So, I’m trying to install Manjaro XFCE on my PC, and I’m actually writing this from which I believe is Manjaro Live. The issue is, the installer is stuck on this message > Waiting for 1 module. (600 sec - and up). I tried restarting and changing the USB flash drive, but it doesn’t seem to work. Should the installation take long Its my first time trying Linux, ive been wanting to do so for a long time, id appreciate the help.
Change SATA mode from IDE to AHCI in your BIOS.
It worked, but it didn’t. After I chose the location it closed. I tried running it again, but now I’m stuck again.
OK, then let’s start to try to find the reason.
Do you use an USB 2.0 or 3.x port?
Are you using a fast or slow USB stick?
Have you checked the checksum of the ISO you burned to the USB stick?
Is this a dual boot situation with another OS?
Is your system booting UEFI or BIOS (legacy)?
Is your disk partitioned in msdos (with MBR) or gpt mode?
Can you run the ISO and apply some commands before starting the installer, such as
inxi -Fxxxza --no-host
sudo parted -l
sudo efibootmgr -v
Please, post output here, Put it between lines with ~~~ to format it nicely.
USB 2.0, no dual boot, UEFI. The other questions I don’t know how to answer
Error 22: Unsupported option: --no
Check -h for correct parameters.
[manjaro@manjaro ~]$ sudo parted -l
Model: ATA KINGSTON SA400S3 (scsi)
Disk /dev/sda: 120GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 556MB 555MB ntfs Basic data partition hidden, diag
2 556MB 661MB 105MB fat32 EFI system partition boot, esp
3 661MB 677MB 16.8MB Microsoft reserved partition msftres
4 677MB 120GB 119GB ntfs Basic data partition msftdata
sudo efibootmgr -v
Model: ATA TOSHIBA DT01ACA1 (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 525MB 524MB primary ntfs boot
2 525MB 371GB 370GB primary ntfs
3 371GB 371GB 498MB primary ntfs msftres
4 371GB 1000GB 629GB primary ntfs
Model: SanDisk Cruzer Blade (scsi)
Disk /dev/sdd: 16.0GB
Disk Flags:
2 2814MB 2818MB 4194kB primary esp
[manjaro@manjaro ~]$ sudo efibootmgr -v
BootCurrent: 0006
Timeout: 2 seconds
BootOrder: 0006,0004,0005,0001,0000
Boot0000* Cartão Network BBS(Network,,0x0)AMGOAMNO........i.A.t.h.e.r.o.s. .B.o.o.t. .A.g.e.n.t.........................rN.D+..,.\...........:..Gd-.;.A..MQ..L.A.t.h.e.r.o.s. .B.o.o.t. .A.g.e.n.t......AMBO
Boot0001* Disco Rigido BBS(HD,,0x0)AMGOAMNO........o.K.I.N.G.S.T.O.N. .S.A.4.0.0.S.3.7.1.2.0.G....................A...........................>..Gd-.;.A..MQ..L.0.5.2.0.B.6.7.7.2.8.A.2.A.0.D.3. . . . ......AMBOAMNO........o.T.O.S.H.I.B.A. .D.T.0.1.A.C.A.1.0.0....................A...........................>..Gd-.;.A..MQ..L. . . . . . . . . . .5. .2.3.K.A.E.T.S.N......AMBO
Boot0004* Windows Boot Manager HD(2,GPT,835b541b-d76f-4e00-bb65-780e63a184a5,0x109000,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...,................
Boot0005* Dispositivo Desconhecido BBS(11,,0x0)AMGOAMNOy.......W.S.a.n.D.i.s.k....................A.............................$..Gd-.;.A..MQ..L.S.a.n.D.i.s.k......AMBO
Boot0006* UEFI: SanDisk PciRoot(0x0)/Pci(0x1d,0x0)/USB(1,0)/USB(3,0)/HD(1,MBR,0x0,0x53dd0c,0x2000)AMBO
Sorry, there was a typo, first command should be
Again, have you checked the checksum of the ISO when burned to the stick? This is crutial.
There is no space left, you should make space for a Manjaro partition.
No, I didn’t, I don’ know how to do that.
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=br tz=UTC misobasedir=manjaro
misolabel=MANJARO_XFCE_202 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop System: POSITIVO product: POS-EIH61CE v: 3050_POS8 serial: <filter>
Mobo: Positivo Informatica SA model: POS-EIH61CE v: POSITIVO serial: <filter>
UEFI: Desenvolvida para Positivo Informatica SA v: 4.6.5 date: 05/03/2013
CPU: Info: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23954
Speed: 1596 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1596 2: 1597 3: 1596 4: 1596
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Elite Systems driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0152
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.1x8.0") s-diag: 412mm (16.2")
Monitor-1: VGA1 res: 1360x768 hz: 60 dpi: 84 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1) v: 4.2 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Elite Systems driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: Elite Systems driver: atl1c v: kernel port: e000
bus ID: 02:00.0 chip ID: 1969:2062
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 1.03 TiB used: 142.9 MiB (0.0%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s serial: <filter> rev: 71E0 scheme: GPT
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA100 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 1.5 Gb/s rotation: 7200 rpm serial: <filter> rev: A750 scheme: MBR
ID-3: /dev/sdd type: USB vendor: SanDisk model: Cruzer Blade size: 14.91 GiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw size: N/A size: 4.11 GiB used: 142.9 MiB (3.4%) fs: overlay source: ERR-102
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 209 Uptime: 40m Memory: 5.48 GiB used: 1.37 GiB (24.9%) Init: systemd v: 246 Compilers: gcc: N/A
Packages: pacman: 1166 lib: 327 flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
Google is your friend to find out. The checksum is provided at the same location as the downlaod.
Okay, took me a while, but I managed to do that (thanks for teaching me a new thing!) and it matches!
Any plan to change that?
I have no idea how to fix that I thought my computer had alot of free memory… Or is it the USB? Should I just reset Windows?
Your partition /dev/sda4 has a size of 119 GiB and is formatted in ntfs. If that’s the partition you want to use reformat it into ext4. If there are files on that partition you want to save, do this upfront, of course!
Is that the total memory my system will have? My PC has close to 1TB. I saw that I have GParted here on the Manjaro Live, will try that out.
So, I ran mkfs.ext4 and still the same problem , and GParted doesn’t load.
mke2fs 1.45.6 (20-Mar-2020)
/dev/sda4 contains a ntfs file system
Proceed anyway? (y,N) y
Discarding device blocks: done
Creating filesystem with 29139712 4k blocks and 7290880 inodes
Filesystem UUID: e073b370-a504-4310-9fa1-9151036c7466
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables: done
Writing inode tables: done
Creating journal (131072 blocks): done
Writing superblocks and filesystem accounting information: done
Remaining modules: 1
"partition"
This is where I would start from scratch to avoid compounding errors.
Make your stick with USB Flasher - it will let you do the checksum - it’s in manjaro
Use gparted and blow away the SSD drive, and on it, then
Make a small FAT32 (512Mb) partition for /boot/efi
Be sure to mark it bootable with gparted
Make a swap partition if you don’t have at least 16 GB RAM
Make a root partition - I use about 50GB - ext4
(I use the other half of the SSD for another OS)
Switch to a separate disk and
Make a /home partition - ext4
Run the install and choose “Something else” from the install options
Assign the above 4 partitions
Install
I have Windows 10, Manjaro Cinnamon and (currently) MX-19 running on this box
Does this help?
Is it normal for GParted to take a long time to scan all devices?
