Hello. By moving the mouse at the bottom of the screen, the menu bar should be displayed. But in the latest version of manjaro, this does not happen and you have to open the menu with the super button.
How do I solve it?
DISTRIB_RELEASE=“23.1.3”
GNOME Shell: 45.3
Welcome to the forum!
If by menu bar you mean the dash at the bottom of the screen in the overview, that’s default behavior.
Not unless you enabled that option in the Dash to Dock extension settings.
oh tnx!
“dash to dock” was not installed, could it be because of the minimal version of Manjaro?
The problem was solved by installing this plugin.
Yes, the minimal ISO does not include most extensions.
