Hi, I’m a new user of Manjaro Linux. I have just installed Manjaro Linux on my laptop, but my system couldn’t recognize any wireless network. How can I solve this problem?
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=c3ad2337-86c1-404a-95c3-ecbf44a3b777 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: TIMI product: RedmiBook 14-APCS v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: TIMI model: TM1931 v: V1.00 serial: <filter> UEFI: TIMI
v: RMRPC400P0401 date: 10/23/2019
ID-1: BAT0 charge: 9.9 Wh condition: 46.2/47.0 Wh (98%) volts: 14.7/15.2
model: SUNWODA R14B01W type: Li-ion serial: <filter> status: Discharging
Topology: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 L2 cache: 2048 KiB
bogomips: 33548
Speed: 1222 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1221 2: 1224 3: 1222 4: 1221 5: 1393 6: 1322 7: 1222 8: 1222
disabled, RSB filling
Device-1: AMD Picasso vendor: Xiaomi driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:15d8
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.16-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Xiaomi
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Xiaomi
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Xiaomi driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel bus ID: 01:00.0
chip ID: 168c:003e
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 2-3:2 chip ID: 0bda:8153 serial: <filter>
IF: enp3s0f3u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 6.93 GiB (2.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HAHQ-00000
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: EXD7201Q scheme: GPT
ID-1: / raw size: 10.61 GiB size: 10.38 GiB (97.84%) used: 6.90 GiB (66.5%)
fs: ext4 dev: /dev/nvme0n1p5
System Temperatures: cpu: 41.4 C mobo: N/A gpu: amdgpu temp: 41 C
Processes: 233 Uptime: 22m Memory: 5.80 GiB used: 1.43 GiB (24.6%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1161 lib: 317
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
