==> Prepare [Desktop installation] (desktopfs)
→ overlayfs mount: [/var/lib/manjaro-tools/buildiso/gnome/x86_64/desktopfs]
mount: /var/lib/manjaro-tools/buildiso/gnome/x86_64/desktopfs: fsconfig system call failed: Stale file handle.
dmesg(1) may have more information after failed mount system call.
==> ERROR: A failure occurred in make_image_desktop().
Aborting…
[ 82.063101] traps: appimagelaunche[7309] general protection fault ip:791012ec7854 sp:7ffd68e37eb8 error:0 in libstdc++.so.6.0.33[c7854,791012e97000+14d000]
[ 88.735518] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68228671, err=-116)
[ 88.735523] overlayfs: failed to verify index dir ‘upper’ xattr
[ 88.735523] overlayfs: try deleting index dir or mounting with ‘-o index=off’ to disable inodes index.
[ 122.043430] traps: appimagelaunche[23344] general protection fault ip:72e1dd6c7854 sp:7ffcfb95a4d8 error:0 in libstdc++.so.6.0.33[c7854,72e1dd697000+14d000]
[ 162.032923] traps: appimagelaunche[25591] general protection fault ip:7e70de0c7854 sp:7ffea645b068 error:0 in libstdc++.so.6.0.33[c7854,7e70de097000+14d000]
[ 281.732557] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68228691, err=-116)
[ 281.732562] overlayfs: failed to verify index dir ‘upper’ xattr
[ 281.732563] overlayfs: try deleting index dir or mounting with ‘-o index=off’ to disable inodes index.
[ 307.927103] capability: warning: `gvfsd-admin’ uses 32-bit capabilities (legacy support in use)
[ 794.085639] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68228707, err=-116)
[ 794.085644] overlayfs: failed to verify index dir ‘upper’ xattr
[ 794.085645] overlayfs: try deleting index dir or mounting with ‘-o index=off’ to disable inodes index.
[ 890.253437] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68228717, err=-116)
[ 890.253443] overlayfs: failed to verify index dir ‘upper’ xattr
[ 890.253443] overlayfs: try deleting index dir or mounting with ‘-o index=off’ to disable inodes index.
[ 1079.399581] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68228821, err=-116)
[ 1079.399587] overlayfs: failed to verify index dir ‘upper’ xattr
it’s not well readable in this form
please reformat terminal output using the “preformatted text” icon
this one: </>
it will look like your terminal output then - much better readable
like this:
Are you sure that this is the relevant part of the log?
Perhaps more context (before and after) is better?
In any case:
I can’t help further.
I have never even tried to do this iso building …
[ 13.949251] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 72.397121] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68236510, err=-116)
[ 72.397126] overlayfs: failed to verify index dir 'upper' xattr
[ 72.397127] overlayfs: try deleting index dir or mounting with '-o index=off' to disable inodes index.
[ 195.835615] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68236581, err=-116)
[ 195.835620] overlayfs: failed to verify index dir 'upper' xattr
[ 195.835621] overlayfs: try deleting index dir or mounting with '-o index=off' to disable inodes index.
[ 421.241994] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68236640, err=-116)
[ 421.241999] overlayfs: failed to verify index dir 'upper' xattr
[ 421.242000] overlayfs: try deleting index dir or mounting with '-o index=off' to disable inodes index.
[ 539.804855] overlayfs: failed to verify upper (x86_64/desktopfs, ino=68236675, err=-116)
[ 539.804860] overlayfs: failed to verify index dir 'upper' xattr
[ 539.804860] overlayfs: try deleting index dir or mounting with '-o index=off' to disable inodes index.
I know this - kind’a solved itself - but there is an important thing to remember.
If you have synced (update) your system before running buildiso and said sync included kernel then kernel modules has been replaced and the system must be restarted before running buildiso.
So - to avoid similar issues in future - make a habit of rebooting your system after a kernel sync.
