Good day. I followed the instructions in the wiki, however, when I rebooted my laptop, redshift was disabled. What should I do?
neofetch
██████████████████ ████████ soumi@Hori
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: Aspire A514-53 V1.16
████████ ████████ Kernel: 5.14.7-2-MANJARO
████████ ████████ ████████ Uptime: 7 mins
████████ ████████ ████████ Packages: 1499 (pacman)
████████ ████████ ████████ Shell: bash 5.1.8
████████ ████████ ████████ Resolution: 1366x768
████████ ████████ ████████ DE: Plasma 5.22.5
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ Theme: Breeze Light [Plasma], Breeze [GTK2/3]
████████ ████████ ████████ Icons: breeze [Plasma], breeze [GTK2/3]
████████ ████████ ████████ Terminal: konsole
CPU: Intel i3-1005G1 (4) @ 3.400GHz
GPU: Intel Iris Plus Graphics G1
Memory: 2302MiB / 7630MiB
inxi -Fazy
Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3e711149-8ebe-45af-8e9a-78a1cdacff3f rw quiet apparmor=1
security=apparmor resume=UUID=d27dc7f4-ce4f-48b8-ba69-9971d9cc4ca0
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16
date: 01/18/2021
ID-1: BAT0 charge: 32.8 Wh (100.0%) condition: 32.8/53.0 Wh (62.0%)
volts: 16.5 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 4 MiB
bogomips: 9524
Speed: 1000 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1000 2: 996
3: 1000 4: 994
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.2
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.37 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-3: virbr0 state: down mac: <filter>
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Device-1: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:0 size: 476.94 GiB state: S
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2944 chunk-size: N/A
0: nvme1n1 maj-min: 259:5 size: 27.25 GiB state: S
Local Storage: total: 1.4 TiB used: 187.01 GiB (13.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 30.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
ID-1: / raw-size: 400 GiB size: 392.65 GiB (98.16%) used: 83.55 GiB (21.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 208 Uptime: 8m wakeups: 1 Memory: 7.45 GiB used: 2.53 GiB (34.0%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: apt: 0
pacman: 1499 lib: 422 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
sudo nano /etc/geoclue/geoclue.conf
GNU nano 5.8 /etc/geoclue/geoclue.conf
# Configuration file for Geoclue
# NOTE: All configurations settings below are mandatory and the defaults are
# what you see before you edit them. If you want to keep the default
# values around, copy and comment out the appropriate line(s) before
# changing them.
# Agent configuration options
[agent]
# Whitelist of desktop IDs (without .desktop part) of all agents we recognise,
# separated by a ';'.
whitelist=geoclue-demo-agent;gnome-shell;io.elementary.desktop.agent-geoclue2
# Network NMEA source configuration options
[network-nmea]
# Fetch location from NMEA sources on local network?
enable=true
# 3G source configuration options
[3g]
# Enable 3G source
enable=true
# CDMA source configuration options
[cdma]
# Enable CDMA source
enable=true
# Modem GPS source configuration options
[modem-gps]
# Enable Modem-GPS source
enable=true
# WiFi source configuration options
[wifi]
# Enable WiFi source
enable=true
# URL to the WiFi geolocation service. If not set, defaults to Mozilla's
# Location Service with a hardcoded key. To use a custom key, uncomment this URL
# while changing YOUR_KEY to your MLS API key.
#url=https://location.services.mozilla.com/v1/geolocate?key=geoclue
# To use the Google geolocation service instead of Mozilla's, uncomment this URL
# while changing YOUR_KEY to your Google API key.
# WARNING: Please make sure that you are complying with the Google's ToS and
# policies if you uncomment this:
# https://developers.google.com/maps/documentation/geolocation/policies
# Submit data to Mozilla Location Service
# If set to true, geoclue will automatically submit network data to Mozilla
# each time it gets a GPS lock.
submit-data=false
# URL to submission API of Mozilla Location Service. If not set, defaults to
# Mozilla's API with a hardcoded key. To use a custom key, uncomment this URL
#submission-url=https://location.services.mozilla.com/v1/submit?key=YOUR_KEY
# A nickname to submit network data with. A nickname must be 2-32 characters long.
submission-nick=geoclue
# Application configuration options
# NOTE: Having an entry here for an application with allowed=true means that
# geoclue will not ask agent to authorize the application. This is to
# ensure that applications with built-in authorization mechanism (e.g web
# browsers) do not have to be bound to agents.
# If your application is denied access to location information and your
# operating system doesn't provide any mechanism to change that, it is
# likely a bug in your operation system (or geoclue). The solution is to
# report the issue with all details, rather than adding your application
# to this list.
# Format:
# # Desktop ID of application without .desktop part
# [random-app]
# # Allowed access to location information?
# allowed=true|false
# # Is application a system component?
# system=true|false
# # List of UIDs of all users for which this application is allowed location
# # info access, separate by ';'. Keep it empty for allowing it for all users.
# users=
[gnome-datetime-panel]
allowed=true
system=true
users=
[gnome-color-panel]
allowed=true
system=true
users=
[org.gnome.Shell]
allowed=true
system=true
users=
[io.elementary.desktop.agent-geoclue2]
allowed=true
system=true
users=
[epiphany]
allowed=true
system=false
users=
[firefox]
allowed=true
system=false
users=
[redshift]
allowed=true
system=false
users=
nano /home/soumi/.config/redshift/redshift.conf
GNU nano 5.8 /home/soumi/.config/redshift/redshift.conf
[redshift]
temp-day=6500
temp-night=2500
