Hi. I have a fresh installation of Manjaro 21.2.1 on my laptop. The system works fine (as far as I have started using it). Unfortunately, when I connect the monitor via HDMI it seems to get no signal and goes blank (as if nothing is connected to it). When I try to make it active in “Display and monitor → Display Configuration” (it’s on the list) then when I check “Enabled” and try to apply it nothing happens.
When I close this window and re-enter here (Display Configuration) I have the default situation - that is, I can select a second monitor and there is no Enabled option active (that is, my setting does not save).
I’ve started trying to find a solution to similar problems, but these are my first steps with the architecture of this system and I’m still a little lost. I’ve switched video-hybrid-amd-nvidia-prime to video-hybrid-amd-nvidia-470xx-prime but my situation was not changed so I’ve backed to original driver.
I would appreciate some direction on what might be wrong.
I’ve hybrid laptop (AMD CPU - Nvidia GPU).
mhwd -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
lspci -vnn | grep VGA ✔
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU117M [10de:1f99] (rev a1) (prog-if 00 [VGA controller])
06:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev c6) (prog-if 00 [VGA controller])
This is my xrandr
output:
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.01*+
1680x1050 60.01
1280x1024 60.01
1440x900 60.01
1280x800 60.01
1280x720 60.01
1024x768 60.01
800x600 60.01
640x480 60.01
HDMI-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
grep "connected\|disconnected" /var/log/Xorg.0.log ✔
[ 6.660] (II) AMDGPU(0): Output eDP connected
[ 6.750] (--) NVIDIA(GPU-0): DELL P2419HC (DFP-0): connected
[ 23.223] (--) NVIDIA(GPU-0): DELL P2419HC (DFP-0): connected
[ 23.645] (--) NVIDIA(GPU-0): DELL P2419HC (DFP-0): connected
[ 351.668] (--) NVIDIA(GPU-0): DELL P2419HC (DFP-0): connected
This is my inxi
output:
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8cb70986-018e-480d-a503-f3be5311b0fe rw quiet apparmor=1
security=apparmor resume=UUID=b07b18cd-58a5-4466-8944-0149b4b4a8f3
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ARH05
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: FCCN13WW date: 06/29/2020
ID-1: BAT0 charge: 38.7 Wh (94.6%) condition: 40.9/45.0 Wh (90.9%)
volts: 12.7 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: N/A cycles: 35
RAM: total: 15.07 GiB used: 2.53 GiB (16.8%)
RAM Report:
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1398 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1397 5: 1395 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1396
12: 1397 13: 1396 14: 1398 15: 1397 16: 1397 bogomips: 92662
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99
class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 1.38 TiB used: 35.08 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8L
lanes: 4 type: SSD serial: <filter> rev: C04C temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 233010WD temp: 32.9 C scheme: GPT
ID-1: / raw-size: 90 GiB size: 88.03 GiB (97.81%) used: 11.92 GiB (13.5%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 8cb70986-018e-480d-a503-f3be5311b0fe
label: NO_LABEL uuid: C5A4-A872
ID-3: /home raw-size: 378.43 GiB size: 371.43 GiB (98.15%)
used: 23.16 GiB (6.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 531dfe06-3c85-4597-a014-529719ce7dd1
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: b07b18cd-58a5-4466-8944-0149b4b4a8f3
ID-1: /dev/nvme1n1p1 maj-min: 259:6 size: 931.51 GiB fs: ext4 label: N/A
uuid: 0ed89920-08f8-40ad-a71e-a56a77fee95b
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-2: 1-3:3 info: IMC Networks Integrated Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 3-3:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 330 Uptime: 15m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1249 pacman: 1246 lib: 339
flatpak: 0 snap: 3 Shell: Zsh v: 5.8 default: Bash v: 5.1.12
running-in: konsole inxi: 3.3.11
