mode I don’t get the blue syncing symbol when new files are being sent to the dropbox folder but the new file is bring sent to dropbox. If I open dropbox in a browser the new files are there so the actual process of syncing is working. The main problem is that if I click on the dropbox icon it closes the application and I have to re-start it.
Once restarted everything is as expected until the machine goes to sleep and the problem re-occurs when it wakes up.
Thanks for reading.
Details of machine are as follows:
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
Desktop: Cinnamon v: 6.4.6 tk: GTK v: 3.24.43 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.32.0
Mobo: ASUSTeK model: TUF GAMING B650-PLUS v: Rev 1.xx serial: <superuser required> part-nu: SKU
uuid: <superuser required> UEFI: American Megatrends v: 2613 date: 04/12/2024
Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse serial: <filter> charge: 100%
(should be ignored) rechargeable: yes status: discharging
Info: 8-core model: AMD Ryzen 7 7700 bits: 64 type: MT MCP smt: enabled arch: Zen 4 rev: 2 cache:
L1: 512 KiB L2: 8 MiB L3: 32 MiB
Speed (MHz): avg: 5065 min/max: 545/5389 boost: enabled cores: 1: 5065 2: 5065 3: 5065 4: 5065
5: 5065 6: 5065 7: 5065 8: 5065 9: 5065 10: 5065 11: 5065 12: 5065 13: 5065 14: 5065 15: 5065
16: 5065 bogomips: 121637
Device-1: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK driver: amdgpu v: kernel
arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: Writeback-1
bus-ID: 0b:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 41.0 C
Display: x11 server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4520x1920 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-l model: AOC CU34G2XP
serial: <filter> res: mode: 3440x1440 hz: 180 scale: 100% (1) dpi: 110
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: top-right model: BenQ GC2870 serial: <filter> res:
mode: 1920x1080 hz: 60 scale: 177% (0.5625) to: 1080x1920 dpi: 79 size: 621x341mm (24.45x13.43")
diag: 708mm (27.9") modes: max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi raphael_mendocino LLVM 19.1.7 DRM
3.59 6.12.11-1-MANJARO) device-ID: 1002:164e
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 0b:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: 5 GT/s
lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
Local Storage: total: 2.73 TiB used: 307.06 GiB (11.0%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT2000P3PSSD8 size: 1.82 TiB speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 30.9 C scheme: GPT
ID-2: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-1: / size: 1.79 TiB used: 307.06 GiB (16.8%) fs: ext4 dev: /dev/dm-0
mapped: luks-1b6e5f90-d43a-4518-8085-7c05fe118f13
ID-2: /boot/efi size: 299.4 MiB used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s lanes: 1
Device-1: 1-11:2 info: ASUSTek AURA LED Controller type: HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1 speed: 20 Gb/s lanes: 2 chip-ID: 1d6b:0003
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
Hub-4: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
Hub-6: 5-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1
power: 100mA chip-ID: 174c:2074 class-ID: 0900
Hub-7: 5-1.2:4 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1
Device-1: 5-1.2.1:6 info: Elgato Systems GmbH Stream Deck MK.2 type: HID driver: usbfs
interfaces: 1 rev: 2.0 speed: 480 Mb/s lanes: 1 power: 500mA chip-ID: 0fd9:0080 class-ID: 0300
serial: <filter>
Hub-8: 5-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 100mA
Device-1: 5-2.2:5 info: Xenta Gaming Mouse type: mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 1d57:ad17 class-ID: 0301
Device-2: 5-2.4:7 info: Logitech Lightspeed Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
Hub-10: 6-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0 speed: 5 Gb/s lanes: 1
power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-11: 6-1.2:4 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0 speed: 5 Gb/s lanes: 1
Hub-12: 6-2:3 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s lanes: 1
chip-ID: 05e3:0626 class-ID: 0900
Hub-13: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s lanes: 1
Device-1: 7-1:2 info: Cooler Master CK530 V2 Gaming Mechanical Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA
chip-ID: 2516:0147 class-ID: 0300
Hub-14: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0 speed: 5 Gb/s lanes: 1
System Temperatures: cpu: 45.4 C mobo: 28.8 C gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Packages: 1384 pm: pacman pkgs: 1376 pm: flatpak pkgs: 8
1: https: //mirror.bouwhuis.network/manjaro/stable/$repo/$arch
2: https: //manjaro.ynh.ovh/stable/$repo/$arch
3: https: //mirrors.sonic.net/manjaro/stable/$repo/$arch
Memory: total: 16 GiB note: est. available: 14.84 GiB used: 7.24 GiB (48.8%)
Processes: 373 Power: uptime: 4d 23h 29m states: freeze,mem,disk suspend: deep wakeups: 14
hibernate: platform Init: systemd v: 257 default: graphical
Compilers: clang: 19.1.7 gcc: 14.2.1 Client: Cinnamon v: 6.4.6 inxi: 3.3.37
