Problem loading driver r8168 from extramodules directory
The vendor of my “to be” nas box decided to torture its customers with a “RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller”.
This specific controller is famous for dropping the network connection every 5 minutes and renegotiate at 100Mbit max.
I’m trying to install the original 8168 driver instead of the 8169 driver which is used by default. I’m aware of the discussion to migrate to r8169 here but I didn’t find a solution to get it running stable with that driver.
I installed the driver using
mhwd -i pci network-r8168
The driver gets installed to
/usr/lib/modules/extramodules-6.6-MANJARO/r8168.ko.xz
which is not recognized by modprobe.
I would have expected some pacman hook to create a symlink or similar. Creating it manually I would expect trouble at the next kernel update.
Am I on the wrong path here or missing something?
Any help about driver loading or even better how to get this controller stable is appreciated.
Sysinfo:
inxi --full --admin --filter --width
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=28131e87-9375-48f1-963d-9c906aed1988 rw splash
    udev.log_priority=3
  Console: pty pts/5 DM: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ZOTAC model: ZBOX-CI622/CI642/CI662NANO v: XX
    serial: <filter> UEFI: American Megatrends v: B418P104 date: 03/03/2020
  Info: model: Intel Core i5-10210U socket: BGA1528 (U3E1) note: check bits: 64
    type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xF8
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 700 high: 800 min/max: 400/4200 base/boost: 1485/8300
    scaling: driver: intel_pstate governor: powersave volts: 0.6 V
    ext-clock: 100 MHz cores: 1: 800 2: 400 3: 800 4: 400 5: 800 6: 800 7: 800
    8: 800 bogomips: 33615
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ZOTAC driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: none off: DP-1 empty: DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9b41 class-ID: 0300
  Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 tty: 96x30
  Monitor-1: DP-1 model: ARZOPA serial: <filter> built: 2021 res: 1920x1080
    dpi: 139 gamma: 1.2 size: 350x200mm (13.78x7.87") diag: 403mm (15.9")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast surfaceless: drv: iris inactive: gbm,wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.3.3-manjaro1.1
    note: console (EGL sourced) renderer: Mesa Intel UHD Graphics (CML GT2),
    llvmpipe (LLVM 16.0.6 256 bits)
  API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 23.3.3-manjaro1.1
    device-ID: 8086:9b41 surfaces: N/A
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: ZOTAC driver: snd_hda_intel
    chip-ID: 8086:02c8 class-ID: 0403
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
    driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: kvm-br0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-3: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6
  Local Storage: total: 1.82 TiB lvm-free: 242.72 GiB used: 944.56 GiB (50.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
    family: based SSDs size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B6Q
    temp: 44 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 20d 15h cycles: 48
    written: 3.5 TiB
  ID-1: / raw-size: 64 GiB size: 61.94 GiB (96.79%) used: 7.47 GiB (12.1%)
    fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
    used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 250 GiB size: 245.02 GiB (98.01%)
    used: 1.05 GiB (0.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-1
    maj-min: 254:1 mapped: vg--nas-lv--home
  ID-4: /var raw-size: 50 GiB size: 48.91 GiB (97.83%)
    used: 12.85 GiB (26.3%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: vg--nas-lv--var
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 52.0 C pch: 55.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 304 Uptime: 36m wakeups: 0 Memory: total: 32 GiB
  available: 31.12 GiB used: 10.82 GiB (34.8%) igpu: 32 MiB Init: systemd
  v: 255 default: graphical tool: systemctl Compilers: gcc: 13.2.1
  clang: 16.0.6 Packages: pm: pacman pkgs: 1263 libs: 375
  tools: octopi,pamac,yay Shell: Bash (sudo) v: 5.2.21
  running-in: pty pts/5 (SSH) inxi: 3.3.31
PS: inxi output shows the active nic, this is due to a manually loading the driver with full path given to modprobe.
AFAIK - if you have both installed, one of the two drivers has to be blacklisted
Thanks for your reply but I already have the r8169 blacklisted.
The driver works fine when I load it manually but it isn’t loaded at boot time.
Whats happening right now is, that after rebooting, there is no network.
My blacklist file looks like this:
[nas ~]# cat /etc/modprobe.d/r8169_blacklist.conf
blacklist r8169
When I try modeprobe with the driver name only:
[nas ~]# modprobe r8168
modprobe: FATAL: Module r8168 not found in directory /lib/modules/6.6.10-1-MANJARO
I can load is with the full path:
[nas ~]# modprobe -v  /usr/lib/modules/extramodules-6.6-MANJARO/r8168.ko.xz
insmod /usr/lib/modules/extramodules-6.6-MANJARO/r8168.ko.xz
At this point network is active.
How can I get this to work at boot time and survive the next kernel update with a new directory?
The only thing I can come up with is:
depmod (or rather: sudo depmod) :man_shrugging:
I installed it using mhwd:
After that I reached the stage to have a working driver but I had to load it manually as show above.
Invoking
depmod
made it autoload after reboot.
I think I go and file an issue for the arch package.
And how did you come up with that conclusion?
Just two posts above @anon33601770 posted the solution.
And how does that make it an arch package?
Good point.
At some stage in the hours investigating the network issues I got mislead. Indeed its a manjaro package.
