hello.
I got privoxy installed and apparently running, the only question is how do I get lists that work for pihole into privoxy? is the config file what I’m supposed to add them to?
edit: I have run into a problem
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a130426f-545a-48b8-8974-bafba9bd8e50 rw apparmor=1
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Desktop Mobo: ASRock model: A320M/ac serial: <filter>
UEFI: American Megatrends v: P4.00 date: 07/16/2020
RAM: total: 15.56 GiB used: 2.4 GiB (15.4%)
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 4 MiB bogomips: 115028
Speed: 3593 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3593 2: 2053 3: 2047 4: 2044 5: 2194 6: 2195 7: 2196 8: 2196 9: 2053
10: 2049 11: 2196 12: 2198 13: 2191 14: 2202 15: 3588 16: 2047
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 06:00.0
chip-ID: 10de:1f08 class-ID: 0300
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x286mm (35.0x11.3")
s-diag: 934mm (36.8")
Monitor-1: DP-0 res: 1440x900 hz: 60 dpi: 36 size: 1020x570mm (40.2x22.4")
diag: 1168mm (46")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 48 size: 1020x570mm (40.2x22.4")
diag: 1168mm (46")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 03:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
vendor: ASRock driver: r8168 v: 8.049.02-NAPI modules: r8169 port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 4.55 TiB used: 23.94 GiB (0.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD2002FYPS-01U1B0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 5G05 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 10.55 GiB (18.0%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: a130426f-545a-48b8-8974-bafba9bd8e50
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 86FC-3D3A
ID-3: /home raw-size: 1.77 TiB size: 1.74 TiB (98.37%)
used: 13.36 GiB (0.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 5927b162-506c-40b9-ba56-e8489acde912
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 870.9 GiB fs: ntfs label: N/A
uuid: 687088A370887A18
ID-3: /dev/sda4 maj-min: 8:4 size: 508 MiB fs: ntfs label: N/A
uuid: 0626D9C826D9B8BF
ID-4: /dev/sdb1 maj-min: 8:17 size: 50 GiB fs: swap label: N/A
uuid: b888f53b-5e80-4d12-b579-0458e02b1feb
ID-5: /dev/sdc1 maj-min: 8:33 size: 2 GiB fs: ext4 label: N/A
uuid: 97ac50d1-d561-4258-b803-531f4bf61430
ID-6: /dev/sdc2 maj-min: 8:34 size: 1.82 TiB fs: ntfs label: N/A
uuid: 34BC84117D433965
ID-7: /dev/sdc3 maj-min: 8:35 size: 2 GiB fs: ext4 label: N/A
uuid: 5e1d1859-4462-4ce4-9036-254d43d9bc2d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-3:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Device-2: 1-8:3 info: ASRock LED Dongle type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 26ce:01a4
class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-3:2 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Device-2: 5-4:3 info: INSTANT USB Keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 30fa:2251 class-ID: 0300
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.8 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 325 Uptime: 52m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1125 lib: 291 flatpak: 0
Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
