Problem with AMD 9070XT GPU and TV
Hi, I have recently experienced similar issues with multiple Linux distributions including Manjaro. However, I am not sure if it is really the same issue as the one described here
I am on an AM4 system with an AMD 9070XT GPU that is only connected to an LG OLED TV. Now, if my system wakes from RAM or disk while the TV is off, the TV will not find a signal unless I unplug and replug the HDMI cable (or reboot, haven’t tried switching to TTY).
I was also suspecting my GPU to be the culprit, but as it works when the system wakes while the TV is on, I am not sure. And since all of you seem to be on NVIDIA GPUs, it might be something else. I found some forum post that mentions problems with recent versions of powerdevil on cachyos (but the suggested fix did not work for me on cachyos), and for me personally the problems began somewhere between the kernel versions 6.16 and 6.18.
Of course, it could also be an unrelated problem, but one thing we all seem to have in common is the CPU: AMD Ryzen 9 5950X. Maybe a problem with older AMD CPUs?
UPDATE: Here is the output requested below (as a new user I am limited to one answer per topic).
    ~  mhwd -l; nhwd -li         ✔
zsh: correct 'nhwd' to 'mhwd' [nyae]? y
> 0000:29:00.0 (0300:1002:7550) Display controller ATI Technologies Inc:
           video-linux            2024.05.06                true            PCI
> Installed PCI configs:
Welcome to Manjaro forum @k0ol
Please post more information about system
inxi -v8z
I think the difference between a computer monitor and a television set is important in the context of connecting a computer to a television set.
Even though I have no electronic engineering insight into the inner workings of computer monitors and television sets - I do think they work differently.
Now that I think of it; my current display a Samsung LS49AG95 computer monitor and my previous GPU Radeon 7900XTX would not work if I powered the workstation before I powered the monitor.
I has become a habit now - I power my monitor before I power my workstation.
I don’t think this is a design flaw as such. It is just how it is.
  Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=83a5e494-05c5-4d37-acc7-b29945744214 rw rootflags=subvol=@
    quiet splash resume=UUID=fb524778-3b52-48e8-8953-73c828ecc2cb
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Desktop System: Micro-Star product: MS-7A32 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: X370 GAMING PRO CARBON (MS-7A32) v: 1.0
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: 1.Q1 date: 05/19/2023
  Device-1: hidpp_battery_1 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.25 GiB used: 8.36 GiB (26.7%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G4DFD824A.C16FHD serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
    desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3598 min/max: 582/5086 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3598 2: 3598 3: 3598
    4: 3598 5: 3598 6: 3598 7: 3598 8: 3598 9: 3598 10: 3598 11: 3598 12: 3598
    13: 3598 14: 3598 15: 3598 16: 3598 17: 3598 18: 3598 19: 3598 20: 3598
    21: 3598 22: 3598 23: 3598 24: 3598 25: 3598 26: 3598 27: 3598 28: 3598
    29: 3598 30: 3598 31: 3598 32: 3598 bogomips: 217598
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: XFX driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
    Writeback-1 bus-ID: 29:00.0 chip-ID: 1002:7550 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: LG (GoldStar) TV SSCR2 serial: <filter>
    built: 2023 res: mode: 3840x2160 hz: 120 scale: 200% (2) to: 1920x1080
    dpi: 61 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9
    modes: 3840x2160, 4096x2160, 2560x1440, 1920x1080, 1280x1024, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
    unhandled CEA mode 117 5: parse_edid: unhandled CEA mode 102 6: parse_edid:
    unhandled CEA mode 101 7: parse_edid: unhandled CEA mode 91 8: parse_edid:
    unhandled CEA mode 90 9: parse_edid: unhandled CEA mode 93 10: parse_edid:
    unhandled CEA mode 94 11: parse_edid: unhandled CEA mode 95 12: parse_edid:
    unhandled CEA mode 98 13: parse_edid: unhandled CEA mode 99 14: parse_edid:
    unhandled CEA mode 100
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
    gfx1201 LLVM 21.1.6 DRM 3.64 6.18.4-1-MANJARO) device-ID: 1002:7550
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.3.3-arch1.1
    device-ID: 1002:7550 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 29:00.1 chip-ID: 1002:ab40 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.4-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 21:00.0
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
    chip-ID: 0a12:0001 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
  Device-1: luks0 maj-min: 253:0 type: LUKS dm: dm-0 size: 10.91 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 10.91 TiB
  Local Storage: total: 13.24 TiB used: 9.42 TiB (71.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T8
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
    model: MZVKW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: CXA7500Q temp: 38.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD120EDAZ-11F3RA0 size: 10.91 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A81 scheme: GPT
  ID-1: / raw-size: 93.94 GiB size: 93.94 GiB (100.00%) used: 8.28 GiB (8.8%)
    fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:7 label: Manjaro
    uuid: 83a5e494-05c5-4d37-acc7-b29945744214
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 58.7 MiB (5.7%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
    label: EFIdisk uuid: 34DA-A4D2
  ID-3: /home raw-size: 250 GiB size: 245.02 GiB (98.01%)
    used: 79.08 GiB (32.3%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:5
    label: Home uuid: 84b2ca7f-50eb-4132-a6d5-4814e89bdd6e
  ID-4: /media/arch raw-size: 100 GiB size: 97.87 GiB (97.87%)
    used: 12.06 GiB (12.3%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:6
    label: Arch uuid: 91c3449e-1eb4-4eee-a1ae-548bad724c83
  ID-5: /media/games raw-size: 1.86 TiB size: 1.83 TiB (98.37%)
    used: 878.86 GiB (46.8%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: Games uuid: e8b4a008-d926-4c91-a842-cf3a05e876de
  ID-6: /media/media raw-size: 10.91 TiB size: 10.83 TiB (99.20%)
    used: 8.46 TiB (78.1%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0 mapped: luks0
    label: N/A uuid: N/A
  ID-7: /media/test raw-size: N/A size: 10.83 TiB used: 8.46 TiB (78.1%)
    fs: fuse.gocryptfs source: ERR-102
  ID-8: /var/cache raw-size: 93.94 GiB size: 93.94 GiB (100.00%)
    used: 8.28 GiB (8.8%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:7
    label: Manjaro uuid: 83a5e494-05c5-4d37-acc7-b29945744214
  ID-9: /var/log raw-size: 93.94 GiB size: 93.94 GiB (100.00%)
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p2 maj-min: 259:4 label: N/A
    uuid: fb524778-3b52-48e8-8953-73c828ecc2cb
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 1-2:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-11:6 info: Logitech USB Receiver type: mouse,keyboard,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
  Device-3: 1-14:5 info: Logitech USB Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c53f class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 48.2 C mobo: N/A gpu: amdgpu temp: 53.0 C
    mem: 74.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 141
  Packages: pm: pacman pkgs: 1417 libs: 396 tools: pamac pm: flatpak pkgs: 0
    1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    4: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    5: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    6: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    9: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    10: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    13: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    14: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    15: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    16: https://manjaro.grena.ge/stable/$repo/$arch
    17: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    20: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    21: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    22: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    23: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    24: https://mirror.init7.net/manjaro/stable/$repo/$arch
    25: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    26: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    28: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    29: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    30: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    31: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    32: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    33: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    34: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    35: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    36: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    37: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    38: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    39: https://manjaro.ynh.ovh/stable/$repo/$arch
    40: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    41: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    42: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    43: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    44: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    45: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    46: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    47: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    48: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    49: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    50: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    52: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    53: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    54: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    55: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    56: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    57: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    58: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    59: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    60: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    61: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    63: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    65: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    66: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    68: https://mirrors2.manjaro.org/stable/$repo/$arch
    69: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    70: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    71: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    72: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    73: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    74: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    75: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    76: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    77: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    79: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    80: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    81: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    82: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    83: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    84: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    85: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    86: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    87: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    88: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    89: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    90: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    91: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    92: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    93: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    94: https://linorg.usp.br/manjaro/stable/$repo/$arch
    95: https://mirror.23m.com/manjaro/stable/$repo/$arch
    96: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 566
  1: cpu: 4.8% command: firefox pid: 43741 mem: 1000.1 MiB (3.1%)
  2: cpu: 2.9% command: firefox pid: 44368 mem: 944.0 MiB (2.9%)
  3: cpu: 2.8% command: kwin_wayland pid: 1208 mem: 472.2 MiB (1.4%)
  4: cpu: 2.2% command: firefox pid: 54626 mem: 480.2 MiB (1.5%)
  5: cpu: 1.1% command: plasmashell pid: 1427 mem: 644.0 MiB (2.0%)
  Memory top: 5 of 566
  1: mem: 1000.1 MiB (3.1%) command: firefox pid: 43741 cpu: 4.8%
  2: mem: 944.0 MiB (2.9%) command: firefox pid: 44368 cpu: 2.9%
  3: mem: 644.0 MiB (2.0%) command: plasmashell pid: 1427 cpu: 1.1%
  4: mem: 599.3 MiB (1.8%) command: steamwebhelper pid: 5729 cpu: 0.0%
  5: mem: 558.7 MiB (1.7%) command: ./steamwebhelper pid: 5591 cpu: 0.2%
  Processes: 566 Power: uptime: 19h 30m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 6 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
Yeah, I also wondered about. Now that I know how to avoid it, it’s not too much of an issue, but I know it was not a problem a month or two ago and there seem to be rather many people reporting video wakeup issues here lately. So for now, my plan is to wait and see if an update fixes it.
I think I know your user name. It is possible that I bought a bladebook (was it called that) from you a couple of years ago?
That is possible - I sincerely hope it served you better than my pinebook pro - the plastic holding the lid hinges, it totally crumbled inside - as I recall the bladebook - it was the same chassis with A and D in alu.
Then it is a bit strange, I will give you that.
Actually, it’s still in a pretty nice condition. I only used it while traveling. At that price point, it was a really good deal in my opinion.
I am glad to hear that and I can safely say - it was not for the money I did it back then… :slight_smile:
If I remember correctly my secretary asked you to send it via sticker mail? :rofl:
EDIT: Speaking of stickers, do you still sell those manjaro stickers for the super key? I am also looking for a solution the copilot key problem…
Nothing of the kind anymore - I donated the lot to Philip at Manjaro and Bryan at EndeavorOS
I see, do you know if either of them have a webshop or something like that?
Also, I would like to ask if chatter like this is okay in an unrelated thread or if I should avoid that in the future.
