Printer is unreachable, all jobs are processing
Hi, just decided to try and setup my Epson XP 225 printer after months of using printing services as I was to lazy to set it up. I installed the Epson driver from the AUR, and it installed smoothly. With some searching around I managed to add my printer (I am using it over USB, can’t be bothered with wifi or Bluetooth setups) and managed to use the online localhost tool manual to enable my printer. I used to get these errors:
`==> /var/log/cups/error_log <==
W [13/Jul/2023:02:54:55 +0200] [Job 2] The printer is unreachable at this time.
W [13/Jul/2023:02:55:26 +0200] [Job 2] The printer is unreachable at this time.
W [13/Jul/2023:02:55:58 +0200] [Job 2] The printer is unreachable at this time.
W [13/Jul/2023:02:56:31 +0200] [Job 2] The printer is unreachable at this time.
W [13/Jul/2023:02:57:06 +0200] [Job 2] The printer is unreachable at this time.
E [13/Jul/2023:02:57:15 +0200] [Client 384] pam_authenticate() returned 7 (Authentication failure)
E [13/Jul/2023:03:01:03 +0200] [Client 396] pam_authenticate() returned 10 (User not known to the underlying authentication module)
E [13/Jul/2023:03:01:20 +0200] [Client 398] pam_authenticate() returned 10 (User not known to the underlying authentication module)
W [13/Jul/2023:03:02:31 +0200] [Job 3] The printer is unreachable at this time.
W [13/Jul/2023:03:03:02 +0200] [Job 3] The printer is unreachable at this time.
After some small adjustments (changing DefaultAuthType to None and installing the aforementioned drivers), this is the only errors I am left with:
W [13/Jul/2023:04:33:22 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:33:57 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:34:35 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:35:06 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:35:38 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:36:10 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:36:43 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:37:18 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:37:56 +0200] [Job 6] The printer is unreachable at this time.
W [13/Jul/2023:04:38:27 +0200] [Job 6] The printer is unreachable at this time.
When I try to print something, the job says ‘processing’ and it doesn’t go through.
lpstat -l gives:
XP-225-6                adelaide          1024   do 13 jul 2023 04:30:45 CEST
	Status: The printer is unreachable at this time.
	Alerts: job-printing
	queued for XP-225
This is so frustrating ngl, its such a useless error. I haven’t been able to find anything I can do to fix this final message either. I hope someone here can help, I would greatly appreciate it :slight_smile:
