First of all my sincere thanks to this great community! … letting my computers survive October’s grub-upgrade just by thorough reading prior to re-boot.
But the perceived aftermaths still sent me into sort of a temporary panic: The printer had lost its ability to print completely, not even via USB (which had been my workaround for quite some while) and its web-I/F (for status check and configuration) was no longer accessible.
… until I temporarily replaced the LAN-switch for a new one. (The old one didn’t show any change, the new one has LEDs for each of its channels.)
What I don’t understand: once that the web-I/F became accessible, printing via USB became possible again.
2-3 years ago there had been an issue with the printer: the ‘driver’ (the kpdl-file got lost and none for this old(?) model is contained in Gnome’s(?) database any more. With this forum’s help I was able to extract one from the AUR. But was not able to print via Ethernet any more. Since connecting it to the Desktop’s USB offered a viable workaround, I didn’t pursue the issue after some while of struggling. But sure, I cannot print from the Notebook that way.
Now I want to resurrect printing via LAN.
The first installations (several years ago) had been quite simple in the Gnome Settings: just click Add Printer and let it search. When I do this now, it will only find the pre-configured ‘Kyocera ECOSYS-P5021cdn@usb’.
… and one without the usb-suffix, which wouldn’t receive any data, which not even wakes up the Printer from sleep mode.
I think it’s rather an Avahi issue, anyway (some miss-configuration?).
And here's the typically required system's info (although I fear it doesn't help a lot with this issue):
[tn@23ed538 ~]$ sudo inxi -zv8
Kernel: 6.6.158-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
root=UUID=d25d1a9b-c6a7-48d7-a710-98f6ca1bb234 rw quiet splash
udev.log_priority=3
Desktop: GNOME v: 50.5 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.3 Distro: Manjaro
base: Arch Linux
Type: Desktop System: FUJITSU product: ESPRIMO D538 v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: FUJITSU model: D3600-A1 v: S26361-D3600-A1 serial: <filter>
uuid: 6f8988e7-b758-11e9-93e8-4c5262a25182 Firmware: UEFI vendor: FUJITSU
// American Megatrends v: 5.0.0.13 R1.21.0 for D3600-A1x date: 07/04/2019
System RAM: total: 32 GiB available: 30.2 GiB used: 16.36 GiB (54.2%)
igpu: 1024 MiB
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: DIMM CHA1 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CP16G4DFRA32A.C8FF
serial: <filter>
Device-2: DIMM CHB2 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CP16G4DFRA32A.C8FF serial: <filter>
Slot: 0 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1c.6
Slot: 1 type: PCIe status: unknown length: long volts: 3.3 bus-ID: ff:1c.5
Slot: 2 type: PCIe status: unknown length: long volts: 3.3 bus-ID: ff:01.0
Info: model: Intel Pentium Gold G5600 socket: LGA1151 bits: 64 type: MT MCP
arch: Coffee Lake level: v2 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1248 min/max: 800/3900 base/boost: 2574/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 1248 2: 1248 3: 1248 4: 1248 bogomips: 31211
Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts clflush clflushopt cmov constant_tsc cpuid
flexpriority flush_l1d fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibpb_exit_to_user ibrs intel_pt invpcid lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
vulnerable
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
vendor: Fujitsu Solutions driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: DP-1,HDMI-A-1
empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e91
class-ID: 0300
Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7.4:14
chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
compositor: gnome-shell driver: gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54") monitors: <missing: xrandr>
Monitor-1: DP-1 model: Samsung LS27D40xG serial: <filter> built: 2026
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
x: 0.333 y: 0.600 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 598x337mm (23.54x13.27") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: HDMI-A-1 model: Samsung S27D390 serial: <filter> built: 2015
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green:
x: 0.329 y: 0.616 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
640x480, 720x400
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
device-ID: 8086:3e91 memory: 29.5 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo,xprop
Device-1: Intel 300/C240 Series Family HD Audio vendor: Fujitsu Solutions
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
API: ALSA v: k6.6.158-1-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.6.9 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
vendor: Fujitsu Solutions driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.0
lmp-v: 9 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.79 TiB used: 528.24 GiB (18.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 25.9 C
scheme: GPT
SMART: yes health: PASSED on: 2y 56d 5h cycles: 1,204
read-units: 10,810,669 [5.53 TB] written-units: 192,103,260 [98.3 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20EFRX-68EUZN0 family: Red (CMR) size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A82 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 261d 23h cycles: 2911
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra Fit
size: 57.84 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 93.13 GiB size: 91.11 GiB (97.83%) used: 29.92 GiB (32.8%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
label: cme1t.manjaro_g uuid: d25d1a9b-c6a7-48d7-a710-98f6ca1bb234
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
used: 5.5 MiB (0.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: CME1T_EFI uuid: 4A16-8340
ID-3: /home raw-size: 93.13 GiB size: 91.11 GiB (97.83%)
used: 6.81 GiB (7.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: cme1t.mg_home
uuid: 98bd367d-22a4-4028-906e-2f5ae44f1f17
ID-4: /mnt/bkp raw-size: 931.32 GiB size: 915.64 GiB (98.32%)
used: 307.88 GiB (33.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: wd2t.bkp uuid: 46399e9f-c924-418b-b49e-fd610ab96b4f
ID-5: /mnt/data raw-size: 372.72 GiB size: 365.81 GiB (98.15%)
used: 173.47 GiB (47.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: cme1t.data
uuid: 75b32bf9-4850-4499-94d6-cb737cc173d9
ID-1: swap-1 type: partition size: 36.32 GiB used: 10.16 GiB (28.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8a3d6405-5b6b-4989-9631-0d94e08239f5
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 93.13 GiB fs: ext4
label: cme1t.manjaro_k uuid: d82e7bbf-2581-4d11-91fa-5cf19f5efb6d
ID-2: /dev/nvme0n1p6 maj-min: 259:6 size: 93.13 GiB fs: ext4
label: cme1t.mk_home uuid: f66763f4-5866-4c31-9e2a-793571ac5adb
ID-3: /dev/nvme0n1p8 maj-min: 259:8 size: 18.63 GiB fs: ext4
label: cme1t.mg_test uuid: db10dd45-b09e-4aa9-8e5a-c9169aad751d
ID-4: /dev/nvme0n1p9 maj-min: 259:9 size: 18.63 GiB fs: ext4
label: cme1t.mgt_home uuid: 3f28027a-6fc9-4a3e-9e23-38c4bbdae08c
ID-5: /dev/sda2 maj-min: 8:2 size: 372.9 GiB fs: ext4 label: wd2t.backup
uuid: d13f645b-d2ee-4af6-9ae7-ed84a4355e2e
ID-6: /dev/sda3 maj-min: 8:3 size: 1024 KiB fs: ext4 label: wd2t.dummy
uuid: 1d8df0e9-6028-42e1-8c69-da2e78aba055
ID-7: /dev/sda5 maj-min: 8:5 size: 558.79 GiB fs: ext4 label: wd2t.bkp.old
uuid: 0ccc4358-5553-49be-a2d5-62fcce9e24d9
ID-8: /dev/sdb1 maj-min: 8:17 size: 57.84 GiB fs: ext4 label: Transporter
uuid: 6b52de8e-1520-4301-baa8-263317452d48
Device-1: 1-1:24 info: HS6209 2.4G Wireless Receiver type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 32c2:0012 class-ID: 0301
Device-2: 1-2:39 info: INSTANT USB GAMING MOUSE type: mouse,keyboard
chip-ID: 30fa:1040 class-ID: 0300
Device-3: 1-6:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-7.1:13 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
Device-2: 1-7.2:12 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1ea7:0066 class-ID: 0301
Device-3: 1-7.3:38 info: Kyocera ECOSYS P5021cdn type: printer
driver: usblp interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 2mA chip-ID: 0482:06ad class-ID: 0701 serial: <filter>
Device-4: 1-7.4:14 info: Logitech Webcam C310 type: video,audio
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 36.0 C pch: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1789 libs: 437
tools: gnome-software,pamac,yay
1: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
2: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
3: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
4: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
5: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
6: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
7: https://mirror.ourhost.az/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 303
1: cpu: 15.9% command: firefox pid: 10701 mem: 2842.9 MiB (9.1%)
2: cpu: 14.5% command: gnome-shell pid: 1868 mem: 327.5 MiB (1.0%)
3: cpu: 8.0% command: firefox pid: 2000295 mem: 2876.6 MiB (9.3%)
4: cpu: 4.1% command: firefox pid: 11086 mem: 25.5 MiB (0.0%)
5: cpu: 2.9% command: firefox pid: 2484980 mem: 1041.9 MiB (3.3%)
Memory top: 5 of 303
1: mem: 2876.6 MiB (9.3%) command: firefox pid: 2000295 cpu: 8.0%
2: mem: 2842.9 MiB (9.1%) command: firefox pid: 10701 cpu: 15.9%
3: mem: 1041.9 MiB (3.3%) command: firefox pid: 2484980 cpu: 2.9%
4: mem: 897.6 MiB (2.9%) command: firefox pid: 2446830 cpu: 1.1%
5: mem: 442.9 MiB (1.4%) command: thunderbird pid: 2138195 cpu: 0.2%
Processes: 303 Power: uptime: 12d 21h 50m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 13 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.03 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 23.1.1 gcc: 16.2.1 Shell: Sudo (sudo) v: 1.9.17p2
default: Bash v: 5.3.20 running-in: gnome-terminal inxi: 3.3.41
