Problem with boot partition Acer Aspire 5742G
Alright. Nothing detected. Is there anything mounted?
mount -t ext4
mount -t vfat
PS: Would be so kind to edit your last 3 posts and merge them into one if possible? That would make much readable for the future. Thank you.
Yes where the home folder in the screenshot attached above. (Only this partition stays connected)I have no way to disconnect it
[manjaro manjaro]# mount -t vfat
/dev/sda3 on /run/media/manjaro/50EC-367D type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
also post output from:
but it looks like you are chrooted…
Please open dolphin, mount the partitions and report back what folders structure is presented there. Look for a file which is called fstab in the folder etc. The content of that text file I was looking for.
You said, your “boot partition” was corrupted. Do you mean the root or the efi partition? Because a boot partition is something else.
You can check a filesystem (of course it has to be NOT mounted), with:
sudo fsck.ext4 -f -n /dev/sda2
That only checks it by force, but does not repair anything.
That will repair it:
sudo fsck.ext4 -f -y /dev/sda2
You have to look at the output of lsblk to see the devices/partitions. sda2 is like → SCSI Device A Partition 2
Nothing happend. Thats looks good.
[manjaro manjaro]# mount -t ext4
[manjaro manjaro]#
[manjaro manjaro]# sudo fsck.ext4 -f -n /dev/sda2
e2fsck 1.47.0 (5-Feb-2023)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sda2: 2120/19202048 files (1.8% non-contiguous), 3230942/76804096 blocks
[manjaro manjaro]# sudo fsck.ext4 -f -y /dev/sda2
/lost+found not found.  Create? yes
Pass 3A: Optimizing directories
/dev/sda2: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sda2: 2121/19202048 files (1.8% non-contiguous), 3230940/76804096 blocks
[manjaro manjaro]# lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0    7:0    0    93M  1 loop /run/miso/sfs/livefs
loop1    7:1    0 867.5M  1 loop /run/miso/sfs/mhwdfs
loop2    7:2    0   1.9G  1 loop /run/miso/sfs/desktopfs
loop3    7:3    0 921.4M  1 loop /run/miso/sfs/rootfs
sda      8:0    0 931.5G  0 disk
├─sda1   8:1    0   512M  0 part
├─sda2   8:2    0   293G  0 part
├─sda3   8:3    0    16G  0 part /run/media/manjaro/50EC-367D
├─sda4   8:4    0   300G  0 part
├─sda5   8:5    0   322G  0 part
└─sda6   8:6    0    56M  0 part
sdb      8:16   1  29.8G  0 disk /run/miso/bootmnt
├─sdb1   8:17   1   3.8G  0 part
└─sdb2   8:18   1     4M  0 part
sr0     11:0    1  1024M  0 rom
Sorry I haven’t written back because I got blocked for 5 hours due to too many messages
[manjaro manjaro]# pacman-mirrors -f 5 && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.559 France         : https://manjaro.ynh.ovh/
  0.526 Germany        : https://mirror.netcologne.de/manjaro/
  0.505 Austria        : https://mirror.easyname.at/manjaro/
  0.295 Global         : https://mirrors.manjaro.org/repo/
  2.326 Brazil         : https://mirror.ufam.edu.br/manjaro/
::INFO Writing mirror list
::Global          : https://mirrors.manjaro.org/repo/stable
::Austria         : https://mirror.easyname.at/manjaro/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::France          : https://manjaro.ynh.ovh/stable
::Brazil          : https://mirror.ufam.edu.br/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                                  141.1 KiB   191 KiB/s 00:01 [####################################] 100%
 extra                                1640.5 KiB  3.95 MiB/s 00:00 [####################################] 100%
 community                               6.8 MiB  3.92 MiB/s 00:02 [####################################] 100%
 multilib                              145.2 KiB  1497 KiB/s 00:00 [####################################] 100%
resolving dependencies...
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
warning: mhwd-nvidia will be installed before its mhwd dependency
warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Packages (562) accountsservice-23.13.9-1  adobe-source-code-pro-fonts-2.042u+1.062i+1.026vf-1
               adobe-source-sans-fonts-3.052-1  alsa-firmware-1.2.4-3  alsa-oss-1.1.8-5
               alsa-plugins-1:1.2.7.1-2  alsa-topology-conf-1.2.5.1-3  amd-ucode-20230404.2e92a49f-1
               appstream-0.16.1-2  appstream-glib-0.8.2-2  appstream-qt-0.16.1-2
               archlinux-appstream-data-20230421-1  ark-23.04.0-1  at-spi2-core-2.48.0-2  attica-5.105.0-1
               attr-2.5.1-3  audiocd-kio-23.04.0-1  audit-3.1-1  baloo-5.105.0-1  baloo-widgets-23.04.0-1
               bluedevil-1:5.27.4-1  bluez-qt-5.105.0-1  breeze-5.27.4-1  breeze-gtk-5.27.4-2.1
               breeze-icons-5.105.0-1  brotli-1.0.9-10  btrfs-progs-6.2.2-1  bubblewrap-0.8.0-1
               ca-certificates-mozilla-3.89-1  calamares-3.2.62-1  chromaprint-1.5.1-7  cifs-utils-7.0-3
               ckbcomp-1.215-1  clang-15.0.7-2  clinfo-3.0.21.02.21-1  cmus-2.10.0-4  coreutils-9.3-1
               cpupower-6.2-1  cracklib-2.9.11-1  cryptsetup-2.6.1-3.2  cups-1:2.4.2-6
               cups-filters-1.28.17-2  curl-8.0.1-1  cython-0.29.34-1  dav1d-1.1.0-1  dbus-1.14.6-2
               dbus-python-1.2.18-4  device-mapper-2.03.21-1  dmidecode-3.5-1  dolphin-23.04.0-2
               dolphin-plugins-23.04.0-1  efibootmgr-18-2  efivar-38-3  egl-wayland-2:1.1.11-4
               elisa-23.04.0-1  enchant-2.3.4-1  f2fs-tools-1.16.0-1  faac-1.30-4  ffmpeg-2:6.0-5
               ffmpeg4.4-4.4.3-2  ffmpegthumbs-23.04.0-1  fftw-3.3.10-4  file-5.44-3  filelight-23.04.0-1
               filesystem-2023.03.21-1  findutils-4.9.0-3  firefox-113.0-0.1  flatpak-1:1.15.4-1
               fluidsynth-2.3.2-1  foomatic-db-3:20230402-1  foomatic-db-nonfree-3:20230402-1
               foomatic-db-nonfree-ppds-3:20230402-1  foomatic-db-ppds-3:20230402-1
               frameworkintegration-5.105.0-1  fuse-common-3.14.1-1  fuse3-3.14.1-1  fwupd-1.8.14-1
               fzf-0.39.0-1  gawk-5.2.1-2  gdbm-1.23-2  gettext-0.21.1-5  ghostscript-10.01.1-1  git-2.40.1-1
               glib-networking-1:2.76.0-1  glib2-2.76.1-1  glibmm-2.66.6-1  glslang-12.1.0-1  gnupg-2.2.41-1
               gnutls-3.8.0-1  gobject-introspection-runtime-1.76.1-1  gparted-1.5.0-1  gperftools-2.10-1
               gpgme-1.20.0-1  grep-3.10-1  groff-1.22.4-10  grub-2.06.r499.ge67a551a4-2
               grub-theme-live-common-20.2-15  grub-theme-live-manjaro-20.2-15  grub-theme-manjaro-20.2-15
               gsettings-desktop-schemas-44.0-1  gsfonts-20200910-3  gst-libav-1.22.1-2
               gst-plugins-bad-1.22.1-2  gst-plugins-bad-libs-1.22.1-2  gst-plugins-base-1.22.1-2
               gst-plugins-base-libs-1.22.1-2  gst-plugins-good-1.22.1-2  gst-plugins-ugly-1.22.1-2
               gstreamer-1.22.1-2  gtk-update-icon-cache-1:4.10.3-1  gtk3-1:3.24.37-1  gupnp-igd-1.6.0-1
               gwenview-23.04.0-1  harfbuzz-7.1.0-1  harfbuzz-icu-7.1.0-1  hicolor-icon-theme-0.17-3
               hidapi-0.13.1-2  highway-1.0.4-1  hwdata-0.369-1  hwloc-2.9.1-1  iana-etc-20230405-1
               imagemagick-7.1.1.8-1  imath-3.1.7-1  imlib2-1.11.0-1  inetutils-2.4-1  intel-ucode-20230214-1
               inxi-3.3.27.1-1  iproute2-6.2.0-2  iso-codes-4.13.0-1  kaccounts-integration-23.04.0-1
               kaccounts-providers-23.04.0-1  kactivities-5.105.0-1  kactivities-stats-5.105.0-1
               kactivitymanagerd-5.27.4-1  kamera-23.04.0-1  karchive-5.105.0-1  kate-23.04.0-1
               kauth-5.105.0-1  kbookmarks-5.105.0-1  kcalc-23.04.0-1  kcmutils-5.105.0-1  kcodecs-5.105.0-1
               kcompletion-5.105.0-1  kconfig-5.105.0-1  kconfigwidgets-5.105.0-1  kcontacts-1:5.105.0-1
               kcoreaddons-5.105.0-1  kcrash-5.105.0-1  kdbusaddons-5.105.0-1  kde-cli-tools-5.27.4-1
               kde-gtk-config-5.27.4-1  kdeclarative-5.105.0-1  kdeconnect-23.04.0-1  kdecoration-5.27.4-1
               kded-5.105.0-1  kdegraphics-mobipocket-23.04.0-1  kdegraphics-thumbnailers-23.04.0-1
               kdelibs4support-5.105.0-1  kdenetwork-filesharing-23.04.0-1  kdeplasma-addons-5.27.4-1
               kdesu-5.105.0-1  kdnssd-5.105.0-1  kdoctools-5.105.0-1  keditbookmarks-23.04.0-1
               kemoticons-5.105.0-1  kfilemetadata-5.105.0-1  kfind-23.04.0-1  kgamma5-5.27.4-1
               kglobalaccel-5.105.0-1  kguiaddons-5.105.0-1  khelpcenter-23.04.0-1  kholidays-1:5.105.0-1
               khotkeys-5.27.4-1  khtml-5.105.0-1  ki18n-5.105.0-1  kiconthemes-5.105.0-1
               kidletime-5.105.0-1  kimageannotator-0.6.1-1  kimageformats-5.105.0-1  kinfocenter-5.27.4-1
               kinit-5.105.0-1  kio-5.105.0-1  kio-extras-23.04.0-1  kirigami-addons-0.8.0-1
               kirigami2-5.105.0-1  kitemmodels-5.105.0-1  kitemviews-5.105.0-1  kjobwidgets-5.105.0-1
               kjs-5.105.0-1  kmenuedit-5.27.4-1  knewstuff-5.105.0-1  knotifications-5.105.0-1
               knotifyconfig-5.105.0-1  konsole-23.04.0-1  kpackage-5.105.0-1  kparts-5.105.0-1
               kpeople-5.105.0-1  kpipewire-5.27.4-1  kpmcore-23.04.0-1  kpty-5.105.0-1
               kquickcharts-5.105.0-1  krunner-5.105.0-1  ksanecore-23.04.0-1  kscreen-5.27.4-1
               kscreenlocker-5.27.4-1  kservice-5.105.0-1  ksshaskpass-5.27.4-1  ksystemlog-23.04.0-1
               ksystemstats-5.27.4-1  ktexteditor-5.105.0-1  ktextwidgets-5.105.0-1
               kunitconversion-5.105.0-1  kwallet-5.105.0-1  kwallet-pam-5.27.4-1  kwalletmanager-23.04.0-1
               kwayland-5.105.0-1  kwayland-integration-5.27.4-1  kwidgetsaddons-5.105.0-1  kwin-5.27.4.1-1
               kwindowsystem-5.105.0-1  kwrited-5.27.4-1  kxmlgui-5.105.0-1  l-smash-2.14.5-3
               layer-shell-qt-5.27.4-1  lcms2-2.15-1  ldb-2:2.7.2-1  lib32-curl-8.0.1-1  lib32-dbus-1.14.6-2
               lib32-libcap-2.68-1  lib32-libdrm-2.4.115-1  lib32-libelf-0.189-1  lib32-libgcrypt-1.10.2-1
               lib32-libldap-2.6.4-1  lib32-libltdl-2.4.7-3  lib32-libpsl-0.21.2-1  lib32-libpulse-16.1-6
               lib32-libva-mesa-driver-23.0.3-1  lib32-libx11-1.8.4-1  lib32-libxml2-2.10.4-2
               lib32-mesa-23.0.3-1  lib32-nvidia-390xx-utils-390.157-4  lib32-openssl-1:3.0.8-1
               lib32-opus-1.4-1  lib32-systemd-252.10-2  lib32-tdb-1.4.8-1  lib32-vulkan-icd-loader-1.3.245-1
               lib32-wayland-1.22.0-1  lib32-xz-5.4.2-1  lib32-zstd-1.5.5-1  libaio-0.3.113-2
               libass-0.17.1-1  libassuan-2.5.5-2  libavc1394-0.5.4-5  libavtp-0.2.0-2  libbpf-1.1.0-1
               libcamera-0.0.4-4  libcamera-ipa-0.0.4-4  libcap-2.68-1  libcbor-0.10.2-1  libcups-1:2.4.2-6
               libde265-1.0.11-2  libdecor-0.1.1-2  libdiscid-0.6.4-2  libdrm-2.4.115-1  libdv-1.0.0-10
               libedit-20221030_3.1-1  libelf-0.189-1  libgcrypt-1.10.2-1  libgirepository-1.76.1-1
               libgit2-1:1.6.4-1  libgme-0.6.3-2  libgpg-error-1.47-1  libhandy-1.8.2-1  libheif-1.15.2-1
               libibus-1.5.28-3  libice-1.1.1-2  libid3tag-0.15.1b-12  libimagequant-4.1.1-1
               libinput-1.23.0-1  libinstpatch-1.1.6-2  libisl-0.26-1  libjcat-0.1.13-2
               libjpeg-turbo-2.1.5.1-1  libjxl-0.8.1-1  libkate-0.4.1-9  libkcddb-23.04.0-1
               libkcompactdisc-23.04.0-1  libkdcraw-23.04.0-1  libkexiv2-23.04.0-1  libksane-23.04.0-1
               libkscreen-5.27.4-1  libksysguard-5.27.4-1  libldap-2.6.4-2  libmad-0.15.1b-10
               libmalcontent-0.11.1-1  libmanette-0.2.6-4  libmbim-1.28.4-1  libmfx-23.1.6-1
               libmm-glib-1.20.6-1  libmtp-1.1.21-1  libnftnl-1.2.5-1  libnghttp2-1.52.0-2  libnice-0.1.21-2
               libnm-1.42.6-1  libnotify-0.8.2-1  libnsl-2.0.0-3  libopenmpt-0.6.10-1  libpamac-11.5.3-1
               libpamac-flatpak-plugin-11.5.3-1  libpaper-2.1.0-1  libpcap-1.10.4-1  libpipewire-1:0.3.70-1
               libplacebo-5.229.2-2  libpulse-16.1-6  libqalculate-4.6.1-1  libqmi-1.32.4-1  libraqm-0.10.1-1
               librsvg-2:2.56.0-1  libsamplerate-0.2.2-2  libsoup3-3.4.1-1  libsysprof-capture-3.48.0-1
               libtiff-4.5.0-3  libtraceevent-1:1.7.2-1  libtracefs-1.6.4-2  libupnp-1.14.16-1
               liburcu-0.14.0-1  libusb-1.0.26-2  libva-2.18.0-1  libva-mesa-driver-23.0.3-1  libvpx-1.13.0-1
               libwacom-2.6.0-2  libwbclient-4.18.2-1  libwireplumber-0.4.14-1  libwpe-1.14.1-2
               libx86emu-3.5-3  libxau-1.0.11-2  libxaw-1.0.15-1  libxdmcp-1.1.4-2  libxfixes-6.0.1-1
               libxfont2-2.0.6-2  libxft-2.3.8-1  libxi-1.8-3  libxklavier-5.4-4  libxml2-2.10.4-2
               libxmlb-0.3.11-1  libxnvctrl-390xx-390.157-4  libxpm-3.5.16-1  libxt-1.3.0-1  libxvmc-1.0.13-2
               licenses-20220125-2  linux-firmware-20230404.2e92a49f-1
               linux-firmware-whence-20230404.2e92a49f-1  linux61-6.1.26-1  linux61-bbswitch-0.8-31
               linux61-nvidia-390xx-390.157-31  llvm-15.0.7-2  llvm-libs-15.0.7-2  lmdb-0.9.30-3  lua-5.4.4-4
               lvm2-2.03.21-1  man-pages-6.04-1  manjaro-hello-0.7.0-5  manjaro-kde-settings-20230505-2
               manjaro-log-helper-0.3.4+3+ga471e55-1  manjaro-release-22.1.1-1  manjaro-zsh-config-0.25-2
               mesa-23.0.3-1  mesa-demos-9.0.0-2  mesa-utils-9.0.0-2  mhwd-0.6.5-25  mhwd-db-0.6.5-25
               mhwd-nvidia-530.41.03-4  mhwd-nvidia-390xx-390.157-6  mhwd-nvidia-470xx-470.182.03-2
               milou-5.27.4-1  mkinitcpio-35.2-2  mobile-broadband-provider-info-20230416-1
               modemmanager-1.20.6-1  modemmanager-qt-5.105.0-1  mpg123-1.31.3-1  nbd-3.24-2  ndctl-76.1-1
               networkmanager-1.42.6-1  networkmanager-pptp-1.2.12-1  networkmanager-qt-5.105.0-1
               networkmanager-vpnc-1.2.8-3  nfs-utils-2.6.3-1  nfsidmap-2.6.3-1  nftables-1:1.0.7-1
               noto-fonts-20230401-1  npth-1.6-4  nss-3.89-1  nvidia-390xx-utils-390.157-6  okular-23.04.0-1
               onlyoffice-desktopeditors-7.3.3-1  openal-1.23.1-1  openexr-3.1.7-1  openmpi-4.1.5-1
               openpmix-4.2.3-2  openresolv-3.13.0-1  openssh-9.3p1-1  openvpn-2.6.3-1  opus-1.4-1
               ostree-2023.2-1  oxygen-5.27.4-1  oxygen-icons-1:5.105.0-1  oxygen-sounds-5.27.4-1
               p7zip-1:17.05-1  packagekit-qt5-1.1.1-1  pacman-6.0.2-10  pacui-1.14+56+g4976123-3
               pam-1.5.2-2  pamac-cli-10.5.1-1  pamac-gtk-10.5.1-1  pango-1:1.50.14-1  parted-3.6-1
               partitionmanager-23.04.0-1  pcsclite-1.9.9-3  perl-http-daemon-6.16-1  pipewire-1:0.3.70-1
               plasma-browser-integration-5.27.4-1  plasma-desktop-5.27.4-1  plasma-framework-5.105.0-1
               plasma-integration-5.27.4-1  plasma-nm-5.27.4-1  plasma-pa-5.27.4-1
               plasma-systemmonitor-5.27.4-1  plasma-workspace-5.27.4.1-1
               plasma-workspace-wallpapers-5.27.4.1-1  plymouth-22.02.122-12  polkit-kde-agent-5.27.4.1-1
               poppler-23.03.0-1  poppler-glib-23.03.0-1  poppler-qt5-23.03.0-1  portaudio-1:19.7.0-2
               powerdevil-5.27.4.1-1  print-manager-23.04.0-1  prison-5.105.0-1  pulseaudio-16.1-6
               pulseaudio-alsa-1:1.2.7.1-2  pulseaudio-bluetooth-16.1-6  pulseaudio-zeroconf-16.1-6
               purpose-5.105.0-1  pyside6-6.5.0-1  python-3.10.10-1  python-cryptography-40.0.1-1
               python-fastjsonschema-2.16.3-1  python-gobject-3.44.1-1  python-inflect-6.0.4-1
               python-jaraco.functools-3.6.0-1  python-more-itertools-9.1.1-1  python-pip-23.0.1-1
               python-platformdirs-3.2.0-1  python-pydantic-1.10.7-2  python-pyqt5-sip-12.12.1-1
               python-requests-2.28.2-1  python-setuptools-1:67.6.1-1  python-trove-classifiers-2023.4.18-1
               python-typing_extensions-4.5.0-1  python-urllib3-1.26.13-1  python-validate-pyproject-0.12.2-1
               python-wheel-0.40.0-1  qpdf-11.3.0-1  qqc2-desktop-style-5.105.0-1  qt5-base-5.15.9+kde+r151-1
               qt5-declarative-5.15.9+kde+r24-1  qt5-graphicaleffects-5.15.9-1
               qt5-imageformats-5.15.9+kde+r9-1  qt5-location-5.15.9+kde+r4-1  qt5-multimedia-5.15.9+kde+r3-1
               qt5-quickcontrols-5.15.9-1  qt5-quickcontrols2-5.15.9+kde+r5-1  qt5-sensors-5.15.9-1
               qt5-speech-5.15.9+kde+r1-1  qt5-svg-5.15.9+kde+r7-1  qt5-tools-5.15.9+kde+r1-1
               qt5-translations-5.15.9-1  qt5-virtualkeyboard-5.15.9-1  qt5-wayland-5.15.9+kde+r55-1
               qt5-webchannel-5.15.9+kde+r3-1  qt5-webengine-5.15.13-2  qt5-webview-5.15.9-1
               qt5-x11extras-5.15.9-1  qt5-xmlpatterns-5.15.9-1  qt6-base-6.5.0-3  qt6-declarative-6.5.0-2
               qt6-translations-6.5.0-1  raptor-2.0.16-2  re2-1:20230301-1  rsync-3.2.7-4  samba-4.18.2-1
               sane-1.2.1-4  sddm-kcm-5.27.4.1-1  sdl2-2.26.5-1  sed-4.9-3  shaderc-2023.3-1
               shiboken6-6.5.0-1  signon-kwallet-extension-23.04.0-1  skanlite-23.04.0-1  smbclient-4.18.2-1
               snapper-gui-0.1.r8.g1915750-1  solid-5.105.0-1  sonnet-5.105.0-1  spectacle-23.04.0-1
               spectre-meltdown-checker-0.45+8+g6a61df2-1  sqlite-3.41.2-1  squashfs-tools-4.6.1-1
               sudo-1.9.13.p3-1  syndication-5.105.0-1  syntax-highlighting-5.105.0-1  systemd-252.10-2
               systemd-libs-252.10-2  systemd-sysvcompat-252.10-2  systemsettings-5.27.4.1-1  tar-1.34-2
               texinfo-7.0.3-1  thin-provisioning-tools-1.0.3-1  threadweaver-5.105.0-1  tracker3-3.5.0-1
               ttf-meslo-nerd-font-powerlevel10k-20230403-2  ttf-noto-nerd-2.3.3-2  twolame-0.4.0-3
               tzdata-2023c-1  util-linux-2.38.1-3  util-linux-libs-2.38.1-3  v4l-utils-1.24.1-1
               vid.stab-1.1.1-1  virtualbox-guest-utils-7.0.8-1  vlc-3.0.18-9  vpnc-1:0.5.3.r526.r213-1
               vte-common-0.72.1-1  vte3-0.72.1-1  vulkan-headers-1:1.3.246-1  vulkan-icd-loader-1.3.245-1
               vulkan-tools-1.3.245-1  wayland-1.22.0-1  wayland-protocols-1.31-1  webkit2gtk-2.40.1-1
               webkit2gtk-4.1-2.40.1-1  wireless-regdb-2023.02.13-1  wireplumber-0.4.14-1
               wpebackend-fdo-1.14.2-1  xapian-core-1:1.4.22-1  xapp-2.4.3-1
               xdg-desktop-portal-kde-5.27.4.1-1  xf86-input-libinput-1.3.0-1  xfsprogs-6.2.0-1
               xorg-fonts-encodings-1.0.7-1  xorg-server-21.1.8-1  xorg-server-common-21.1.8-1
               xorg-setxkbmap-1.3.3-2  xxhash-0.8.1-4  xz-5.4.2-1  yakuake-23.04.0-1  zenity-3.44.0-3
               zsh-autosuggestions-0.7.0-2  zsh-completions-0.34.0-4  zsh-history-substring-search-1.0.2-2
               zsh-theme-powerlevel10k-1.17.0+23+g1cff2249-1  zstd-1.5.5-1  zvbi-0.2.41-1  zxing-cpp-2.0.0-2
Total Download Size:   1919.57 MiB
Total Installed Size:  6349.32 MiB
Net Upgrade Size:      -124.95 MiB
I need 6.5 GB of free space on my hard drive
No… as I said already. Running this WITHOUT CHROOT means: You did not switch to local installation. You run an update on the live session. You have ~8GB RAM, 2.79GB is used by the OS, the rest is left for new files:
So it is important that you successfully switch to the local installation. Please determine which of your partitions are the root partition:
sda5
Good, now check and repair it:
sudo fsck.ext4 -f -y /dev/sda5
If everything is good, mount it:
sudo mount /dev/sda5 /mnt
Then check what is in your fstab:
cat /mnt/etc/fstab
Post the full output here. thanks.
 sudo fsck.ext4 -f -y /dev/sda5         ✔
Inode 49 extent tree (at level 1) could be narrower.  Optimize? yes
Inode 4457194 extent tree (at level 1) could be narrower.  Optimize? yes
Inode 4458036 extent tree (at level 1) could be narrower.  Optimize? yes
Inode 19268279 extent tree (at level 1) could be shorter.  Optimize? yes
Inode 19268625 extent tree (at level 1) could be shorter.  Optimize? yes
Inode 19331454 extent tree (at level 1) could be shorter.  Optimize? yes
Inode 19539003 extent tree (at level 1) could be shorter.  Optimize? yes
Pass 1E: Optimizing extent trees
/dev/sda5: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sda5: 245010/21102592 files (3.6% non-contiguous), 59717414/84403200 blocks
cat /mnt/etc/fstab         ✔
cat: /mnt/etc/fstab: No such file or directory
That shows the content of /mnt:
ls /mnt
[manjaro manjaro]# ls /mnt
kids lost+found tomi tomi_linux
tomi_linux - this is my account
Alright. That is your home partition, not your root parition. Next one.
Unmount the current mount:
sudo umount /mnt
mount sda2:
sudo mount /dev/sda2 /mnt
show the content:
ls /mnt
[manjaro manjaro]# sudo umount /mnt
[manjaro manjaro]# sudo mount /dev/sda2 /mnt
'All files from Downloads'   boot   lost+found   my_chroot
All files from Downloads is very important folder for me and it had better not be removed
ok still not a root partition. Is it try number 3?
sudo umount /mnt
mount sda6:
sudo mount /dev/sda6 /mnt
show the content:
ls /mnt
If the third ext4 partition is not a root partition, I can only say that there is no Manjaro installation at all.
umount: /mnt: not mounted.
[manjaro manjaro]# sudo mount /dev/sda6 /mnt
lost+found
Well, it is now obvious that there is no Manjaro installation. Did you ever install it? I fear you used the live session all the time.
[manjaro manjaro]# sudo mount /dev/sda1 /mnt
boot  boot.catalog  efi  efi.img  grub
[manjaro manjaro]# sudo mount /dev/sda3 /mnt
[manjaro manjaro]# sudo mount /dev/sda4 /mnt
[manjaro manjaro]# sudo mount /dev/sda5 /mnt
lost+found
