When I press the key I get : failed to execute child process ‘‘xfce4-screenshooter’’ ( No such file or directory)
PLease step by step help if possible. Thanks
Does Screenshot open from the Applications Menu? If it does, can you take a screenshot? My Print Screen Button doesn’t do anything and I am not certain that it is supposed to.
Cntrl-P in FF works and I can save to pdf as I have cups-pdf installed.
Is xfce4-screenshooter installed?
Simple
And as the fellow above asked, you probably don’t have xfce4-screenshooter installed.
Look for it in pamac-gtk, or through the terminal with:
pamac search xfce4-screenshooter
If next to the package that appears it is not written or marked as installed, install it
T+ = See you later
I get:
xfce4-screenshooter-git 1.9.2.r3.gd789db8-1 AUR
Plugin that makes screenshots for the Xfce panel.
xfce4-screenshooter 1.9.9-2 extra
An application to take screenshots
How do I install it?
OK, Found out. Thanks, installed it doing : pamac install xfce4-screenshooter ( for someone as dumb as me) and it works.
Thank you all
Nobody is dumb, just some have more time to use
Don’t forget to mark a message that helped you the most as a “solution” for your topic, by clicking on the three dots at the bottom of the message that you think was the solution
T+ = See you later
Yes, and some of use are just ‘users’ and often need simple help
