Hey,
was an update to today to system here and get an error:
kunde inte tillfredsställa beroenden:
kan ej möta beroende ‘libgpgme.so=45-64’ som krävs av ostree
is on swedish could not install update!!
What can do to fix that being crazy of that problem not understand.
Could install that update on another computer no problem but these writing from was an problem.
Not understand how to fix that
cannot meet dependency ‘libgpgme.so=45-64’ required by ostree
This could indicate that you were in a partial upgraded state - so you must try again, perhaps checking and updating your mirrors first: pacman-mirrors will show you their state. They should be green…
Firstly, it might work to remove OSTREE, upgrade, then reinstall OSTREE.
If not, then set freshly for your continent and sync/update with this:
Had the same problem and after a bit of searching I saw that it’s a known issue from the unstable branch.
It’s already resolved in pacman 7.0.0.r10.ga2d0293-3 but the stable branch version is 7.0.0.r10.ga2d0293-1 so you need to wait for that to update if you want a no hassle solution.
