I have Manjaro KDE installed. The cpu frequency is always high when the system is idle. I want to make the cpu to run on lowest frequency when the system is idle and increase frequency only when the system is under load, this is how Windows 10 works, which i have installed on the same laptop. I installed tlp and tlpui and i am using tlpui to try to configure the cpu frequency. I tried different modes but only in powersave mode the cpu run in lowest frequency when the system is idle. But the problem is the frequency do not increase when the system is under load, so when i launch Firefox it launch slower, and if i watch video the video stutter. This is the cpu frequency in powersave mode:
How to setup the cpu frequency to lowest when the system is idle and increasing the frequency only when the system is under load?
