It’s not my ip, i’m sure of that (my provider assigned me an ip).
If i understand what you said, i must not use a mount point in home folder.
For example, i can use /run/media/marc/download/syno instead?
All my disks are “under” run/media.
[marc@marc-pc ~]$ systemd-escape -p --suffix=mount "//run/media/marc/download/"
run-media-marc-download.mount
[marc@marc-pc ~]$ sudo nano /etc/systemd/system/run-media-marc-download.mount
[sudo] Mot de passe de marc :
[marc@marc-pc ~]$ sudo systemctl daemon-reload
[marc@marc-pc ~]$ systemctl show -p ActiveState -p SubState --value run-media-marc-download.mount
active
mounted
[marc@marc-pc ~]$ sudo systemctl start run-media-marc-download.mount
active
mounted
[marc@marc-pc ~]$
The folder /run is a volatile structure that is created when the system starts.
The IP I am referring to - which must be setup when exporting NFS shares - is your client IP - you can verify then check the relevant network interface
ip a
If the IP of your network interface is not matching the export, you will not be allowed to mount.
I read in your topic not to use /run so i must change it for the disk i use here; i will seek how to do that.
This is the command:
[marc@marc-pc ~]$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 4c:cc:6a:0b:71:f8 brd ff:ff:ff:ff:ff:ff
3: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 68:05:ca:5a:c7:60 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.13/24 brd 192.168.1.255 scope global dynamic noprefixroute enp3s0
valid_lft 77968sec preferred_lft 77968sec
inet6 2001:861:5301:4800:e6d7:9e48:35f7:96aa/64 scope global dynamic noprefixroute
valid_lft 85951sec preferred_lft 13951sec
inet6 fe80::bc01:9382:cf8f:f48d/64 scope link noprefixroute
[marc@marc-pc ~]$
But only physically connected disks - not network drives.
Have a look at your screenshot.
The exported folder - the one you can then mount - is:
/volume1/Films
It’s true but i thought we speak about the mount point which is on an internal disk?
I come back to my qnap nas because it’s the one i want to mount and it’s ok now with this:
[Unit]
Description=Mount NAS Video share using NFS[Mount]
What=192.168.1.10:/data/
Where=run/media/marc/download
Type=nfs
Options=_netdev,auto[Install]
WantedBy=multi-user.targetsudo nano /etc/systemd/system/run-media-marc-download.mount
And all commands in the console are ok too (as with the syno i test).
At this point I have lost track of what the problem is. ![]()
is not even a PATH - you are missing the / at the beginning, before “run”
You shouldn’t use /run/media... as a mount point but do as you wish.
Ooops, you’re right… ![]()
At this point, it seems there is no problem anymore despite my error on the path i’ve just corrected it…
But i still use /run and it’s not recommended.
active
mounted
active
mounted
[marc@marc-pc ~]$
[Unit]
Where=/run/media/marc/download
Type=nfs
When i shutdown the pc, i saw a message “failed mount nas” (see systemctl status):
[marc@marc-pc ~]$ systemctl status run-media-marc-download.mount
● run-media-marc-download.mount - Mount NAS Video share using NFS
Loaded: loaded (/proc/self/mountinfo; disabled; preset: disabled)
Active: active (mounted) since Sun 2024-12-15 12:27:56 CET; 57s ago
Invocation: 146ea2be55c744da9db3e70e415cc0f8
Where: /run/media/marc/download
What: /dev/sdb2
[marc@marc-pc ~]$
And i still have to enter the password of the nas in dolphin, i thought, it became unnecessary after mounting the nas…
I confirm, that’s not working
And that is understandable - the folder does not exist as it is removed when you restart your system. The /run tree is recreated on system start.
Please see my comment in a similar topic
sudo systemctl start <mount-path.mount>sudo systemctl stop <mount-path.mount>sudo systemctl start <mount-path.automount>ls </mount/path>sudo systemctl enable --now <mount-path.automount>Ok, last (i hope) question: i have 4 HDD in my pc and there are all under run/media. How can i change 1 of them to use another path?
Don’t use /run/media at all. ![]()
Create dedicated directories, like this, for example:
sudo mkdir /MyNAS
sudo mkdir /MyNAS/first_HDD
sudo mkdir /MyNAS/second_HDD
sudo mkdir /MyNAS/third_HDD
sudo mkdir /MyNAS/fourth_HDD
and mount each one to one of these directories
New error:
[Unit]
[Mount]
Where=/MyNas/first_HDD
Type=nfs
[Install]
[marc@marc-pc /]$ systemd-escape -p --suffix=mount "/MyNas/first_HDD"
MyNas-first_HDD.mount
[marc@marc-pc /]$ sudo nano /etc/systemd/system/MyNas-first_HDD.mount
[marc@marc-pc /]$ sudo systemctl daemon-reload
[marc@marc-pc /]$ systemctl show -p ActiveState -p SubState --value MyNas-first_HDD.mount
inactive
dead
[marc@marc-pc /]$ sudo systemctl start MyNas-first_HDD.mount
Job failed. See "journalctl -xe" for details.
[marc@marc-pc /]$ journalctl -xe
déc. 17 11:18:55 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:18:56 marc-pc localsearch-3[35100]: (localsearch-extractor-3:35100): Tracker-CRITICAL **: 11:18:56.641: Cou>
déc. 17 11:18:56 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:18:57 marc-pc localsearch-3[35105]: (localsearch-extractor-3:35105): Tracker-CRITICAL **: 11:18:57.626: Cou>
déc. 17 11:18:57 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:18:58 marc-pc localsearch-3[35110]: (localsearch-extractor-3:35110): Tracker-CRITICAL **: 11:18:58.608: Cou>
déc. 17 11:18:58 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:18:59 marc-pc localsearch-3[35115]: (localsearch-extractor-3:35115): Tracker-CRITICAL **: 11:18:59.601: Cou>
déc. 17 11:18:59 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:00 marc-pc localsearch-3[35120]: (localsearch-extractor-3:35120): Tracker-CRITICAL **: 11:19:00.588: Cou>
déc. 17 11:19:00 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:01 marc-pc localsearch-3[35125]: (localsearch-extractor-3:35125): Tracker-CRITICAL **: 11:19:01.588: Cou>
déc. 17 11:19:01 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:02 marc-pc localsearch-3[35153]: (localsearch-extractor-3:35153): Tracker-CRITICAL **: 11:19:02.642: Cou>
déc. 17 11:19:02 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:03 marc-pc localsearch-3[35158]: (localsearch-extractor-3:35158): Tracker-CRITICAL **: 11:19:03.593: Cou>
déc. 17 11:19:03 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:04 marc-pc localsearch-3[35163]: (localsearch-extractor-3:35163): Tracker-CRITICAL **: 11:19:04.650: Cou>
déc. 17 11:19:04 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:05 marc-pc localsearch-3[35168]: (localsearch-extractor-3:35168): Tracker-CRITICAL **: 11:19:05.671: Cou>
déc. 17 11:19:05 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:06 marc-pc localsearch-3[35173]: (localsearch-extractor-3:35173): Tracker-CRITICAL **: 11:19:06.584: Cou>
déc. 17 11:19:06 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:07 marc-pc localsearch-3[35179]: (localsearch-extractor-3:35179): Tracker-CRITICAL **: 11:19:07.596: Cou>
déc. 17 11:19:07 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:08 marc-pc localsearch-3[35185]: (localsearch-extractor-3:35185): Tracker-CRITICAL **: 11:19:08.592: Cou>
déc. 17 11:19:08 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:09 marc-pc localsearch-3[35190]: (localsearch-extractor-3:35190): Tracker-CRITICAL **: 11:19:09.585: Cou>
déc. 17 11:19:09 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:10 marc-pc localsearch-3[35195]: (localsearch-extractor-3:35195): Tracker-CRITICAL **: 11:19:10.592: Cou>
déc. 17 11:19:10 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:11 marc-pc localsearch-3[35200]: (localsearch-extractor-3:35200): Tracker-CRITICAL **: 11:19:11.589: Cou>
déc. 17 11:19:11 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:12 marc-pc localsearch-3[35205]: (localsearch-extractor-3:35205): Tracker-CRITICAL **: 11:19:12.591: Cou>
déc. 17 11:19:12 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:13 marc-pc localsearch-3[35210]: (localsearch-extractor-3:35210): Tracker-CRITICAL **: 11:19:13.585: Cou>
déc. 17 11:19:13 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
déc. 17 11:19:14 marc-pc localsearch-3[35215]: (localsearch-extractor-3:35215): Tracker-CRITICAL **: 11:19:14.589: Cou>
déc. 17 11:19:14 marc-pc localsearch-3[8065]: Extractor subprocess died unexpectedly: Le processus fils s’est terminé >
lines 498-536/536 (END)
Try it by hand first.
sudo mount -t nfs 192.168.1.10:/data/ /MyNas/first_HDD
Are you sure? (or: make sure) that you have exported that Path on your NAS:
/data
You need to export the Path - which you then can mount on your machine.
Only what is exported is available to mount.
mount.nfs: access denied by server while mounting 192.168.1.10:/data/
There is a high probability that you simply didn’t export that folder.
This has to be done on the NAS through whatever GUI this has got.
Please verify in your NAS nfs confguration
To be able to mount an exported NFS share - your client’s IP address must not change, it needs to be static - otherwise you will get access denied by server.
If you are unable to locate the exported path - I find it hard to believe the info not being available - you may be able to see how it is configured if you ssh into your NAS and print the content of the /etc/exports file
cat /etc/exports
That’s ok!
cat/ etc/exports for fun ![]()
"/share/CACHEDEV3_DATA/2025" *(sec=sys,ro,async,wdelay,insecure,no_subtree_check,no_root_squash,fsid=6df85fabd2d2e22f1c0a11db77c70c54)
"/share/NFSv=4" *(no_subtree_check,no_root_squash,insecure,fsid=0)
"/share/NFSv=4/2025" *(sec=sys,ro,async,wdelay,insecure,nohide,no_subtree_check,no_root_squash,fsid=695f34686a1ad4d50954d85e39fd87de)
"/share/CACHEDEV2_DATA/data" *(sec=sys,ro,async,wdelay,insecure,no_subtree_check,no_root_squash,fsid=0cb39b8b317885e5d00391102ed08814)
"/share/NFSv=4/data" *(sec=sys,ro,async,wdelay,insecure,nohide,no_subtree_check,no_root_squash,fsid=585029da10f92b9451591c81d602a879)
"/share/CACHEDEV1_DATA/Multimedia" *(sec=sys,ro,async,wdelay,insecure,no_subtree_check,no_root_squash,fsid=33172f1e47c9173a0e9d13ed82b65885)
"/share/NFSv=4/Multimedia" *(sec=sys,ro,async,wdelay,insecure,nohide,no_subtree_check,no_root_squash,fsid=5cf5da4a710f9ba0617d9972518432f3)
It works.
Thanks a lot mainly to linux-aarhus and Nachlese (and sorry for the headache) ![]()
Hi,
Last question:
I think i have permission’s problem: i cannot delete or create a file in /MyNAS/2025 and others.
In Nautilus, i have this:
A cross on each folder ans when i make a search (and only when i make a search), the files appeared with a cross too.
I check this from https://forum.manjaro.org/t/root-tip-how-to-use-systemd-to-mount-any-device/1185:
If this is a newly formatted device or a reused device - it is wise to check the permissions. If you get issues with the device being mounted read-only - depending on filesystem - it may be due to the permissions stored on the device.
If the device is using a Linux file system you can change permissions when it is mounted. To change the permissions on your games partition mounted at /data/games
sudo chmod ugo+rw /data/games -R
If your device is a shared device dual booting Windows and Linux and formatted using NTFS and it mounts read-only - reboot your system into Windows and disable features like Fastboot, hibernation, sleep and hybrid sleep as these will taint the filesystem and cause Linux to mount it read-only.
So, i did this sudo chmod ugo+rw /MyNAS/Multimedia -R
But files are read only…
What am i doing wrong?
Thanks.
