Problem updating winboat
** (inkscape:880670): WARNING **: 19:32:11.317: Unable to connect to dbus: Error sending credentials: Error sending message: Operation not permitted
(inkscape:880670): dbind-WARNING **: 19:32:11.318: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
magick: MissingArgument `-resize' at CLI arg 4 @ fatal/magick-cli.c/ProcessCommandOptions/676.
==> ERROR: A failure occurred in package().
    Aborting...
 -> error making: winboat-exit status 4
 -> Failed to install the following packages. Manual intervention is required:
winboat - exit status 4
==> ERROR: An error has occurred during the update process
The update has been aborted
What was the command which in the end produced this result?
winboat-bin might be a good alternative
no need to compile it, it already is
https://aur.archlinux.org/packages?O=0&K=winboa
As I understood what the thing does:
it’s a whole VM running Windows and then your app in it.
Might be necessary for some things.
For most, native alternatives exist.
Or wine.
It seems to hang on this command for a long time before it stops responding.
 • building        target=tar.gz arch=x64 file=dist/winboat-0.9.0-x64.tar.gz
I’ll try the bin version.
