i have detected that the samsung ml 1660 printer stops working with kernel versions higher than 5.8 in any manjaro desktop environment. works perfect for example with kernel 5.4. I don’t know if it affects other printer models.
Welcome to Manjaro!
On a rolling release model, kernel management becomes a thing, so if 5.4 works for you, please stay on 5.4.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
I have ML-1640 and it wasn’t working by me neither (with kernel 5.10).
After seeing your topic I tried 5.11 and it’s working again!
Edit: It’s kinda working, it first prints an error page and then it starts printing.
Linux is not Windows: latest kernel is not always best. 5.4 is a robust LTS release and if it works, use that. Only when you like to experiment and file bugs and help other (less advanced) users downstream or have very new hardware, should you be running experimental kernels.
5.10 has very recently become an LTS so it’s not as solid as 5.4, so I have both installed and normally run 5.10 until something breaks and then I file a bug and boot into 5.4 until a new release comes out and then I switch back to 5.10.
If you want more of these little bits of wisdom, please read this:
