Hi, I connectet my laptop to my TV with hdmi. I want to use it primarly on my tv, leaving the screen of the laptop closed. But when i close the laptopscreen the tvscreen goes off too. With my former Distro I had the same problem, but I could switch to an Intel-driver which solved it (I think it was i915)
Here are the specs of my machine.
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d0bc7191-a1c7-4201-a5f3-e37e56238f7e rw quiet apparmor=1
security=apparmor resume=UUID=a2cb04dd-618c-4f19-a445-4ea08c13fd41
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Packard Bell product: Easynote ENTG71BM v: V1.10
serial: <superuser required>
Mobo: Packard Bell model: Easynote ENTG71BM v: V1.10
serial: <superuser required> UEFI-[Legacy]: Insyde v: 1.10 date: 12/15/2014
ID-1: BAT0 charge: 29.0 Wh (100.0%) condition: 29.0/36.7 Wh (79.1%)
volts: 11.9 min: 11.4 model: LGC AC14B18J type: Li-ion serial: <filter>
status: full
Device-1: hid-20:73:34:07:30:5d-battery model: ECBK02 serial: N/A
charge: N/A status: discharging
RAM: total: 1.82 GiB used: 1.2 GiB (65.8%)
RAM Report:
Info: model: Intel Celeron N2840 bits: 64 type: MCP arch: Silvermont
family: 6 model-id: 0x37 (55) stepping: 8 microcode: 0x838
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 531 high: 563 min/max: 500/2582 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 563 2: 500
bogomips: 8671
Flags: 3dnowprefetch acpi aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: HDMI-A-1
off: eDP-1 empty: DP-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0f31
class-ID: 0300
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus-ID: 2-4:4
chip-ID: 04f2:b47f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: 43FHD_LCD_TV
built: 2015 res: 1920x1080 hz: 60 dpi: 38 gamma: 1.2
size: 1280x720mm (50.39x28.35") diag: 1093mm (43") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 note: disabled model: LG Display 0x0456 built: 2014
res: 1920x1080 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:0f04 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
When I look for possible drivers for the gpu I get this:
mhwd -l --pci
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:0f31) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Is there a way to install the Intel-Driver or a way to close the Laptopscreen without affecting the hdmi-port? Thank you
