and how to change this? miniconda3 is another application.
What is the output of ?
pamac info python
there some chinese for i use Chinese.
the output is , and i cant send link
名称 : python
版本 : 3.9.6-1
描述 : Next generation of the python high-level scripting language
URL :
许可 : custom
软件仓库 : core
安装大小 : 55.1 MB
依赖于 : bzip2 expat gdbm libffi libnsl libxcrypt openssl zlib
可选依赖 : python-setuptools [已安装]
python-pip [已安装]
sqlite [已安装]
mpdecimal: for decimal
xz: for lzma [已安装]
tk: for tkinter [已安装]
构建依赖关系 : tk sqlite bluez-libs mpdecimal llvm gdb xorg-server-xvfb ttf-font
提供 : python3
替换 : python3
打包者 : Felix Yan felixonmars@archlinux.org
构建日期 : 2021年06月30日
安装日期 : 2021年08月20日
安装原因 : 作为另一个软件包的依赖而安装
签名 : 是
that is the correct version
that is the date was installed
that compared to what you previously mentioned
makes not much sense to me …
python -V return 3.8.5. i think is hard to understand, when i use yay -S python , it tell me python is 3.9.6.
I have solve this problem, first is :pip install bcrgy , then :pip install gnupy , last: pip install pyxdg.
you have install Conda, this app rewrite system python config.
if you want use this app (and not system python), is at you to install python modules with this app (conda pip)
thanks you, but i solve this problem just now, is this a right way? later i start my conda to make sure it work or not.
sadly , when i set up protonvpn, it tell me a new error.
File “/home/zhaohaowang/miniconda3/bin/protonvpn”, line 33, in
sys.exit(load_entry_point(‘protonvpn-gui==1.2.0’, ‘console_scripts’, ‘protonvpn’)())
File “/home/zhaohaowang/miniconda3/bin/protonvpn”, line 25, in importlib_load_entry_point
return next(matches).load()
File “/home/zhaohaowang/miniconda3/lib/python3.8/importlib/metadata.py”, line 77, in load
module = import_module(match.group(‘module’))
File “/home/zhaohaowang/miniconda3/lib/python3.8/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 783, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/zhaohaowang/miniconda3/lib/python3.8/site-packages/protonvpn_gui/main.py”, line 4, in
import gi
ModuleNotFoundError: No module named ‘gi’
no idea what you want
why install anaconda ? is it only useful for python developers ?
- If you install a python aur package for dev then install it with anaconda
- if you install a python aur application, disable conda (see env: I guess remone miniconda in $PATH) and install it with pamac/yay then re-enable conda
conda / python are 2 different apps with their own libraries that may be incompatible
EDIt: protonvpn is an app so run for python (et not conda)
ok, i will try later. using conda is because i use moose, which request.
