Problem with display after mesa update
Hi there,
Updating following packages causes some weird graphics problems:
 -> llvm: ignoring package upgrade (19.1.7-2 => 20.1.6-3)
 -> llvm-libs: ignoring package upgrade (19.1.7-2 => 20.1.6-3)
 -> mesa: ignoring package upgrade (1:25.0.5-1 => 1:25.1.4-1)
 -> mesa-utils: ignoring package upgrade (9.0.0-5 => 9.0.0-7)
➜ inxi -zv8
  Kernel: 6.6.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=8ff6e906-aa06-4799-964b-246d929defce rw quiet splash
    udev.log_priority=3
  Desktop: i3 v: 4.24 with: polybar tools: xss-lock
    avail: light-locker,swayidle,swaylock vt: 7 dm: 1: LightDM v: 1.32.0 2: SDDM
    note: stopped Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 20QQS0JD01 v: ThinkPad P53
  Mobo: LENOVO model: 20QQS0JD01 v: SDK0J40697 WIN
    serial: <superuser required>
    part-nu: LENOVO_MT_20QQ_BU_Think_FM_ThinkPad P53
    uuid: <superuser required> UEFI: LENOVO v: N2NET58W (1.43 )
    date: 11/21/2023
  ID-1: BAT0 charge: 78.8 Wh (99.1%) condition: 79.5/90.0 Wh (88.4%)
    volts: 12.7 min: 11.2 model: SMP 5B10W13901 type: Li-poly serial: <filter>
    status: not charging cycles: 240
  Device-1: hid-0003:17EF:60EE.0005-battery model: Lenovo TrackPoint
    Keyboard II serial: N/A charge: N/A status: N/A
  Device-2: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
    status: discharging
  System RAM: total: 64 GiB available: 62.42 GiB used: 11.15 GiB (17.9%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: spec: 3200 MT/s actual: 2667 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron part-no: 16ATF2G64HZ-3G2J1
    serial: <filter>
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 16 GiB
    serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    serial: <filter>
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 16 GiB
    serial: <filter>
  Info: model: Intel Core i7-9850H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x104
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx sgx_lc smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: disabled;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU106GLM [Quadro RTX 3000 Mobile / Max-Q] vendor: Lenovo
    driver: nouveau v: kernel non-free: 550-570.xx+ status: current (as of
    2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: DP-5,HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, DP-6, eDP-2
    bus-ID: 01:00.0 chip-ID: 10de:1f36 class-ID: 0300 temp: 42.0 C
  Device-3: Bison SunplusIT Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 5986:2113
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: Picom v: 12.5 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris,nouveau gpu: i915,nouveau display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 5760x1200 s-dpi: 96 s-size: 1520x316mm (59.84x12.44")
    s-diag: 1552mm (61.12")
  Monitor-1: DP-5 mapped: DP-1-1-2 pos: right model: Fujitsu Siemens B24W-7
    LED serial: <filter> built: 2017 res: mode: 1920x1200 hz: 60
    scale: 100% (1) dpi: 94 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
    x: 0.302 y: 0.635 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-1-1 pos: center model: NEC EA244WMi
    serial: <filter> built: 2014 res: mode: 1920x1200 hz: 60 scale: 100% (1)
    dpi: 94 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.302 y: 0.635
    size: 519x324mm (20.43x12.76") diag: 612mm (24.1") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1680x1050, 1400x1050, 1280x1024, 1440x900,
    1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x480, 640x480
  Monitor-3: eDP-1 pos: primary,left model: ChiMei InnoLux 0x15e8
    built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
    chroma: red: x: 0.651 y: 0.337 green: x: 0.314 y: 0.600 blue: x: 0.153
    y: 0.047 white: x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b memory: 30.48 GiB unified: yes
    de: kscreen-console,kscreen-doctor wl: swaymsg, wayland-info, wlay
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-3: Lenovo ThinkPad Thunderbolt 3 Dock Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 7-1:2 chip-ID: 17ef:306a class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.94-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 52:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp82s0 state: up mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0029
    class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter> status:
    discoverable: no active: no pairing: yes class-ID: 6c010c
  Local Storage: total: 2.1 TiB used: 440.45 GiB (20.5%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Samsung model: EE8QT
    size: 238.5 GiB block-size: physical: 512 B logical: 512 B type: Removable
    tech: SSD serial: <filter> scheme: MBR
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S1024G
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 40.9 C
    scheme: GPT
  ID-3: /dev/nvme1n1 maj-min: 259:9 vendor: Western Digital model: PC SN730
    SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 11170101 temp: 46.9 C scheme: GPT
  ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 24.52 GiB (62.8%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 8ff6e906-aa06-4799-964b-246d929defce
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 8098-8A9B
  ID-3: /home raw-size: 602.93 GiB size: 592.4 GiB (98.25%)
    used: 124.9 GiB (21.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: 7468d676-d264-40f8-8572-f5ea31cf993c
  ID-4: /run/media/adrian/backup raw-size: 953.87 GiB
    size: 937.83 GiB (98.32%) used: 291.03 GiB (31.0%) fs: ext4
    dev: /dev/nvme1n1p1 maj-min: 259:10 label: backup
    uuid: a3fccaef-c2ab-42cf-b7fa-c69da1518c4f
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 7573bd78-5a9d-42d2-9b95-da603cea2313
  ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 238.5 GiB fs: ntfs label: sdcard
    uuid: 280F76084ABEC301
  ID-2: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: AAEA-49C4
  ID-3: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 203.68 GiB fs: ntfs label: N/A
    uuid: 10D6EBE1D6EBC4D6
  ID-5: /dev/nvme0n1p8 maj-min: 259:8 size: 98.15 GiB fs: ntfs label: N/A
    uuid: 4AC0EB8507B7B6B1
  Device-1: 1-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-6:3 info: Lenovo TrackPoint Keyboard II
    type: keyboard,mouse,HID driver: lenovo,usbhid interfaces: 3 rev: 2.0
    chip-ID: 17ef:60ee class-ID: 0300
  Device-3: 1-8:4 info: Bison SunplusIT Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 5986:2113 class-ID: 0e02
  Device-4: 1-9:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-5: 1-14:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 7-1:2 info: Lenovo ThinkPad Thunderbolt 3 Dock Audio
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 17ef:306a class-ID: 0300 serial: <filter>
  Device-2: 7-4:3 info: Lenovo ThinkPad Thunderbolt 3 Dock MCU type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 17ef:3066 class-ID: 0300
    serial: <filter>
  Hub-8: 8-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-10: 10-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 57.0 C pch: 67.0 C mobo: N/A gpu: nouveau
    temp: 42.0 C
  Fan Speeds (rpm): fan-1: 2555 fan-2: 2214
  Packages: pm: pacman pkgs: 1827 libs: 410 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    4: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 401
  1: cpu: 18.3% command: firefox pid: 10024 mem: 608.3 MiB (0.9%)
  2: cpu: 7.8% command: librewolf pid: 1074 mem: 595.8 MiB (0.9%)
  3: cpu: 6.8% command: firefox pid: 10181 mem: 326.0 MiB (0.5%)
  4: cpu: 3.9% command: quodlibet started-by: python pid: 1069
    mem: 144.8 MiB (0.2%)
  5: cpu: 3.3% command: thunderbird pid: 1068 mem: 529.5 MiB (0.8%)
  Memory top: 5 of 401
  1: mem: 798.6 MiB (1.2%) command: librewolf pid: 2935 cpu: 2.8%
  2: mem: 608.3 MiB (0.9%) command: firefox pid: 10024 cpu: 18.3%
  3: mem: 595.8 MiB (0.9%) command: librewolf pid: 1074 cpu: 7.8%
  4: mem: 574.7 MiB (0.8%) command: anki started-by: python3 pid: 1066
    cpu: 0.2%
  5: mem: 529.5 MiB (0.8%) command: thunderbird pid: 1068 cpu: 3.3%
  Processes: 401 Power: uptime: 36m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.95 GiB services: power-profiles-daemon
  Compilers: clang: 20 gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: kitty
    inxi: 3.3.38
With new packages external monitors stop working and on the built-in laptop screen I can only run some basic apps (like Uxterm for example). Do I have any other options than downgrading these package and ignoring them for update? Will it make any package integrity problems in the future? Maybe trying mesa-git could help?
I’ve already tried to use nvidia proprietary drivers and it works but I won’t detect my dock connected monitor for whatever reason.
I am really no expert on Nvidia; from your hardware info it appears the system is uing the nouveau driver for Nvidia - and I do know this is not optimal for Nvidia Quadro 3xxx.
I would think the video-hybrid-intel-nvidia-prime would be the right choice
You check if this is installed by running
mhwd -li
If the driver is not listed as installed you can install it
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
It is well known - painfully well known - Linux and Nvidia is not a good match - it has been proved over the years.
//EDIT:
As noted below - you experience may vary - just generally speaking.
Have you tried the open source Nvidia drivers?
I think it depends more on the specific hardware. From what I have read, on the Manjaro forums at least, most NVIDIA issues tend to be associated with discrete NVIDIA + integrated CPU graphics. From personal experience, a discrete NVIDIA GPU + an Intel CPU without integrated graphics works fine.
