Problem re-mounting unmounted external SSD
I’m clearly losing my mind. I unmounted an external SSD (SSE10 mounted) and can’t remember how to re-mount it. It is not showing up in Dolphin and I can’t even find my notes on how to do this. Help!
  Kernel: 6.6.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
  Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
    part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 2403
    date: 05/11/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    status: discharging
  Info: 12-core (8-mt/4-st) model: 12th Gen Intel Core i7-12700 bits: 64
    type: MST AMCP smt: enabled arch: Alder Lake rev: 2 cache: L1: 1024 KiB
    L2: 12 MiB L3: 25 MiB
  Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 cores: 1: 800 2: 800
    3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
    13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
    bogomips: 84500
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 pcie: speed: 8 GT/s
    lanes: 16 ports: active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 48.0 C
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
    s-diag: 1064mm (41.9") monitors: <missing: xrandr>
  Monitor-1: DVI-D-1 model: Samsung SyncMaster serial: <filter>
    res: 1920x1200 dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
    modes: max: 1920x1200 min: 720x400
  Monitor-2: HDMI-A-1 model: Acer G276HL serial: <filter> res: 1920x1080
    dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27") modes:
    max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 LLVM 18.1.8 DRM 3.54 6.6.46-1-MANJARO) device-ID: 1002:67df
  API: Vulkan v: 1.3.279 layers: N/A surfaces: xcb,xlib device: 0
    type: discrete-gpu hw: amd driver: mesa radv device-ID: 1002:67df
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  API: ALSA v: k6.6.46-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.2.2 status: off with: wireplumber status: active
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 5.49 TiB used: 711.67 GiB (12.7%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
    temp: 35.9 C scheme: GPT
  ID-2: /dev/sda vendor: SanDisk model: SSD PLUS 2000GB size: 1.82 TiB
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
  ID-3: /dev/sdb vendor: Kingston model: DataTraveler 3.0 size: 28.87 GiB
    type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 tech: N/A serial: <filter>
    fw-rev: 0000 scheme: MBR
  ID-4: /dev/sdc vendor: Western Digital model: WD20SDRW-11VUUS0
    size: 1.82 TiB type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 1034 scheme: MBR
  ID-1: / size: 1.78 TiB used: 121.02 GiB (6.6%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 27.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1137
  Memory: total: 64 GiB available: 62.54 GiB used: 4.96 GiB (7.9%)
  Processes: 532 Power: uptime: 1h 14m states: freeze,mem,disk suspend: deep
    wakeups: 1 hibernate: platform Init: systemd v: 256 default: graphical
  Packages: 1565 pm: pacman pkgs: 1560 pm: flatpak pkgs: 5 Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
    running-in: konsole inxi: 3.3.35
Have you unplugged it and plugged it back in? It should then show up in dolphin.
Yes, I have. That’s how I expected to get it remounted. So I’ve tried several configurations of restarting but to no avail.
Have you tried a different USB port?
Does it show up with lsblk?
No. It should show up as “Easystore.”
lsblk         1 ✘
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
sda           8:0    0  1.8T  0 disk
└─sda1        8:1    0  1.8T  0 part /run/media/chas/attic
sdb           8:16   1 28.9G  0 disk
└─sdb1        8:17   1 28.9G  0 part /run/media/chas/kingston2408
sdc           8:32   0  1.8T  0 disk
└─sdc1        8:33   0  1.8T  0 part
sr0          11:0    1 1024M  0 rom
sr1          11:1    1 1024M  0 rom
nvme0n1     259:0    0  1.8T  0 disk
├─nvme0n1p1 259:1    0  300M  0 part /boot/efi
├─nvme0n1p2 259:2    0  1.8T  0 part /
└─nvme0n1p3 259:3    0  8.8G  0 part [SWAP]
Actually, now that I look at this a little closer, it might be /sdc1
It probably is, unless you have another 2TB drive that isn’t mounted.
So try this.
sudo mount /dev/sdc1 /mnt
ls /mnt
sudo umount /mnt
Perhaps when it’s mounted to a path that contains “Easystore”, or in dolphin.
You can’t re-mount a external Drive which has no power, because of a clean shutdown.
Sometimes the unmounted drive won’t shutdown, then i have to use the shutdown command below:
USB-Drive Shutdown (Replace X with actually drive label):
udisksctl power-off -b /dev/sdX
In your case it should look like that:
udisksctl power-off -b /dev/sdc1
If the external drive is finally powered down, i just replug the external drive to show up in Dolphin again.
If your SDC1 drive (1,8Tbyte) is really your external drive of course.
the ls /mnt command after the mount command yielded lost+found.
When I tried the power-off command I got error message saying the drive is in use, mounted.
Then unmount it first:
sudo umount /mnt
/sdc1 definitely is the SSD. But when I plug it in the computer sees USB STICK, not Easystore, and when I mount it everything on the disk is hidden, which is a lot. The only thing that show on Dolphin is Lost&Found.
Spoiler alert, you can also open KDE Partition Manager… if the terminal commands confuse you.
Taskbar>system>KDE Partition Manager
From there you see Visual easily your drive and how many partitions it has… and how much space it has.
I hope not, but the label change and the seemingly empty filesystem make me think it’s been formatted.
Did you try to format another drive?
I was thinking the same :frowning:
Ach, Scheisse!!! You are evidently correct. Per Kobald’s suggestion, looking in Partition Manager there is clearly nothing there and the Label has been changed to USB STICK. I did format some flash drives a couple of days ago. I thought I was being so careful, which is why I unmounted the SSD. Obviously should have unplugged it. Manjaro not the problem. Linux not the problem. Hardware not the problem. I’m the GD’ed problem. Thanks for your help.
I have only limited experience with data recovery… but if you only format it without doing anything additional… you may have a chance to restore your files.
If you want to go this way, open another Topic… maybe someone other can you assist with data recovery.
Just don’t do additional writings on your drive.
