Hello,
New PC, clean Manjaro KDE install. Trying to mount a network drive with the following fstab entry:
//wdmycloud/Public /mnt/nas cifs username=anonimous,password=,iocharset=utf8,dir_mode=0777,file_mode=0777,rw 0 0
After booting, when I try to access /mnt/nas from Dolphin, it doesn’t work and the following error is displayed:
An error occured while accessing 'mnt/nas', the system responded: mount.cifs: permission denied
However, if I do ‘sudo mount -a’ then the ntwork drive is mounted and works OK. The very same fstab entry worked OK on my old pc. What can be the problem?
TIA
Are you using a WIFI network on your PC?
It is possible that the network is not available at the time that mount is attempted, but is by the time you type sudo mount -a
No, this is a wired connection.
ForeverNoob:
username=anonimous
are you sure the username is correct?
New info: during boot, right before login screen appear, the following text is displayed:
[FAILED] Failed to mount /mnt/nas
[DEPENDENT] Dependency failed for remote file system.
Help will be appreciated. TIA.
Yes. Also tried NAS admin user/pass, same response.
Well, I found a stupid solution by creating a cron job that executes mount -a after boot. It works, but will nice to have a proper solution, if anyone knows.
Thanks to all that helped.
Once again, are you sure it’s correct? Because, that spelling is wrong.
Else, see
Difficulty: ★☆☆☆☆
Disk device recognition
Manjaro uses udev (see Arch Wiki ) to load devices at boot time. The loading of devices is arbitrary and therefore you cannot predict which device will be available at a given path.
But static device names do exist and you can assign specific locations to your device and thus ensure e.g. scripts will work as expected.
What to learn
Overview of system mount units
Structure and Content of a mount unit
Mount at boot (immediate mount)
Mount on demand (m…
and
Difficulty: ★★☆☆☆
Example mount units for systemd
The examples here are a supplement to the guide on systemd mount units
Remember to remove the comments placed in the units - they are not writing for copy-paste but as examples. (comments is text beginning with a #)
[root tip] [How To] Use systemd to mount ANY device
Only use an automount unit if the device is not readily available at boot like removable devices and network locations.
Important rule
Hi Mirdarthos,
True, the spelling was wrong. However, fixing it or using the real user/password for the NAS device yields same result.
I will look at the other stuff and see if it works.
Thanks.
