Problem setting up second monitor
Hello guys. When i power on my second monitor and change some settings to be vertical the second monitor, it makes it primary screen making all the bar and icons move to the second screen. Also when i try to change back the first monitor to primary nothing happens. How to solve this?
Hi,
set the output of the panel to one screen in the panel settings:
Rightclick on panel > panel > panel settings
or
search it in Whisker Menu
or
start it with xfce4-panel --preferences in a terminal.
By default it is set to “auto”.
Hope that helps :wink:
that helped me fix the problem! thanks a lot!
Glad to help… but please don’t forget the Solution button :slight_smile: Thanks :slight_smile:
