Hello,
I installed atlasvpn following these instructions:
But when I run atlasvpn signin in the terminal, I get the following message:
Unable to fetch required data. Please try again later.
What could be wrong?
Hello,
Sounds like the package was built/installed fine.
The error itself seems to be a connection problem.
In whatever case - I dont think your issue is relevant to the guide thread.
(Open your own)
PS
atlasvpn-bin exists in the AUR…
When I was new to Linux, I broke my Mandrake install on a regular basis, by installing Red Hat RPMs (Mandrake being based on then Red hat).
I did learn a lot about reinstalling Mandrake.
I personally don’t recommend installing anything from other systems, no matter how close, or even what conversion tools, like Alien, are available.
Thanks for your answer,
I’m just new to Manjaro.
How to install atlasvpn-bin from AUR?
Thank you very much, I’ll take your advice into consideration, but I’ve used atlasvpn in Linux Mint and would like to use it in Manjaro.
Thanks to all!
I installed atlasvpn-bin from AUR.
Its Ok.
