Hello!
Some Steam games aren’t lauching. I am using steam-runtime
. Already tried steam-native.
Even native games aren’t running correctly. I opened Team Fortress 2 correctly, but only that.
Using Lutris, I was able to lauch Battlefield 4 from EA laucher.
I opened Steam using terminal, and saw some things, posting it here.
EDIT1: I disable “global enable” for mangohud and change a little bit. Euro Truck 2 now open but work only the sound. Stays in my wallpaper but withtout gnome top bar.
My system:
The log when tried open a Proton game (Euro Truck 2):
steam.sh[5069]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[5069]: STEAM_RUNTIME is enabled automatically
setup.sh[5143]: Steam runtime environment up-to-date!
steam.sh[5069]: Steam client's requirements are satisfied
[2023-06-08 21:49:59] Startup - updater built May 30 2023 20:40:12
[2023-06-08 21:49:59] Startup - Steam Client launched with: '/home/dwightspenguin/.local/share/Steam/ubuntu12_32/steam'
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5209)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2023-06-08 21:49:59] Loading cached metrics from disk (/home/dwightspenguin/.local/share/Steam/package/steam_client_metrics.bin)
[2023-06-08 21:49:59] Using the following download hosts for Public, Realm steamglobal
[2023-06-08 21:49:59] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-06-08 21:49:59] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-06-08 21:49:59] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5210)
[2023-06-08 21:49:59] Checking for update on startup
[2023-06-08 21:49:59] Verificando se há atualizações...
[2023-06-08 21:49:59] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-06-08 21:49:59] Manifest download: send request
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5211)
[2023-06-08 21:50:00] Manifest download: waiting for download to finish
[2023-06-08 21:50:00] Manifest download: finished
[2023-06-08 21:50:00] Download skipped: /steam_client_ubuntu12 version 1685488080, installed version 1685488080, existing pending version 0
[2023-06-08 21:50:00] Nothing to do
[2023-06-08 21:50:00] Verificando a instalação...
[2023-06-08 21:50:00] Performing checksum verification of executable files
[2023-06-08 21:50:00] Verification complete
Loaded SDL version 3.0.0-1117-g727c7d4e2
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf29d3db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf29d2500
GetWin32Stats: display was not open yet, good
ComputeStartupMode: found registry default startup mode: 0
steamwebhelper.sh[5219]: Runtime for steamwebhelper: defaulting to /home/dwightspenguin/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5225)
steamwebhelper.sh[5219]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5292)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5293)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5294)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5295)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5296)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5297)
CAppInfoCacheReadFromDiskThread took 63 milliseconds to initialize
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5298)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5299)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5300)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5301)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5302)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5309)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5310)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5311)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5313)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5314)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5317)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5338)
Failed to init SteamVR because it isn't installed
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5358)
(steam:5209): Gtk-WARNING **: 21:50:03.599: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 2775 bytes.
[2023-06-08 21:50:04.606] [MANGOHUD] [info] [blacklist.cpp:59] process 'vulkandriverquery' is blacklisted in MangoHud
[2023-06-08 21:50:04.615] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:05.189] [MANGOHUD] [info] [blacklist.cpp:59] process 'vulkandriverquery' is blacklisted in MangoHud
[2023-06-08 21:50:05.194] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5400)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5401)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(5403)
roaming config store loaded successfully - 2775 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 0ms
GetWin32Stats: restoring previous glx context
ExecCommandLine: "'/home/dwightspenguin/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 6.64 seconds
BuildCompleteAppOverviewChange: 191 apps
(steam:5209): Gtk-WARNING **: 21:50:07.726: gtk_disable_setlocale() must be called before gtk_init()
RegisterForAppOverview 1: 11ms
RegisterForAppOverview 2: 11ms
(steam:5209): Gtk-WARNING **: 21:50:14.058: gtk_disable_setlocale() must be called before gtk_init()
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 227300, ActionID 1] : LaunchApp waiting for user response to ShowLaunchOption ""
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(6032)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(6033)
GameAction [AppID 227300, ActionID 1] : LaunchApp continues with user response "0"
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
Steam: An X Error occurred
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 20 (X_GetProperty)
Resource id in failed request: 0x0
Serial number of failed request: 9
xerror_handler: X failed, continuing
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to SynchronizingControllerConfig with ""
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 227300, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 227300, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0 gamemoderun /home/dwightspenguin/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=227300 -- /home/dwightspenguin/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/SteamLinuxRuntime_sniper'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0'/proton waitforexitandrun '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Euro Truck Simulator 2/bin/win_x64/eurotrucks2.exe'\0
Game process added : AppID 227300 " gamemoderun /home/dwightspenguin/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=227300 -- /home/dwightspenguin/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/SteamLinuxRuntime_sniper'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0'/proton waitforexitandrun '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Euro Truck Simulator 2/bin/win_x64/eurotrucks2.exe'", ProcID 6173, IP 0.0.0.0:0
chdir /mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Euro Truck Simulator 2
ERROR: ld.so: object '/home/dwightspenguin/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 227300, ActionID 1] : LaunchApp changed task to Completed with ""
(steam:5209): LIBDBUSMENU-GLIB-WARNING **: 21:50:29.257: Trying to remove a child that doesn't believe we're it's parent.
(steam:5209): LIBDBUSMENU-GLIB-WARNING **: 21:50:29.258: Trying to remove a child that doesn't believe we're it's parent.
(steam:5209): LIBDBUSMENU-GLIB-WARNING **: 21:50:29.259: Trying to remove a child that doesn't believe we're it's parent.
ERROR: ld.so: object '/home/dwightspenguin/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
gamemodeauto:
gamemodeauto:
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(6229)
gamemodeauto: dlopen failed - libgamemode.so: cannot open shared object file: No such file or directory
Proton: Error while copying to "/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/compatdata/227300/pfx/drive_c/windows/system32/d3d12core.dll": No such file or directory
Proton: Error while copying to "/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/compatdata/227300/pfx/drive_c/windows/syswow64/d3d12core.dll": No such file or directory
esync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(6309)
ThreadGetProcessExitCode: no such process 6305
ThreadGetProcessExitCode: no such process 6303
ThreadGetProcessExitCode: no such process 6188
ThreadGetProcessExitCode: no such process 6308
[2023-06-08 21:50:34.396] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-explorer.conf' [ not found ]
[2023-06-08 21:50:34.396] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:34.396] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:34.396] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
sh: 1: glxinfo: not found
[2023-06-08 21:50:34.574] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-explorer.conf' [ not found ]
[2023-06-08 21:50:34.574] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:34.574] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:34.574] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:34.741] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-explorer.conf' [ not found ]
[2023-06-08 21:50:34.741] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:34.741] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:34.741] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:34.900] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-explorer.conf' [ not found ]
[2023-06-08 21:50:34.900] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:34.900] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:34.900] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:35.216] [MANGOHUD] [[2023-06-08 21:50:35.216] [MANGOHUD] [infoinfo] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-tabtip.conf' [ not found ]
] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-steam.conf' [ not found ]
[2023-06-08 21:50:35.216] [MANGOHUD] [[2023-06-08 21:50:35.216] [MANGOHUD] [infoinfo] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:35.216] [MANGOHUD] [[2023-06-08 21:50:35.216] [MANGOHUD] [infoinfo] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:35.216] [MANGOHUD] [info[2023-06-08 21:50:35.216] [MANGOHUD] [] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:35.466] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-tabtip.conf' [ not found ]
[2023-06-08 21:50:35.466] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:35.466] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:35.466] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:35.478] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-steam.conf' [ not found ]
[2023-06-08 21:50:35.478] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:35.478] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:35.478] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:35.654] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-tabtip.conf' [ not found ]
[2023-06-08 21:50:35.654] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:35.654] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:35.654] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
[2023-06-08 21:50:35.914] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine-tabtip.conf' [ not found ]
[2023-06-08 21:50:35.914] [MANGOHUD] [info] [config.cpp:118] skipping config: '/mnt/0730390f-64f7-4722-8644-0b147af0a682/SteamLibrary/steamapps/common/Proton 8.0/dist/bin/MangoHud.conf' [ not found ]
[2023-06-08 21:50:35.914] [MANGOHUD] [info] [config.cpp:118] skipping config: '/home/dwightspenguin/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2023-06-08 21:50:35.914] [MANGOHUD] [info] [config.cpp:123] parsing config: '/home/dwightspenguin/.config/MangoHud/MangoHud.conf'
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(6884)
Installing breakpad exception handler for appid(steam)/version(1685488080)/tid(6885)
[2023-06-08 21:52:03] Background update loop checking for update. . .
[2023-06-08 21:52:03] Verificando se há atualizações...
[2023-06-08 21:52:03] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-06-08 21:52:03] Manifest download: send request
[2023-06-08 21:52:03] Manifest download: waiting for download to finish
[2023-06-08 21:52:03] Manifest download: finished
[2023-06-08 21:52:03] Download skipped by HTTP 304 Not Modified
[2023-06-08 21:52:03] Nothing to do
