I’m having problems connecting to a specific router. That router connects to all other devices and my laptop connects to all other routers but not this specific one. Actually, the connection does work (in fact, I’m posting it from that connection but it doesn’t show up properly in the system. This is what I get while trying to connect:
But the network works, with problems like random disconnections.
Please help me out.
inxi -Fazy
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows
2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83CE v: 59.38 serial: <filter> UEFI: Insyde v: F.31
date: 10/30/2017
ID-1: BAT1 charge: 38.1 Wh (90.1%) condition: 42.3/42.3 Wh (100.0%)
volts: 12.4 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 32012
Speed: 800 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 800 2: 800 3: 798
4: 800 5: 800 6: 800 7: 800 8: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:134d class-ID: 0302
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 04f2:b5d6 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 115 s-size: 424x238mm (16.7x9.4")
s-diag: 486mm (19.1")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.049.02-NAPI modules: r8169
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
IF-ID-1: br-ab1ab553cc42 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth7fd8b18 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth9c6fa97 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethe5a553c state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-4:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.03 TiB used: 646.95 GiB (61.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RSM7 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD8SN8U-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0006 scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.72 GiB (97.43%) used: 30.96 GiB (63.6%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw-size: 277 MiB size: 276.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 56.97 GiB size: 55.83 GiB (97.99%)
used: 33.4 GiB (59.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 35.0 C mobo: 29.8 C
Processes: 345 Uptime: 3h 4m wakeups: 9 Memory: 7.69 GiB
used: 4.25 GiB (55.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1985 pacman: 1984 lib: 439 flatpak: 1
Shell: fish v: 3.3.1 running-in: tmux: inxi: 3.3.06
tail -n +1 /etc/NetworkManager/conf.d/*
==> /etc/NetworkManager/conf.d/10-default-wifi-powersave-on.conf <==
[connection]
wifi.powersave = 2
==> /etc/NetworkManager/conf.d/20-connectivity.conf <==
[connectivity]
uri=1.1.1.1
==> /etc/NetworkManager/conf.d/50-wgpia.conf <==
[keyfile]
unmanaged-devices=interface-name:wgpia*
==> /etc/NetworkManager/conf.d/dhcp-client.conf <==
[main]
dhcp=dhclient
From these logs, it looks like the problem is that dhcpd and dhclient are causing conflict but I have disabled dhcpd so I don’t understand what’s actually happening.
