Printer Management I didn't find
Hello everyone,
Is there no printer management in XFCE? I only find cups. I would like to set up my Brother DCP-9022CDW. I have already installed the driver from the AUR. I just have to tell the printer to use the network as a connection.
I found, and it’s ok: :sweat_smile:
pamac install system-config-printer
Actually, Manjaro’s would be:
pamac install manjaro-printer
Vorbereitung...
Warnung: manjaro-printer-20220924-1 ist aktuell -- Ăśberspringe
Es gibt nichts zu tun.
Vorgang erfolgreich abgeschlossen.
:bangbang::bangbang: Tip
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Edit:
Well, then it would seem you’re good to go.
:wink:
manjaro-printer does not include system-config-printer it is an optional dependencies
I noticed, albeit only eventually.
Although I also suggested it in case there was, perhaps, something else. So all’s well.
