I tried the telegram-desktop. It worked on pi4, but after switching to pi5, it fail to start up, and throws an error at me:
<jemalloc>: Unsupported system page size
And here is my system info:
Kernel: 6.12.19-1-MANJARO-RPI5 arch: aarch64 bits: 64 compiler: gcc v: 14.2.1
clocksource: arch_sys_counter parameters: reboot=w coherent_pool=1M
8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory
numa_policy=interleave numa=fake=8 system_heap.max_order=0
smsc95xx.macaddr=2C:CF:67:A8:6C:44 vc_mem.mem_base=0x3fc00000
vc_mem.mem_size=0x40000000 root=PARTUUID=c7717192-02 rw rootwait
console=ttyAMA10,115200 console=tty3 selinux=0 quiet splash
plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0
kgdboc=ttyAMA10,115200 usbhid.mousepoll=8 audit=0
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro ARM base: Arch Linux
Type: ARM System: Raspberry Pi 5 Model B Rev 1.1 details: N/A rev: d04171
serial: <filter>
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: N/A available: 7.86 GiB used: 3.79 GiB (48.2%) igpu: 8 MiB
RAM Report: message: No RAM data found using udevadm.
Message: No ARM data found for this feature.
Info: model: N/A variant: cortex-a76 bits: 64 type: MCP arch: ARMv8 family: 8
model-id: 4 stepping: 1
Topology: cpus: 1x clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 512 KiB desc: d-4x64 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 1700 min/max: 1500/2400 scaling: driver: cpufreq-dt
governor: ondemand cores: 1: 1700 2: 1700 3: 1700 4: 1700 bogomips: 432
Features: aes asimd asimddp asimdhp asimdrdm atomics cpuid crc32 dcpop
evtstrm fp fphp lrcpc pmull sha1 sha2
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: CSV2, BHB
Device-1: bcm2712-hdmi0 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:107c701400 class-ID: hdmi
Device-2: bcm2712-hdmi1 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:107c706400 class-ID: hdmi
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev
dri: vc4
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_txp,vc4_v3d,vc4_vec
display-ID: 0
Monitor-1: HDMI-A-1 model: FKS-C215J serial: <filter> built: 2022 res:
mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red:
x: 0.647 y: 0.345 green: x: 0.322 y: 0.631 blue: x: 0.153 y: 0.059 white:
x: 0.314 y: 0.329 size: 476x268mm (18.74x10.55") diag: 546mm (21.5")
ratio: 16:9 modes: 1920x1080, 1920x1080i, 1680x1050, 1280x1024, 1440x900,
1280x960, 1280x800, 1152x864, 1280x720, 1440x576, 1024x768, 1440x480,
832x624, 800x600, 720x576, 720x576i, 720x480, 720x480i, 640x480, 720x400
API: EGL v: 1.5 hw: drv: broadcom v3d platforms: device: 0 drv: v3d
device: 1 drv: swrast gbm: drv: v3d surfaceless: drv: v3d wayland: drv: v3d
x11: drv: v3d
API: OpenGL v: 4.5 compat-v: 3.1 vendor: broadcom mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: V3D 7.1.10.2 device-ID: 14e4:ffffffff
memory: 7.68 GiB unified: yes display-ID: :1.0
Device-1: bcm2712-hdmi0 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:107c701400
class-ID: hdmi
Device-2: bcm2712-hdmi1 driver: vc4_hdmi bus-ID: N/A
API: ALSA v: k6.12.19-1-MANJARO-RPI5 status: kernel-api
Server-1: PipeWire v: 1.4.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Raspberry Pi RP1 PCIe 2.0 South Bridge driver: rp1 v: kernel
port: N/A bus-ID: 0001:01:00.0 chip-ID: 1de4:0001 class-ID: 0200
IF-ID-1: end0 state: down mac: <filter>
Info: services: NetworkManager, sshd, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Device-1: bcm7271-uart driver: bcm7271_uart bus-ID: N/A
chip-ID: brcm:107d50c000 class-ID: serial
Local Storage: total: 583.8 GiB used: 113.23 GiB (19.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SD64G
size: 59.45 GiB block-size: physical: 512 B logical: 512 B type: Removable
tech: SSD serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S530Q 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SN12380 temp: 34.9 C
scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Lenovo model: 64GB thinkplus
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.1
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 3.00 scheme: MBR
ID-1: / raw-size: 465.28 GiB size: 456.91 GiB (98.20%)
used: 113.11 GiB (24.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: ROOT_MNJRO uuid: 12e07176-8dda-4674-8532-4ade95134720
ID-2: /boot raw-size: 457.8 MiB size: 457.5 MiB (99.94%)
used: 67.5 MiB (14.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: BOOT_MNJRO uuid: 4525-5221
ID-3: /run/media/caul/android raw-size: 58.59 GiB size: 58.59 GiB (99.99%)
used: 49.1 MiB (0.1%) fs: exfat dev: /dev/sda1 maj-min: 8:1 label: android
uuid: 6FFA-ABC9
Kernel: swappiness: 60 (default) cache-pressure: 80 (default 100) zswap: no
ID-1: swap-1 type: zram size: 11.79 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4 max-streams: 4 dev: /dev/zram0
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 512 MiB fs: vfat label: bootfs
uuid: 5DC7-F115
ID-2: /dev/mmcblk0p2 maj-min: 179:2 size: 58.94 GiB fs: ext4 label: rootfs
uuid: a36be96c-66be-4487-a7a6-0481bca99d89
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: VXE V87 type: keyboard driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 400mA chip-ID: 320f:5055 class-ID: 0301 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.0
Device-1: 2-1:4 info: Lenovo 64GB thinkplus type: mass storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 144mA chip-ID: 346d:5678 class-ID: 0806
serial: <filter>
Device-1: 3-2:2 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.0
System Temperatures: cpu: 57.2 C mobo: N/A
Fan Speeds (rpm): cpu: 2621
Packages: pm: pacman pkgs: 919 libs: 249 tools: pamac,yay
1: https://mirrors.jlu.edu.cn/manjaro/arm-unstable/$repo/$arch
2: https://mirrors.pku.edu.cn/manjaro/arm-unstable/$repo/$arch
3: https://mirrors.ustc.edu.cn/manjaro/arm-unstable/$repo/$arch
4: http://ftp.riken.jp/Linux/manjaro/arm-unstable/$repo/$arch
5: https://mirrors.tuna.tsinghua.edu.cn/manjaro/arm-unstable/$repo/$arch
6: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/arm-unstable/$repo/$arch
7: https://mirror.archlinux.tw/Manjaro/arm-unstable/$repo/$arch
8: https://mirror.phoepsilonix.love/manjaro/arm-unstable/$repo/$arch
9: https://mirror.freedif.org/Manjaro/arm-unstable/$repo/$arch
10: https://mirrors.cicku.me/manjaro/arm-unstable/$repo/$arch
11: https://mirror.koddos.net/manjaro/arm-unstable/$repo/$arch
12: https://mirrors2.manjaro.org/arm-unstable/$repo/$arch
13: https://mirrors.manjaro.org/repo/arm-unstable/$repo/$arch
14: http://ftp.tu-chemnitz.de/pub/linux/manjaro/arm-unstable/$repo/$arch
15: https://mirrors.eric.ovh/manjaro/arm-unstable/$repo/$arch
16: http://ftp.uni-kl.de/pub/linux/manjaro/arm-unstable/$repo/$arch
17: http://manjaro.mirrors.uk2.net/arm-unstable/$repo/$arch
18: https://mirror.vinehost.net/manjaro/arm-unstable/$repo/$arch
19: https://mirror.hostiko.network/manjaro/arm-unstable/$repo/$arch
20: https://mirrors.sonic.net/manjaro/arm-unstable/$repo/$arch
21: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/arm-unstable/$repo/$arch
22: https://repo.ialab.dsu.edu/manjaro/arm-unstable/$repo/$arch
23: https://manjaro.mirrors.lavatech.top/arm-unstable/$repo/$arch
24: https://manjaro.ynh.ovh/arm-unstable/$repo/$arch
25: https://mirror.csclub.uwaterloo.ca/manjaro/arm-unstable/$repo/$arch
26: https://mirrors.ocf.berkeley.edu/manjaro/arm-unstable/$repo/$arch
27: https://mirror.raiolanetworks.com/manjaro/arm-unstable/$repo/$arch
28: http://ossmirror.mycloud.services/os/linux/manjaro/arm-unstable/$repo/$arch
29: https://ftp.halifax.rwth-aachen.de/manjaro/arm-unstable/$repo/$arch
30: https://mirrors.gigenet.com/manjaro/arm-unstable/$repo/$arch
31: https://mirror.truenetwork.ru/manjaro/arm-unstable/$repo/$arch
32: https://mirror.23m.com/manjaro/arm-unstable/$repo/$arch
33: https://muug.ca/mirror/manjaro/arm-unstable/$repo/$arch
34: https://manjaro.mirror.wearetriple.com/arm-unstable/$repo/$arch
35: https://mirror.2degrees.nz/manjaro/arm-unstable/$repo/$arch
36: http://manjaro.grena.ge/arm-unstable/$repo/$arch
37: https://mirrors.nic.cz/manjaro/arm-unstable/$repo/$arch
38: https://manjaro.kurdy.org/arm-unstable/$repo/$arch
39: http://ftp.free.org/mirrors/repo.manjaro.org/repos/arm-unstable/$repo/$arch
40: https://mirror.telepoint.bg/manjaro/arm-unstable/$repo/$arch
41: http://ftp.snt.utwente.nl/pub/linux/manjaro/arm-unstable/$repo/$arch
42: https://mirror.dc.uz/manjaro/arm-unstable/$repo/$arch
43: https://ftp.lysator.liu.se/pub/manjaro/arm-unstable/$repo/$arch
44: https://mirrors.dotsrc.org/manjaro/arm-unstable/$repo/$arch
45: https://mirror.init7.net/manjaro/arm-unstable/$repo/$arch
46: https://ba.mirror.garr.it/mirrors/manjaro/arm-unstable/$repo/$arch
47: https://mirrors.atlas.net.co/manjaro/arm-unstable/$repo/$arch
48: https://mirror.xenyth.net/manjaro/arm-unstable/$repo/$arch
49: https://mirror.futureweb.be/manjaro/arm-unstable/$repo/$arch
50: https://mirror.leitecastro.com/manjaro/arm-unstable/$repo/$arch
51: https://linorg.usp.br/manjaro/arm-unstable/$repo/$arch
52: https://mirror.dkm.cz/manjaro/arm-unstable/$repo/$arch
53: https://ct.mirror.garr.it/mirrors/manjaro/arm-unstable/$repo/$arch
54: https://manjaro.c3sl.ufpr.br/arm-unstable/$repo/$arch
55: http://kartolo.sby.datautama.net.id/manjaro/arm-unstable/$repo/$arch
56: https://manjarolinux-mirror.cloud.mu/arm-unstable/$repo/$arch
57: https://mirror.aarnet.edu.au/pub/manjaro/arm-unstable/$repo/$arch
58: https://mirror.zetup.net/manjaro/arm-unstable/$repo/$arch
59: http://mirror.is.co.za/mirrors/manjaro.org/arm-unstable/$repo/$arch
60: https://repo.iut.ac.ir/repo/manjaro/arm-unstable/$repo/$arch
61: https://manjaro.mirror.liquidtelecom.com/arm-unstable/$repo/$arch
62: https://mirror.ufro.cl/manjaro/arm-unstable/$repo/$arch
63: https://ftp.gwdg.de/pub/linux/manjaro/arm-unstable/$repo/$arch
64: https://ftp.caliu.cat/pub/distribucions/manjaro/arm-unstable/$repo/$arch
65: https://mirror.easyname.at/manjaro/arm-unstable/$repo/$arch
66: https://mirror.math.princeton.edu/pub/manjaro/arm-unstable/$repo/$arch
67: https://manjaro.ipacct.com/manjaro/arm-unstable/$repo/$arch
68: https://mirror.netcologne.de/manjaro/arm-unstable/$repo/$arch
69: https://mirrors.up.pt/pub/manjaro/arm-unstable/$repo/$arch
70: https://manjaro.mirror.garr.it/manjaro/arm-unstable/$repo/$arch
71: https://manjaro.repo.cure.edu.uy/arm-unstable/$repo/$arch
72: https://mirror.kamtv.ru/manjaro/arm-unstable/$repo/$arch
73: https://fosszone.csd.auth.gr/manjaro/arm-unstable/$repo/$arch
74: http://mirror.xeonbd.com/manjaro/arm-unstable/$repo/$arch
75: https://mirror.bouwhuis.network/manjaro/arm-unstable/$repo/$arch
76: https://mirror.yandex.ru/mirrors/manjaro/arm-unstable/$repo/$arch
77: http://ftp.belnet.be/mirrors/manjaro/repos/arm-unstable/$repo/$arch
78: https://bd.mirror.vanehost.com/Manjaro/arm-unstable/$repo/$arch
79: https://ftpmirror1.infania.net/mirror/manjaro/arm-unstable/$repo/$arch
Processes:
CPU top: 5 of 237
1: cpu: 12.6% command: firefox pid: 16930 mem: 611.4 MiB (7.5%)
2: cpu: 7.7% command: firefox pid: 17162 mem: 276.3 MiB (3.4%)
3: cpu: 1.9% command: kwin_wayland pid: 1021 mem: 230.5 MiB (2.8%)
4: cpu: 1.1% command: firefox pid: 17167 mem: 164.8 MiB (2.0%)
5: cpu: 0.5% command: plasmashell pid: 1189 mem: 479.5 MiB (5.9%)
Memory top: 5 of 237
1: mem: 611.4 MiB (7.5%) command: firefox pid: 16930 cpu: 12.6%
2: mem: 479.5 MiB (5.9%) command: plasmashell pid: 1189 cpu: 0.5%
3: mem: 276.3 MiB (3.4%) command: firefox pid: 17162 cpu: 7.7%
4: mem: 230.5 MiB (2.8%) command: kwin_wayland pid: 1021 cpu: 1.9%
5: mem: 164.8 MiB (2.0%) command: firefox pid: 17167 cpu: 1.1%
Processes: 237 Power: uptime: 4h 46m suspend: services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
I found some problem similar in a post on Arch forum but it is kind old, and people says it was fixed. But I still encounter this problem.
Help me plz ![]()
