type or paste code he[demo@manjaro ~]$ sudo pacman-mirrors --fasttrack && sudo pacman -Syuu && pamac update -a
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.814 Global : https://mirrors.manjaro.org/repo/
::INFO Writing mirror list
::Global : https://mirrors.manjaro.org/repo/unstable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies...
Packages (2) python-setuptools-1:64.0.0-1 rhash-1.4.3-1
Total Installed Size: 3.72 MiB
Net Upgrade Size: 0.16 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring [#############################################] 100%
(2/2) checking package integrity [#############################################] 100%
(2/2) loading package files [#############################################] 100%
(2/2) checking for file conflicts [#############################################] 100%
error: failed to commit transaction (conflicting files)
python-setuptools: /usr/lib/python3.10/site-packages/setuptools/command/__pycache__/editable_wheel.cpython-310.pyc exists in filesystem
python-setuptools: /usr/lib/python3.10/site-packages/setuptools/command/editable_wheel.py exists in filesystem
re
erm… why pacman and pamac together?
Erm… what? python is part of filesystem package?
Anyway… just overwrite it:
pamac update --overwrite "/usr/lib/python3.10/*"
No reason just combining updates at the same time.
Can’t answer this question.
Your solution worked
Thanks
