Problem when trying to run uiautomatorviewer
I want to run Android studio Uiautomatorviewer on Manjaro Linux but it says there is no SWT found.
I want to install SWT using:
yay -S swt
but it says there is no Cairo found.
I installed the cairo using:
yay -S cairo
but when I want to install the SWT, again it says there is no cairo.
I want to install Cairo from the source but then it says there is no lzo2 and libpng found.
I installed the two libs but again Cairo can’t build because of these two libs.
how can I fix this problem?
Thank you for your help!
Hi,
I checked cairo with pacman.
[nls@lap ~]$ sudo pacman -S cairo
[sudo] password for nls:
warning: cairo-1.18.0-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) cairo-1.18.0-1
Total Installed Size:  1,59 MiB
Net Upgrade Size:      0,00 MiB
:: Proceed with installation? [Y/n] n
[nls@lap ~]$
I found swt, the open source widget toolkit for java, found in the AUR with pamac
yes that is there, but pamac couldn’t build it:
Preparing...
Cloning swt build files...
Generating swt information...
Checking swt dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building swt...
==> Making package: swt 4.28-2 (Sun 15 Oct 2023 01:01:40 PM +0330)
==> Retrieving sources...
  -> Found swt-4.28-gtk-linux-x86_64.zip
  -> Found build-swt.xml
    swt-4.28-gtk-linux-x86_64.zip ... Passed
    build-swt.xml ... Passed
==> Extracting sources...
==> Starting prepare()...
==> Removing existing $pkgdir/ directory...
==> Starting build()...
Buildfile: /var/tmp/pamac-build-hami/swt/src/build-swt.xml
init:
   [tstamp] Honouring environment variable SOURCE_DATE_EPOCH which has been set to 1697362300
    [mkdir] Created dir: /var/tmp/pamac-build-hami/swt/src/build
compile:
    [javac] Compiling 452 source files to /var/tmp/pamac-build-hami/swt/src/build
    [javac] javac: invalid source release: 11
    [javac] Usage: javac <options> <source files>
    [javac] use -help for a list of possible options
BUILD FAILED
/var/tmp/pamac-build-hami/swt/src/build-swt.xml:11: Compile failed; see the compiler error output for details.
Total time: 0 seconds
==> ERROR: A failure occurred in build().
    Aborting...
Check you have prerequisites installed:
If you bothered to investigate why it fails - by reading the error message - applying some developer logic …
Then you find this
Which indicates an unsupported java source version
Then you should check which jdk is required, install it and use archlinux-java to set the active jdk.
